Boenicke Audio W8
wizard
Read a review here
I've heard the bigger W20SE and W20, and they are phenomenal sounding speakers.
Many thanks. The Boenicke W5 and W8-series are revolutionary speakers that needs to be seen and experienced to be believed. Seriously.
Having a pair of these sent to my home next week to try, and if I like them, they will be my new speakers!
Fingers crossed they work well in my room.
In the end it's not the costs of individual components, but how they work together and what sound they produce that counts, right?
Indeed. The solid wood construction of the Boenicke speakers are also much more sophisticated (and costly) compared to most other MDF-enclosures on this level.
/ Marcus
They've arrived!
And Wow! I couldn't believe how small they were and I've read that they need a good few hours before they are at their best, but I find they are bloody good already!
I'm listening to the Best of James Taylor in 24bit and it sounds brilliant.
I was reading a review of these speakers by an Australian magazine and the reviewer mentioned that they do need a lot of power to run well.
Sven Boenicke saw the review and emailed to say to run his speakers really well you need 1000 watts into 4 ohms! That is a load of power.
The specs for my amp is 700 watts into 4 ohms so I'm not far off :)
I have my speakers turned inwards towards my listening position.
I guess it is different for all manufacturers but should the speakers be facing directly towards my head, or toed in slightly more so that they are pointing to my opposite ear?
I find having the speakers facing directly towards my sitting position, some high notes on bad recordings are a little too direct, so I now have them crossing just in front of my sitting position and find it works really well now, with a very good stereo image.
