Results 1 to 17 of 17
May 17, 2016, 08:13 PM #1
Is anyone here into re-veneering cabinets?
A few years back I found myself actively seeking out speaker projects (used speakers) to re-veneer and sell. Most all of them turned out nicely.
Just wondering if any of you guys have done anything similar with woodworking other than a few of the AS members that are speaker manufacturers?Avanti Audio
May 17, 2016, 09:22 PM #2
Re: Is anyone here into re-veneering cabinets?
Mike I have built a few speakers in my day and used veneer. Please post some pictures of your projects.
Marty
MSB Premier
PS Audio Powerplant 15
May 17, 2016, 10:34 PM #3
Cool Marty, please post some pics of yours too.
Here's a pretty rough AR3a restoration with new Mahogany veneer. Some that care would gasp at not restoring the original veneer and/or not using walnut, but I had sheets of Mahogany on hand so...
BEFORE:
AFTER:
Still can't pretty up the face....
Avanti Audio
May 17, 2016, 10:40 PM #4
JBL L-96 that had good surfaces except for the tops that the previous owner decided to use as plant stands I guess.
BEFORE: (and after some sanding on my part to feather the existing veneer "hole" created by years of water damage)
AFTER:
Avanti Audio
May 17, 2016, 10:43 PM #5
Here's a JBL L-100 restoration that required no veneer, just sanding and oil refinishing:
BEFORE:
AFTER:
Avanti Audio
May 17, 2016, 10:45 PM #6
I don't have before pictures of these Rogers LS2's, but they started life as a black ash pair that were beat badly...
AFTER:
Avanti Audio
May 18, 2016, 06:10 AM #7
Mike you do excellent work. I will see if I can find some of my old pictures.
Marty
MSB Premier
May 18, 2016, 10:47 AM #8
I've only veneered a couple items so far, but have a few more projects lined up.
Here is a turntable that was a NAD 533(Rega) at one point, but then received a 3" baltic birch plinth along with a myriad of upgrades(platter, arm, cart, motor, belt, cables, etc...) and mahogany veneer.
Here is one Tannoy HPD385A cabinet I built and veneered with red oak veneer. I'll attempt to look for more completed images with the crossover control cover, ports, and driver loaded. They have recently been turned into sealed subwoofer cabinets though.
I've also worked with solid wood a few times in the last few years.
These were built with 5/4 Sapele(Italian Mahogany) frames. They are still unsealed at the moment, I will be applying Waterlox to them as soon as my hernia is completely healed.
And here are a small pair of speakers I designed. They have a floating Sapele baffle with a baltic birch enclosure and were a gift to my brother and his wife.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
2 Channel: Wyred 4 Sound STP-SE, Wyred 4 Sound DAC-2, Manley Mahi Monoblocks, DIY SEOS Waveguide/Dipole Bass Towers
HT: Marantz AV7005, Wyred 4 MMC5, DIY SEOS Towers, DIY 7CF Sealed 18" Subs
PC: Wyred 4 Sound mINT, KEF Q100, Hifiman HE-6
May 18, 2016, 06:10 PM #9Avanti Audio
May 18, 2016, 06:11 PM #10
Great work, Face. Looks like some very cool custom pieces you've crafted!
Avanti Audio
May 18, 2016, 06:13 PM #11
Well done Mike (Face)! Awesome work.
May 19, 2016, 07:08 AM #12
Mike - very nice work! Love the speakers you designed - open baffle horns?
May 19, 2016, 12:38 PM #13
May 19, 2016, 01:22 PM #14
February 19, 2023, 12:15 AM #15
- Mar 2016
- Minnetonka, MN
- 59
Bringing this thread back to life after so many years dormant. I'm looking for a speaker cabinet builder for an Altec VOTT 817 build. If anyone can remotely point me towards someone who has this kind of expertise, I'll be grateful.
February 19, 2023, 12:51 PM #16
- Nov 2014
- 2,104
Do you already have the cabinets? If so, have you looked into or considered wrapping? There are tons of color options and finishes available and it would be lots cheaper! You can take your speakers to any place where they do car wrapping and have them do it for you. I wrapped my amps and changed them from silver to matte black.
February 19, 2023, 02:51 PM #17
So nice when you see the grain wrap around corners. Very nice.
Synology 1019D+ - SGC Sonictransporter I9 w Roon/HQ Player- UltraRendu- PBD Stream IF to Playback Designs MPS5 via fiber optic - ARC 40th Anniversary Pre - ARC 610 T's - Martin Logan CLX's - 4 Martin Logan Depth i Subs - Shunyata Hydra, DIY PCOCC interconnects, speaker cables and power cords with Furutech terminations. Blue Jeans CAT 6's. Acoustically treated room with one permanent chair.
Clarisys Arrives at Puur...
