A 2 Channel Stereo System For Our 5th Wheel Camper
Southeast Iowa
The camper came with a junk Furrion system with both indoor and outdoor speakers. We really only need indoor speakers. Recommend a 2 channel stereo system for our 42' 5th wheel camper. There are several usb plug ins. It has WiFi. A streaming system would likely be best. It could be wired or wireless. I'm thinking something like a Sonos system for < $1000? Do they have a decent rep? Any other recommendations in that price range?
Take a look at the Bluesound Powered Node. It has streaming via the Bluesound app and compatible with their other speakers if you evr expand. IMO, this would be better than Sonos. If not familiar Bluesound and NAD are under the same umbrella. You could play separate music inside & out, or, have same music everywhere. You could have main unit where it goes and a wireless Bluesound speaker in any other room.
Arcam integrated amps have built-in streaming but wouldn't have the expandable/compatibility with other speakers and such. However, if certain not to expand they do sound decent.
