Berkeley Alpha Reference DAC Break In Period
Odyssey
Austin, TX & Suburban Chicago
To all you Berkeley owners out there: How many hours would you hazard a guess that it takes to break in the Berkeley Reference DAC?
I bought Joe's unopened box (the one that he waited forever to get) and I'm going to be doing a DAC shootout with another contender. Want to make sure that it is a fair fight. Thanks.
Took 2 or 3 months before mine was anything close to fully broken in.
BTW, what do you mean by "independent ground" in your signature?
I'm not a big believer in break in.... If you need any help getting the best out of the BADA reference feel free to PM me...
Best break in for the BADA: send it to me. Wait 6 months. I'll send it back to you. Repeat.
My electrician, who also happens to be a sound engineer, tapped into the top of the main panel, ran a sub-panel just for the 4 dedicated lines to the 2 channel listening room. He then ran an independent ground for the sub-panel and those dedicated lines and measured the resistance to ground afterwards.
You mean it goes to a separate ground rod from your main service ground? If so, are they bonded together?
I don't know if they are bonded together. I do know that he was focused on resistance to ground. I think he back filled the area around the grounding rod(s) with bentonite (sp?) something that is supposed to retain moisture.
Make sure they're bonded together - otherwise there can be a difference in potential between them causing unwanted current flow. My lightning protection electrician (residential,commercial, hospital, military) was quite compulsive about this with my 8 ground rods in my lightning protection system.
