Converting a captive power connection.
Tracy B
Seattle
What is a good connector to use when converting away from a captive power connection on a turntable?
My table requires AC 120v, 50/60 hz.
I should also ask about converting captive RCA interconnects. I was looking at Vampire Wire #CM7F High end copper chassis mount RCA connectors and Vampire Wire #BP.5 Grounding Post.
What is the best cable choice to solder at the interior?
Is silver solder the best choice?
The table is a Pioneer PL-518
