Does anyone have any experience with the Ansuz Mainz?
Hi Guys,
Do you plug your amps into the Mainz D8 and if so, do you find that it limits current/dynamics at all? I own the Audience AR6-TSS and plug all my components into it. It also uses star grounding. I find that it dramatically reduces the noise floor and removes a brightness/edginess from the treble that was previously compromising my system. I am extremely pleased with these results. However, the one drawback is that it seems to have reduced dynamics on my amplifiers to a degree. So I'm wondering if the Mainz D8 would be a good solution for my amps, while keeping the AR6-TSS for my K-01 and 520. Or do you think all my components would just sound better plugged into a Mainz D8? Any thoughts?
Thanks so much!!
Ken
Ken, I've metered the amperage going to the Mainz D8 running the Soulution 520/501's/541 and during normal music passages it draws less than 4 amps. During the most demanding musical passages I've never seen it draw more than 7 amps of power.
You may remember that the Soulution amps have massive capacitance built into them. Here's a quote from the 501 brochure "The high-precision idle current management ensures optimal operating conditions, storage capacitors with 47’000 microfarads allow for a nearly infinite impulse response. Atotal of six power supplies feed each 501 mono-amplifier"
I believe the MainzD8 can accommodate at least 15 amps of continuous draw. When I was back in Chicago auditioning the Soulution 701's mono blocks against the 725, I saw the 701's peak out at 17 amps of draw under the most extreme and demanding musical passages. The 701's at that time were plugged into the back of the Mainz D8 and I didn't sense any compression of dynamics.
If you can find a way to home audition the Mainz you could see if it works for you.
Hi AS,
Probably this is my first post here
I recently got the D8 from local dealer, and i must say it has synergy with my current ansuz power cord loom.
Previously i used small IS torus to feed my sources and pre, and another line to feed my power ( directly to the wall) to feed my raidho D1. With the mainz D8 in place, i dump everything to the box, and i got nothing in my 2nd line at the moment. I would say, i like the synergy compare to my previous setup. Though i kinda feel i may lost the finesse certain tones compare to previous, but it brought up the ansuz characteristics into higher level. I guess if you like ansuz character, this is something that you shouldn't be missed.
Jesse
Singapore
Hi Jesse and welcome to AS.
For sure a very nice place.
My next upgrade will be the D8, but it might takes some months yet.
Can anyone tell me if the D8 use the darkz for footers?
Looks like there is maybe 1 "ring" underneath it.
The best must of course be to put the Diamond darkz under it.
But maybe I for the start can live with just the D8 as it is?
Lars Kristensen and Michael Borresen the founders of Raidho and Ansuz would say that the Mainz D8 is one of their most significant accomplishments.
In one of my systems I use two in series. I demoed this and more impressed with the results of the two together. As Mike points out it dramatically lowers the noise floor. It uses a proprietary star grounding technology.
You can read more of the advantages here:
Mainz A8 / D8 Power Distributor
Hi Le Roy,
How are things coming along with your new Austin system? Have you started the break-in process for the 520 and the D3's?
Best,
Ken
