David Smolinski
What's the best for speed watching tutorials?
We should get a sense of price and value. If you recommend >1, rank them best to worst and give them points and ideally a price.
example: 10 model a $100, 8 model b $1
gear
What I've heard about ANC
I have
gear
- DAC amp
- ventilating headphones: They keep skin dry and healthy, and provide relief from non-ventilated headphones.
- noise cancellation headphones: If your room is soundproofed, this might be unnecessary. Reduce sound sent to and received from the environment.
- ANC (active noise cancellation)
- PNC (passive noise cancellation)
- It cancels white noise, but not irregular noise.
- It sounds worse.
I have
- FX Audio DAC-X6
- Koss KSC75: Its better than ATH-M50X, worse than 280 PRO. It's open back and vents.
- Sennheiser HD 280 PRO: Ignoring the closed back sound, it sounds the same as Stax SR-5 and better than KSC75, ATH-M50X, and Skull Candy IEMs.
