VoicesInMyHead
I would have liked a D2 as well, but I just couldn't bring out the money for it this time as I'm changing my entire system... C2 will have to do, for better or worse...
I've sold more or less all my Diamond cables, decouplers and power distributor products together with some of my other equipment. My original plan was to stick with only the minimal amount of cables I needed for my scaling down project and that I could be flexible about which ones to keep. But then a buyer came and bought everything in a extremely nice package deal (mostly for him), and I figured I could just as well "start over" from the beginning...
Which I of course did... And did I ever have thoughts about trying another brand? Nope! Not even a little? Nope! Feeling very loyal and committed here. While I've been evaluating different amplifiers for a while, I was already clear on that I wanted a new Mainz 8 C2 as foundation to build upon with a just few A2 cables to my new integrated solution. These are all now on order. First one has to sort out clean power and cables, then the actual amplifier decision comes last in the chain, right?
@Mordante hey, buy my Job 250 monos... they're amazing value to a great price!
Are the jobs 110V or 240V? I'm Dutch.
Are you keeping your speakers?I would have liked a D2 as well, but I just couldn't bring out the money for it this time as I'm changing my entire system... C2 will have to do, for better or worse...
As Lars pointed out during his cable/power distribution at Axpona Start with the foundation and you might be very surprised how good the rest of your system really is.For now yes, but I'm planning to look into other options there as well. It's a bit more complicated due to room limitations, and in general it feels like a much bigger thing to change.
I wrestled with the purchase of my Mainz DTC but bought one to replace my Mainz D. I can’t say how much difference it makes because I made other changes at the same time. If I’d known there would be multiple V2 choices I might have passed on the DTC version.Can't wait to hear your impression of the Mainz C2 vs D2. I have yet to hear those. I replaced my MainzD8 with the D-TC when I asked Mike B at a demo if he was going to come out with a less expensive option. His answer was no. I should have known better. But that said my D-TC is going nowhere. I'm amazed the difference in power cord SQ when comparing A2 C2 and D2. So much more than the original A C and D.
i did buy a pair of C2 digital Coax’s to connect a Chord BLU CD transport to a Chord Dave DAC.
While waiting for the BLU2 to arrive (3 months and counting) I compared one of the C2 Coax’s to my Ansuz DTC USB and to my Ansuz DTC Coax. I used the cables between an Aurender N10 and the Dave used as a DAC.
Using both headphones and speakers it was clear to me that both DTC cables were superior to the C2. All the cables were excellent but the DTC’s provided a richer, more organic sound. This was especially apparent with piano. As with most things there is the law of diminishing returns. The $12,500 DTC Coax was better than the $3,600 USB and both better than the $3,000 C2 Coax.
I have the chance to upgrade the C2’s at a good price but I’m going to keep the C2’s since for the application between the BLU2 and the Dave I think they are good enough and better than what just about any BLU2 owner is using.
Bud
I'll admit that my system has never sounded better.Bud when I got my Mainz D-TC to replace the MainzD8 the difference was huge. It was like adding several layers of resolution to everything. I could also play music almost twice as loud which I believe is due to the lower noise floor. I know this sounds crazy but you should hear what a second Mainz D-TC does. I was floored at Axpona. For grins and giggles on the last day I brought mine for a total of 3. I immediately heard a difference but not quite as much as adding the second one.
I heard an improvement when I upgraded C1 and D1 PC’s to DTC PC’s when I had a MainZ D8. I wonder if I would have heard a bigger improvement going to the Mainz DTC if I still had those PC’s,While the Darkz are a nice improvement they are not even close to what the Mainz D-TC brought to the table.
The Darkz D-TC can easily handle 35 kg. The ceramic balls shouldn't make an issue eitherAnyone knows how much weight the Darkz D-TC can handle? 35kg should be ok? If I have two layers with ceramic balls in between, will that make a difference in how much weight it can take?
They come as 3 layers, with 2 layers of ceramics.
I have 4 each under 256 lb speakers, no problem
Only 1 layer of ceramic bearings if you get the adjustable version.
