jdandy
Like a kid waiting for Santa Claus, I was watching out my office window all morning waiting on FedEx to deliver my new APC SMC1000-2U UPS. I walked down and opened the electric gate at 8:00 AM just in case FedEx was super early. Finally I saw the delivery truck come up the drive just before 11:00 AM. Gotta love morning deliveries.
This new APC SMC1000-2U backup power supply replaces an older APC Back-UPS ES 650 that sat on the floor behind my left channel speaker in the living room for 10 years. I had used it as backup power to support my McIntosh MS750 music server, then the Olive 04HD music server, and most recently the Aurender N100H music server. I made the move to the newer UPS because I wanted to take advantage of its pure sine wave output when on battery, and also because I was looking for a UPS that could be installed in my audio rack.
I unboxed the new UPS and discovered that it was not painted, rather it was silver metal on all sides. The only thing black was the removable front face plate. Everything else was bright silver. Not good because I did not want to be looking at a base metal cabinet with stickers on it in my audio rack.
First things first, I peeled off the stickers, removed the rack clips from the side panels, wiped the metal surfaces with isopropyl alcohol, masked
off the front and rear panels, then spray painted the top cover and side panels with Valspar quick dry satin black. Looks much better in black.
Next I discovered that since the UPS is designed primarily for rack mounting it had no feet, nothing to raise it off the shelf for ventilation. Digging around in my shop I found four rubber self sticking feet that I had tucked away and long forgotten. After a bit of measuring for locations I had the feet installed on the bottom of the UPS.
I had to reverse the position of the battery pack that allows it to mate with a quick connect plug in the battery bay, then snap the front face plate on and the UPS was ready for my audio rack.
The APC SMC1000 weighs nearly 40 lbs. so it is a bit of a chore to handle, but it did not take me long to get it installed in the audio rack. I adjusted the shelf heights on the left side of the rack last night to provide a perfectly spaced opening for the UPS. After that it was only minutes to make the power connection to the PS Audio P10 AC regenerator and then plug in the Aurender N100H, NetGear WiFi repeater, and the Sonos zone player to the UPS. I took a minute to cycle through the menu to ensure the various settings were to my requirements and the installation was complete. I like that the LCD display screen when set to Eco-mode goes dark after 60 seconds of no use. I am also pleased that this new UPS allows for the alarm beep to be silenced when on battery.
All together this APC SMC1000-2U is a compact and robust UPS that I expect to get many years of great service from. Battery packs are user replaceable and hot-swappable from the front of the UPS once the front face panel is removed. This can be accomplished without removing the UPS from the rack. The UPS is completely silent. Always a good thing.
