Page 6 of 6 FirstFirst ... 23456
Results 251 to 291 of 291
  1. #251
    Re: WTB EML or KR Audio tubes
    Quote Originally Posted by khonfused View Post
    Hi Ked,
    what does the rest of the system consists of?
    I think at this point it's important to consider system synergy as you've done this comparison with horn speakers.
    I mentioned it in follow up posts. They are the horns fp-15. See links in above posts for reviews.
    They are wave guide, boxed horns, a bit like audio note AN-E looks. Lampi GM 70 amps. Expensive verictum cabling and Gigawatt filter. All polish, actually, except for the tubes
  2. #252
    What was the source? audio pc, streamer, cd-player?
    One month ago I wanted to get the 242 really bad, now I want to get the px4.
    Maybe I wait another month....
  3. #253
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Kris,
    See the FB link I posted. I think they used a Lampi SB Transport...
    Greg did a very extensive write up on FB.
    NORMAN
  4. #254
    I think 242 seldom works in a GG. Big 7, it is superb. Yes we did PCM streamed through an old Lampi Transport
  5. #255
    Senior Member
    Join Date
    Apr 2016
    Posts
    139
    Can someone explain in which tube the internals 'do not touch the glass'? Lukasz says the 101d's and the Lampi Anniversary tubes fall into that category. I was wondering if any of the other KR output tubes have that distinction?
  6. #256
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    AFAIK, only the EML anniversary globe 45 solid plate and the EML Lampi Mesh anniversary 45 globe fit that description. Never heard the 101d described that way...
    NORMAN
  7. #257
    I think today I heard the special Lampi 45s, the px4, the px25, Elrog 300b, original WE 101d, original WE 104 in another system. Will write a report tomorrow in case anyone's interested
  8. #258
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    Quote Originally Posted by bonzo View Post
    VERY interested!!!!
  9. #259
    VERY interested!!!!
    Lol
  10. #260
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    My money is on PX4's!!!
  11. #261
    Maybe you can run a spread bet till tomorrow
  12. #262
    The choice between PX4/25 is clearly a gain play. The PX4s seem to be the best and safest choice for those who are buying blind. They do everything. Great for rock, classical, vocals, cello. They place the choir back behind the speakers wide across the room like it should be. Greg's DIY horns and Yamamoto are very high gain. The PX25 initially had a superb grip on the piano and the cello in Beethoven's cello sonata. On other tracks we were getting too much hardness so Greg reduced his preamp gain by inserting tubes 3db lower. Then the difference between PX25 and the PX4 dropped. So, in other words, please don't read here for advice on whether to buy 4 or 25. If you can't hear both, buy 4.
    The Special EML Lampi Globe anniversary 45 did some things better...but only if you were critically listening, and had to write a review, and pick one of the two. Otherwise, they are so close, if you have one and don't want to spend on the other, don't. You are not losing out on any quality or drastic presentation differences that might suit your preferences. The 45 did highlight some of the individual instruments in large orchestral passages better.
    In Greg's system the EML mesh 5u4g recti worked the best with all these tubes. It gave a slight air, and timing pause, while the special KR 5u4g sounded too aggressive and rushed. But then in some systems, the EML sounds too laid back. I would still take the KR as the safer bet and if it sounds too rushed, switch to EML. EML has more air.
    The Elrogs do their own 300b magic but I don't seem to be a 300b fan. None has worked on me. I think if one has to spend on one output tube, it should be the PX4 or the special 45 depending on your budget and the 45 availability. Greg is in agreement like with last fortnight's rolling group. Bill's system will be worth confirming this in as it is a very different system - SS, big cone speakers.
    The 101d and 104 were not used in months and were taken out cold. Both have a warm, embracing feel, but more laid back and less dynamic than the modern valves. The 104 is more dynamic than the 101. What they had over the modern ones was a pause and time interval in the music, making the modern ones appear more rushed. They had a more traditional tubey sound.
  13. #263
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,086
    Thanks for the write up. The PX4 seems to be the best all around choice, would you agree?
    I've got a bunch of PX4's on order for customers (and a couple for myself).
  14. #264
    Selling my Elrog 300b pair for 700 Euro, which is what I bought it for, if anyone wants to buy. Postage additional. Hardly used except to test (I don't have speakers right now anyway). Bought it off Khonfused who hardly played it either, and it still has warranty till Dec. Barely 100 hours, I guess, and playing fine. Selling because I just received my special Lampi 45s, and already have a PX4 on order, also have a 242. Best 300bs I have heard, better than KR 300b. I haven't heard the original WEs so let's leave those out
  15. #265
    So we heard at Bill's, with SS analog domain integrated and focal Maestro utopias, a different set up from the high efficiency horn loaded SET set ups we had compared the valves on.
    The px25 and px4 were nearly equal, with px25 having a bit larger soundstage and leading edge that when compared gave the px25 the edge, but without comparison would have kept anyone happy.
    The special Lampi 45s were tonally the best and my choice for most music except that they had less details on tuttis compared to the others. The PXs are also superb on cellos, but the 45 really stand out on all other instruments. These were brand new and not broken in
    The baritone vocal was the best on the 45, while Sullaria was better on the px25.
    101d replicas were still the most dynamic and cleanest, but tonally the least equal. The others also had a deeper soundstage, but on piano and solo, the notes really slammed and leapt out with the 101ds.
    Both of us found that both 300bs, KR and Elrog, were not to our tastes. These are excellent 300 bs however.
    All compares were done with KR 5u4g which turned out to be the best all round recti, with KR 274b giving the bit more required edge on special 45s. The EML was relatively too laid back and slow, though on other systems it did give a bit of air due to the mesh plate.
    Oh yes, and like an idiot, I forgot to take the 242, but both of us are quite sure if it doesn't distort or sound too hard, it will win easily. I will post it to Bill next week.
  16. #266
    Hi Ked
    Did you manage to send your KR 242 to Bill in the meantime?
    Would be curious to hear about the differences between the KR 242 and the EML Lampi 45 mesh anniversary tubes and the PX4...
  17. #267
    I keep forgetting. But if they don't distort, they will be better
  18. #268
    The only way to find out is to actually stick them in and try, then?
  19. #269
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    What a fascinating thread for the tube roller. I am interested in any impressions of the Tak recti with the PX4s. Has anyone tried this combo in a Golden Gate? Also, any more impressions of the PX25 vs the PX4? I'm trying to determine what to go for as a starter set for a GG.
  20. #270
    PX25 had almost always been better than both PX4 and RK PX4 except in very rare cases where the gain has been too much for the PX25
  21. #271
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    Agreed! Full stop!
    LS: Vienna Acoustics Klimt "The Music"
    PowerAmp: Nagra VPA
    PreAmp: Tobian Soundsystems SC12
    DAC: LampizatOr Horizon
    Server: LDMS Maximus Music Server
    CDT: CH Precison D1
    Switch: Edison Creation Silent OCXO Extreme, FiberBox
    Power: LampizatOr Kraftwerk 10
    Cabling: Signal Projects loom
  22. #272
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Really? Has anyone here heard the RK PX4?
    NORMAN
  23. #273
    Quote Originally Posted by wisnon View Post
    Yes, both Greg and I liked it, better than regular PX4, but we preferred PX25
  24. #274
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Excellent. That was not clear before.
    NORMAN
  25. #275
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    New kid on the block
    PowerAmp: Nagra VPA
    CDT: CH Precison D1
  26. #276
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    Selling my KR PX4 and KR 300B RK (Less than 1 month old). Please PM me if interested.
  27. #277
    Senior Member
    Join Date
    Nov 2015
    Poland
    Posts
    212
    Adam, are you in EU or USA?
    Aurender W20->Lampizator Pacific SE/Audio Aero La Fontaine->Ayon Crossfire III or Circle Labs A100-> Avantgarde Acoustic Trio LE 26, 4x REL Carbon Special Subwoofers
    Analog : Fat Bob S with SME 5, Shelter Harmony, Tom Evans Groove+ SRX mk2, Muarah PSC with InteliClamp
    cabling: Duelund DCA 16GA, Acrolink, Vovox, Siltech, Transparent, Audio Phase , NxLT The Flame, FTA Callisto and Sinope usb, Fadel Art , Argentum , REL Bassline Blue
    HT : Sony HW 50 ES, Oppo 93 EU, Darbee DVP-5000 ,Yamaha Aventage RX-A 3010 , B&W 9.1, screen 120 inches matt white
  28. #278
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Marslo, he is in the US.
    NORMAN
  29. #279
    Senior Member
    Join Date
    Nov 2015
    Poland
    Posts
    212
    Thank you Norman, not for me then
  30. #280
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    What were you looking for? 300b or px4?
    NORMAN
  31. #281
    Senior Member
    Join Date
    Nov 2015
    Poland
    Posts
    212
    Rather PX4 as I cannot get PX 25 from best300b.
  32. #282
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Lukasz does not have more PX25? There are rumours of a RK PX25 later this year!
    remind me again which tubes you already have, please.
    NORMAN
  33. #283
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    We killed the stock of PX25s Norm :-)
    PowerAmp: Nagra VPA
    CDT: CH Precison D1
  34. #284
    Senior Member
    Join Date
    Aug 2013
    Genf
    Posts
    3,647
    Heheh!
    NORMAN
  35. #285
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    Hi fellas. I'm in the US. Minneapolis, to be precise.
  36. #286
    Hi Gents.
    I have a nice combo up for sale.Kr 5u4g lampizator anniversary edition and a pair of Kr 242's
    Make me an offer!
  37. #287
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    Anyone have a pair of KR PX25 RK they're looking to unload? Please let me know.
  38. #288
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    Quote Originally Posted by adamaley View Post
    I would assume to early for that as they just introduced them in RK version..but hope you’ll get them..
    PowerAmp: Nagra VPA
    CDT: CH Precison D1
  39. #289
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    They are not available on best300b.com. Not even listed, however, a buddy purchased a pair from there a month or so ago. Just hoping it isn't working out in someone's system and they'd like to move it.
  40. #290
    Senior Member
    Join Date
    Jan 2017
    Lausanne, CH
    Posts
    282
    I also didn’t see them there but i know Chris got them with his Pacific...
    PowerAmp: Nagra VPA
    CDT: CH Precison D1
  41. #291
    Join Date
    Mar 2016
    Minnetonka, MN
    Posts
    59
    My friend had sent in his newly purchased, used, GG for updates and got them directly from Lukasz. It seems they are only available directly from Lampi for now.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
