Thread: WTB EML or KR Audio tubes
August 22, 2016, 11:18 AM #251
- Sep 2014
- 766
Re: WTB EML or KR Audio tubes
I mentioned it in follow up posts. They are the horns fp-15. See links in above posts for reviews.
They are wave guide, boxed horns, a bit like audio note AN-E looks. Lampi GM 70 amps. Expensive verictum cabling and Gigawatt filter. All polish, actually, except for the tubes
August 22, 2016, 11:36 AM #252
What was the source? audio pc, streamer, cd-player?
One month ago I wanted to get the 242 really bad, now I want to get the px4.
Maybe I wait another month....
August 22, 2016, 11:51 AM #253
Kris,
See the FB link I posted. I think they used a Lampi SB Transport...
Greg did a very extensive write up on FB.NORMAN
August 22, 2016, 02:08 PM #254
- Sep 2014
- 766
August 27, 2016, 12:29 PM #255
- Apr 2016
- 139
Can someone explain in which tube the internals 'do not touch the glass'? Lukasz says the 101d's and the Lampi Anniversary tubes fall into that category. I was wondering if any of the other KR output tubes have that distinction?
August 27, 2016, 02:14 PM #256
AFAIK, only the EML anniversary globe 45 solid plate and the EML Lampi Mesh anniversary 45 globe fit that description. Never heard the 101d described that way...
NORMAN
September 4, 2016, 05:20 PM #257
- Sep 2014
- 766
I think today I heard the special Lampi 45s, the px4, the px25, Elrog 300b, original WE 101d, original WE 104 in another system. Will write a report tomorrow in case anyone's interested
September 4, 2016, 05:21 PM #258
September 4, 2016, 05:22 PM #259
- Sep 2014
- 766
September 4, 2016, 05:23 PM #260
My money is on PX4's!!!
September 4, 2016, 05:24 PM #261
- Sep 2014
- 766
September 5, 2016, 01:57 AM #262
- Sep 2014
- 766
The choice between PX4/25 is clearly a gain play. The PX4s seem to be the best and safest choice for those who are buying blind. They do everything. Great for rock, classical, vocals, cello. They place the choir back behind the speakers wide across the room like it should be. Greg's DIY horns and Yamamoto are very high gain. The PX25 initially had a superb grip on the piano and the cello in Beethoven's cello sonata. On other tracks we were getting too much hardness so Greg reduced his preamp gain by inserting tubes 3db lower. Then the difference between PX25 and the PX4 dropped. So, in other words, please don't read here for advice on whether to buy 4 or 25. If you can't hear both, buy 4.
The Special EML Lampi Globe anniversary 45 did some things better...but only if you were critically listening, and had to write a review, and pick one of the two. Otherwise, they are so close, if you have one and don't want to spend on the other, don't. You are not losing out on any quality or drastic presentation differences that might suit your preferences. The 45 did highlight some of the individual instruments in large orchestral passages better.
In Greg's system the EML mesh 5u4g recti worked the best with all these tubes. It gave a slight air, and timing pause, while the special KR 5u4g sounded too aggressive and rushed. But then in some systems, the EML sounds too laid back. I would still take the KR as the safer bet and if it sounds too rushed, switch to EML. EML has more air.
The Elrogs do their own 300b magic but I don't seem to be a 300b fan. None has worked on me. I think if one has to spend on one output tube, it should be the PX4 or the special 45 depending on your budget and the 45 availability. Greg is in agreement like with last fortnight's rolling group. Bill's system will be worth confirming this in as it is a very different system - SS, big cone speakers.
The 101d and 104 were not used in months and were taken out cold. Both have a warm, embracing feel, but more laid back and less dynamic than the modern valves. The 104 is more dynamic than the 101. What they had over the modern ones was a pause and time interval in the music, making the modern ones appear more rushed. They had a more traditional tubey sound.
September 5, 2016, 07:22 AM #263
October 14, 2016, 11:22 AM #264
- Sep 2014
- 766
Selling my Elrog 300b pair for 700 Euro, which is what I bought it for, if anyone wants to buy. Postage additional. Hardly used except to test (I don't have speakers right now anyway). Bought it off Khonfused who hardly played it either, and it still has warranty till Dec. Barely 100 hours, I guess, and playing fine. Selling because I just received my special Lampi 45s, and already have a PX4 on order, also have a 242. Best 300bs I have heard, better than KR 300b. I haven't heard the original WEs so let's leave those out
October 15, 2016, 11:19 AM #265
- Sep 2014
- 766
So we heard at Bill's, with SS analog domain integrated and focal Maestro utopias, a different set up from the high efficiency horn loaded SET set ups we had compared the valves on.
The px25 and px4 were nearly equal, with px25 having a bit larger soundstage and leading edge that when compared gave the px25 the edge, but without comparison would have kept anyone happy.
The special Lampi 45s were tonally the best and my choice for most music except that they had less details on tuttis compared to the others. The PXs are also superb on cellos, but the 45 really stand out on all other instruments. These were brand new and not broken in
The baritone vocal was the best on the 45, while Sullaria was better on the px25.
101d replicas were still the most dynamic and cleanest, but tonally the least equal. The others also had a deeper soundstage, but on piano and solo, the notes really slammed and leapt out with the 101ds.
Both of us found that both 300bs, KR and Elrog, were not to our tastes. These are excellent 300 bs however.
All compares were done with KR 5u4g which turned out to be the best all round recti, with KR 274b giving the bit more required edge on special 45s. The EML was relatively too laid back and slow, though on other systems it did give a bit of air due to the mesh plate.
Oh yes, and like an idiot, I forgot to take the 242, but both of us are quite sure if it doesn't distort or sound too hard, it will win easily. I will post it to Bill next week.
November 6, 2016, 11:04 AM #266
- Sep 2016
- 25
Hi Ked
Did you manage to send your KR 242 to Bill in the meantime?
Would be curious to hear about the differences between the KR 242 and the EML Lampi 45 mesh anniversary tubes and the PX4...
November 6, 2016, 11:22 AM #267
- Sep 2014
- 766
I keep forgetting. But if they don't distort, they will be better
November 6, 2016, 11:24 AM #268
- Sep 2016
- 25
The only way to find out is to actually stick them in and try, then?
November 23, 2018, 04:42 PM #269
- Mar 2016
- Minnetonka, MN
- 59
What a fascinating thread for the tube roller. I am interested in any impressions of the Tak recti with the PX4s. Has anyone tried this combo in a Golden Gate? Also, any more impressions of the PX25 vs the PX4? I'm trying to determine what to go for as a starter set for a GG.
November 23, 2018, 04:46 PM #270
- Sep 2014
- 766
PX25 had almost always been better than both PX4 and RK PX4 except in very rare cases where the gain has been too much for the PX25
November 24, 2018, 05:48 AM #271LS: Vienna Acoustics Klimt "The Music"
PowerAmp: Nagra VPA
PreAmp: Tobian Soundsystems SC12
DAC: LampizatOr Horizon
Server: LDMS Maximus Music Server
CDT: CH Precison D1
Switch: Edison Creation Silent OCXO Extreme, FiberBox
Power: LampizatOr Kraftwerk 10
Cabling: Signal Projects loom
November 24, 2018, 11:00 AM #272
Really? Has anyone here heard the RK PX4?
NORMAN
November 24, 2018, 11:03 AM #273
- Sep 2014
- 766
November 24, 2018, 11:20 AM #274
Excellent. That was not clear before.
NORMAN
December 23, 2018, 12:11 PM #275
New kid on the block
PowerAmp: Nagra VPA
CDT: CH Precison D1
January 29, 2019, 12:42 PM #276
- Mar 2016
- Minnetonka, MN
- 59
Selling my KR PX4 and KR 300B RK (Less than 1 month old). Please PM me if interested.
January 30, 2019, 02:24 AM #277
Adam, are you in EU or USA?
Aurender W20->Lampizator Pacific SE/Audio Aero La Fontaine->Ayon Crossfire III or Circle Labs A100-> Avantgarde Acoustic Trio LE 26, 4x REL Carbon Special Subwoofers
Analog : Fat Bob S with SME 5, Shelter Harmony, Tom Evans Groove+ SRX mk2, Muarah PSC with InteliClamp
cabling: Duelund DCA 16GA, Acrolink, Vovox, Siltech, Transparent, Audio Phase , NxLT The Flame, FTA Callisto and Sinope usb, Fadel Art , Argentum , REL Bassline Blue
HT : Sony HW 50 ES, Oppo 93 EU, Darbee DVP-5000 ,Yamaha Aventage RX-A 3010 , B&W 9.1, screen 120 inches matt white
January 30, 2019, 06:13 AM #278
Marslo, he is in the US.
NORMAN
January 30, 2019, 06:24 AM #279Aurender W20->Lampizator Pacific SE/Audio Aero La Fontaine->Ayon Crossfire III or Circle Labs A100-> Avantgarde Acoustic Trio LE 26, 4x REL Carbon Special Subwoofers
January 30, 2019, 07:21 AM #280
What were you looking for? 300b or px4?
NORMAN
January 30, 2019, 07:29 AM #281
Rather PX4 as I cannot get PX 25 from best300b.
January 30, 2019, 07:36 AM #282
Lukasz does not have more PX25? There are rumours of a RK PX25 later this year!
remind me again which tubes you already have, please.NORMAN
January 30, 2019, 08:27 AM #283LS: Vienna Acoustics Klimt "The Music"
PowerAmp: Nagra VPA
CDT: CH Precison D1
January 30, 2019, 08:37 AM #284
Heheh!
NORMAN
January 30, 2019, 09:39 AM #285
- Mar 2016
- Minnetonka, MN
- 59
Hi fellas. I'm in the US. Minneapolis, to be precise.
March 24, 2019, 01:36 AM #286
- Feb 2015
- 8
Hi Gents.
I have a nice combo up for sale.Kr 5u4g lampizator anniversary edition and a pair of Kr 242's
Make me an offer!
July 4, 2019, 03:17 PM #287
- Mar 2016
- Minnetonka, MN
- 59
Anyone have a pair of KR PX25 RK they're looking to unload? Please let me know.
July 4, 2019, 04:41 PM #288
PowerAmp: Nagra VPA
CDT: CH Precison D1
July 4, 2019, 04:54 PM #289
- Mar 2016
- Minnetonka, MN
- 59
They are not available on best300b.com. Not even listed, however, a buddy purchased a pair from there a month or so ago. Just hoping it isn't working out in someone's system and they'd like to move it.
July 4, 2019, 04:58 PM #290
PowerAmp: Nagra VPA
CDT: CH Precison D1
July 4, 2019, 06:37 PM #291
- Mar 2016
- Minnetonka, MN
- 59
My friend had sent in his newly purchased, used, GG for updates and got them directly from Lukasz. It seems they are only available directly from Lampi for now.
I think Magico is set to retire the S7 design and put it in it's rightful place in the pantheon of other great past successes.
Magico S5 mk3
