johndoe21ro
Before Ansuz did anyone use any hi-end AudioQuest cables? I was curios for a comparison.
Welcome to the forum Dave, thank you for joining.
Thank you Mike!Hi Dave - welcome to AS!
Thanks a lot Joe, never had this before from another forums.
Dave, I have a Mainz8 power distributor and 2 TCs in my system, one plugged into the Mainz and the other into the wall outlet that the Mainz in plugged into (dedicated 20A circuit). I've tried the TCs in various places and combination and that's what works best for me. I also have a PS Audio PP5 that I use for powering devices like my PC, LPS, etc. The Mainz has only my preamp and sources plugged in. The combination works fine and I keep the noisiest devices out of the Mainz.3. Is it OK to combine the TC with another conditioners or filters OR ONLY the SparkzTC in use for the whole system?
Thank you in advance.
Regards,
Dave S.
Hi Kiwi, I'm new here & have couple questions regarding Ansuz products. My apologies, maybe some of my questions were asked & discussed earlier by other members.
1. From your reviews, seems that the P grade of Ansuz (interconnect & power cable) are a little bit weak on bass, please comment. I had a chance to compare the P interconnect vs Atlas Mavros, and IMO the Mavros had more weight, punch & dynamic in bass.
2. For the SparkzTC:
- Is it OK to use the TC with another conditioners or filters in the same system? Or I must remove all other conditioners & filters from my system to get the best from the TC?
- Is it OK to use the TC with adapter? My power outlet is UK type but the TC available here is in US plug.
- Since the TC is an active equipment, does it have a life time i.e. maybe only last a year or something. Or theTC last forever without any need to replace the inside components?
Best regards,
Dave S.
Welcome to the forum Dave.
Happy to respond as follows.
1. I think Ansuz P is good for the money but there is no denying that as you move up the Ansuz range you get more detail, greater weight and simply more music.
2. I've not tried the Sparkz TC in other conditioners but I know of some who have tried and reported favorable results.
3. It is not recommended to use mains adapters. You can only lose by doing that. Best to chose a mains pin standard and use it consistently through the whole system.
4. I am not aware of any published lifespan for the product.
Cheers
Ralph
Thank you Ralph for sharing. My whole system is using UK plug also my wall socket, but the TC available from the distributor here is in either US plug or Euro, that's why I have ti use adapter like the one sold by Hi-End Cable, UK. So are you saying that it's better to get the TC w/ UK plug? Please advise. Sorry about my English.
Your English is fine Dave.
I had a foreign posting to Indonesia long back and I'm aware that many residences use a mains AC plug which is the same as Europe so I'm assuming you changed the wall outlet to UK standard? I've had a look online at the adapter offered by Hi-End Cable (UK) and it looks to be of good quality so I think it should be fine for your needs.
