Cable direction
ozzy
USA Michigan
Dumb question, I am trying a Valhalla BNC digital cable from the Ether Regen to a AfterDark clock.
The Valhalla has a arrow pointing the direction. Does the arrow point towards the clock or to the EtherRegen?
The arrow points in the direction of signal flow. Also, don't be afraid to try it in the "wrong" direction, sometimes they sound better that way.
Based on my listening, the arrow should point towards the Uptone EtherRegen.
So, from the clock to the EtherRegen. At least with the Valhalla,
ozzy
ozzy - I hate to contradict our fine and honorable host Mike, but think you've got it correct. The clock's output feeds the EtherRegen's clock input so the arrow would be expected to point towards the ER.
You are correct. I was thinking the clock was for the DAC. Forgot we have clocks for switches now!
If in the Northern Hemisphere the toilet flushes clockwise and in the Southern, counterclockwise, do electrons.. oh, never-mind.... LOL
in Pharma where it should stay.
I get it, that’s the typical response from an audiophile. I respect the opinion, but the implication that it is only a Pharma thing is not accurate.
Blind tests are used in many studies beyond Pharma. For example, ask ANY company involved in the food business.
It would still be great if the OP do a blind test and share with us the results. After all, people hear whatever they THINK they hear.
Yes, the AfterDark Clock manufacturer confirmed, the arrow points towards the EtherRegen from the clock.
Kinda surprised me, but the sound quality difference doesn't lie.
ozzy
If directional, imo the arrows point from source >> to further downstream.
For me, I'm still guessing if this is right, I mean copper is copper and I'm somehow always tempted to reverse my only cable that has directional arrows on it :) But I don't
Copper's properties and characteristics are dependent on it's crystalline structure, and how that crystalline structure is produced during refinement and how it is drawn during casting. Its crystalline structure impacts its audio qualities.
To wit: (PDF) 📄 Microstructure and texture evolution of cold drawing 〈110〉 single crystal copper
What about annealing and compaction effects on the copper ...?
Regards
Hum from what I remember, annealing of copper only takes place around temps of 700F. And the compaction with copper only takes place with copper powder. So not sure how this is going to impact a solid core cable is some audio system.
Yeah, but the direction of the arrow simply comes about by which end of the cable shield is connected to ground, which should be the upstream end. The other end the shield is not connected to anything. So the arrow points in the direction of the cable end where the shield is not connected. This was discussed in an Audioquest forum where AQ made a batch of cables where both ends were connected to ground, which was a manufacturing fault. Pointed out by an owner who discovered the cable sounded no different in either way the cable was hooked up, and the fault finding after that discovered the manufacturing defect.
