Clear Audio Double Matrix Sonic - how long does it take to clean?
Golucid
Taking a break
The unit is quick! One Minute and 38 seconds. Boom! Yeah, that's start to finish!
Man, that is fast
does the lp sound any better if you do it twice or 3 times?
Man, that is fast
Hmmm... I have not needed to clean my discs more than once so far. The first go is so remarkable that I have not needed to run an LP twice to achieve sonic improvement.
I am going to take a trip to a record store today and pick up some both new and used records and I will run them through the ClearAudio only. Maybe I will run them twice or thrice and listen if there is improvement.
