Audio analogue maestr anniversary
Audio Analogue has very limited exposure in this part of the world so unlikely to find many who have heard their current models, but of the two options you have presented this would be my choice. Another Italian integrated you might want to look into are the ones by Audia Flight.
Thx Jack,
so Pulled the trigger Focal sopra 2 and nuvista 600 is coming in. Story to long and to complicated to write down. Lets say out of financial reason. I hope the sopra s Will do Well in my room have only 13 feet between front and back wall. The nuvista I m not sure but if its to bright I change in warmer amp Jack I have Seen in your signature aqua la voce. In my system with sopra would that dac not bring sound to the warmer end?
It is possible the Aqua could help get you in that direction but a lot is going to depend on how the combo of the Focal's and the MF sound together.
Thx Jack, indeed gone listen for a while speakers should nearly be broken in, its a demo pair, amp is brand new. If its to bright I change amp first to something warmer. Just hope sopra 2 Will not have bas boom dont know english word for it cause my room dimensions.
