Chassis grounding Typhon vs Altaira
Dizzie
Sacramento
Has anyone used a Typhon T2 for chassis grounding then tried an Altaira CGS? I currently have a Denali 6000/S v2 connected to a Typhon T2. I am using Alpha grounding cables for my source components. Amps are on a different wall and power conditioner.
It's my understanding that Typhon T2 is a high-current power distributor, designed to provide maximal DTCD for amplifiers. It's not a ground-plane noise reduction hub, per se, and as such, it's primary function is not to provide chassis-ground plane noise reduction in the manner that Altaira does. I'd check with Mike as to how it might best be utilized for your specific application(s).
This diagram from the Typhon T2's product literature shows recommended applications for Typhon T2.
