BRYSTON and DSD
DSD
Hi folks
I have been asked a number of times by our customers our position on DSD so please find below our thoughts.
DSD currently is available in a number of variations. Assuming you want to produce a product that can grow with time and market forces both hardware and software should to be considered.
DOP 64, 128, 256, 512 (last 2 are theoretical at this point) and DSD Native are the current options.
Currently DSD is possible relatively easily with current software and hardware utilizing DOP 64 on current DAC’s and to some degree DOP 128
For example:
DOP-64 requires 176.4 capable DAC’s
DOP-128 requires 352.8 capable DAC’s
DSD Native 64 x 44.1 (standard 2.8224 MHz) (which is equivalent to 16 BIT 176.4 PCM) DAC’s.
Currently the majority of DSD capable products today are using DOP-64 architecture and some DOP-128 and DSD Native. There are also some manufacturers that have proprietary hardware and software which are capable of DOP-64, DOP-128 and Native DSD but proprietary software is not compatible with USB 2 drivers etc.
The other issue we are investigating has to do with the sample rate converters in DAC’s. In order to activate DSD the sample rate converter on the DAC inut stage would have to be a custom piece because current sample rate converters are not equipped to handle DSD to the best of our knowledge?
So that means in a standard PCM converter like our BDA-2 you would have to bypass the sample rate converter which may cause more jitter because our current sample converters reduce jitter on the input. So in Bryston’s case we definitely want the sample rate converter in the circuit for 44.1 to 192 PCM signals. Also some DAC’s we have looked at that are DSD capable convert all the incoming sample rates (44,48,88,96,176,192Hz) to a very high single sample rate ‘Asynchronously’ whereas our preference with our DAC’s is to maintain the ‘Native’ incoming sample rate throughout the conversion process with all PCM signals. If we do up-sample we do it in a synchronous manner so (44.1 becomes 176.4 and 48 becomes 192) not asynchronous.
So before Bryston goes down the DSD road I want to make sure we are providing our customers with the full story and allowing for possible advancements in both hardware and software development as much as possible. Also please offer any info or input if you feel we are mistaken or misinformed.
james tanner
Note- DOP – Stands for DSD over PCM
James - what about a BDA-3, BDP-3 and BDSD (native DSD up to X2 - much better than DoP). Modular approach? So those who don't give a hoot about DSD, can just go with the BDA/BDP.
Hi Mike
Yes I have thought about that especially in the context of having to bypass the sample rate convert in the case of PMC and increasing jitter for the sake of adding DSD.
It may mean if you want the best of PCM you go with the BDA-2 and if you want DSD you go with a new product thet does both PCM and DSD (BDA-3?)
james
I was thinking modular based. Not everyone cares about DSD. Plus, not a lot (any?) are doing PCM and DSD in separate boxes. From a marketing perspective, you could argue that the best PCM and best DSD can't be done in the same box. Just a thought.
Hello james
I understood now the bda2 playback Dop64 makes it converts to Pcm 24/176 all Dsd 64 and 128, it does not play natively dsd.
I have 'em in separate boxes!
Hello james
Hi
I believe so - when I play DSD files for instance using JRIVER it converts the files to 176/24 PCM and does play them but I have not tried other programs like Media Monkey etc. It is JRiver though doing the conversion not the BDA-2.
james
I would be happy with a BDA based on doubling up on the AKM4399s on a mono design and beefed up power supply as a Bryston Ref DAC with USB, AES/EBU and Coax inputs and AES/EBU analog outputs. The AKM4399 is a fantastic sounding chip.
I'm still on the fence with DSD. Not a lot of music avail. Also, I hate to buy the same music for the 3rd or 4th time!
The BDA2 uses a mono design with dual AKM dacs already and the power supply is substantial - have a listen to one!!!!
james
Hi Folks,
So far these are the DSD DAC units which we have tested that will work with BDP-2 and the new Manic Moose software.
Bricasti – M1
EMM XDS-1 – B2
Schitt
AYRIES QB9
