Wow! This seems like a thing of beauty. Anyone hear one?
http://www.ambienceaudio.com/product.htm?id=ubbmuhuh#prettyPhoto
Many times- what do you want to know? Could be the best 845 for sane money.
Very simple design with excellent transformers.
Joe- sounds like you're having fun! I love high efficiency speakers precisely for this reason.
if you love SET, i would probably try a more SET- friendly speaker and hear the difference. IMO a 4 ohm speaker like the Strads is leaving stuff on the table. Although certainly monoblocks will be beneficial.
Joe - on mine, the only stock tubes I left are the 310a's. Believe it or not, I bought some WE 310a's and the stock tubes were better. Other than that, no stock tubes being used.
Joe
Will the 40.1's (should they appear) even work with a SET amp? If not you might want to look at the model Lumina below Mike's. I was looking at it, but he raised all his Lumina prices almost 30% the day we all started talking about Mike's Statements and 40% on them.
Keith,
I absolutely am having a blast. What's your top few SET friendly speakers for fun. I'm curious.
Would something like this help?
If the Melody worked the LM should be plenty at the volumes you play and a good bit above. Glad they are finally going to show and hope they are worth the wait.
Keith,
Autoformers
Mike,
Boy were you right about this amp.![]()
Yes, you definitely have a thinning of the herd to occur at some point
Which do you prefer between Pass and Hegel amps? I'd really like to hear those amps against my DarTZeel. But if I was going to try another amp, it would most likely be Melody AN845 to have both a tube and ss option.
The one other thing about Black Shadows- they are cheap under todays audiophile standards![]()
I like Sophia 845 amps quite a bit too, but their prices have gone insane. That's why Melody is such value (retubed)
Agreed.
I read a review where the LM-219IA edged out the Melody amp. I forget what model. I think the reason given was the LM was a touch sweeter.
Kev,
Those look awesome! but WAY too big for me.![]()
