Results 1 to 17 of 17
Thread: ModWright LS 36.5
April 11, 2016, 11:32 AM #1
ModWright LS 36.5
After spending the past couple of years with the ModWright LS100 in my system, I have decided to give the LS 36.5 a demo. Immediate impressions are very positive - a dead quiet noise floor and I like that I don't have to have it turned on to use the HT Bypass. It also has a lower output impedance which I believe matches better with my MC501s. I will miss the terrific phono stage and to a lesser extent the headphone amp in the LS100, but overall the LS 36.5 is a better sounding unit and better fit for my system. Pictures and more listening impressions to come...
McIntosh MC501s, XRT29s, XR27, WS350s
ModWright LS 300 preamplifier
ModWright PH 9.0XT phono stage
Oppo UDP-205 with ModWright Signature Truth Tube Modifications
Cambridge Audio CXNv2 with ModWright Truth Tube Modifications
Clearaudio Performance SE TT with Hana ML MC cartridge
Outlaw 7000x HT Amplifier
Denon AVR-X4700H HT Receiver (pre-amp mode)
JL Audio F113 subs with CR-1 Crossover
ASC & RealTraps Panels; APS PurePower 2000; Daedalus Audio DiDs
WyWires, LAT International, Wireworld Cables
April 11, 2016, 11:34 AM #2
Re: ModWright LS 36.5
Nice looking unit!
Glad you're happy. I am eyeing his phonostage.My Systems: http://www.audioshark.org/showthread...481#post158481
April 11, 2016, 11:40 AM #3
Thanks Mike! The two preamps are surprisingly very different sounding. Given that my system already leans to the warmer side, I like the fact that the LS 36.5 is more neutral and detailed. I'd love to hear the Dual Mono LS 36.5 in my system sometime, but would have to do a complete rack reconfiguration to accomplish that. I still might at some point.
The PH150 just received a very positive review in the latest issue of TAS. I'd like to see you give it an evaluation and find out your feedback!McIntosh MC501s, XRT29s, XR27, WS350s
April 11, 2016, 11:46 AM #4
April 11, 2016, 11:55 AM #5
May 14, 2016, 09:18 PM #6
- Sep 2015
- UK
- 55
I also went from the LS100 to a 36.5. Both are superb preamps but the LS36.5 is is clearly superior. I have also had the DM at home for review when it launched in the UK along with the KWA150SE power amp. My thoughts HERE
Preamp: Aesthetix Calypso Signature
Power Amp: Aesthetix Atlas Signature
DAC/CDP: Aesthetix Romulus Signature
Phono: Aesthetix Rhea Signature
TT: Kuzma Stabi Ref 2, Kuzma 4Point 11, Hana ML
TW Acustic Raven One, Raven 10.5, Shelter 5000
Speakers: Acapella High Violin MkIII
January 11, 2017, 11:55 AM #7
I've been with the LS36.5DM for quite a while now jumping to it from ARC LS2B and LS16. It made quite a big leap forward in all sonic terms comparing to those two mentioned preamps. Also I've been playing a bit with rectifier tubes and the best results I got when inserting NOS Mullard GZ34 instead of stock Sovtek.
April 20, 2017, 08:53 PM #8
I've been using an LS36.5DM for many years as well.
May 6, 2017, 03:29 PM #9
yes I had the 36.5 for about a year and a half . beautifully built . in the last 6 months been using the 2 box dm . it sounds just as good rca or xlr to my ears . I like the support and back up that modwright give . it has a lovely midrange .
May 9, 2017, 08:26 AM #10
LS: Vienna Acoustics Klimt "The Music"
PowerAmp: Nagra VPA
PreAmp: Tobian Soundsystems SC12
DAC: LampizatOr Horizon
Server: LDMS Maximus Music Server
CDT: CH Precison D1
Switch: Edison Creation Silent OCXO Extreme, FiberBox
Power: LampizatOr Kraftwerk 10
Cabling: Signal Projects loom
May 9, 2017, 09:04 AM #11
would that be dan ?
I must try that tube swap with some mullards one day1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
May 9, 2017, 09:16 AM #12
PowerAmp: Nagra VPA
CDT: CH Precison D1
May 9, 2017, 10:01 AM #13My Systems: http://www.audioshark.org/showthread...481#post158481
May 9, 2017, 10:20 AM #14
I had Mullards (believe it said Amperex - still have them) made in Holland. Using Create Audio Synergy HiFi 5AR4s for quite a bit and like them.
May 13, 2017, 10:05 AM #15
my dm 36.5 been out of action for a few weeks and been trying various products . last couple of days its been back . its singing beautifully , the texture and delicacy of this pre is delightful. playing max richter the blue notebooks sounds so natural
https://youtu.be/Nfy2fs01ZkI
so pleased to have it back . the grandinote proemio may have deeper bass that this dm but the dm is so balanced and controlled and organic its more than a match for the proemio1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
July 19, 2017, 06:33 PM #16
- Jul 2017
- 54
I've owned an LS 36.5 DM for some time now. There is no other preamplifier I would rather own (However, I do wish it had 2 more balanced inputs). Anyone that says a preamplifier is not significant to a systems sound quality has never heard one of Dan's preamps!
It really responds well to tube rolling in the 6DJ8/6922 slots. I've settle on a strong pair of bugle boys that really augment my current system perfectly. I have a nice pair of Mullard DD GZ34 rectifiers that work perfectly in the power supply but I'm trying to save them as they are getting very pricy. I'm probably being over cautious because I have never worn out a Mullard GZ34! Instead I use a pair of RCA 5AS4A tubes which I have found to be exceptionally good rectifiers. Don't tell anyone though as it will just make their price go up...
July 20, 2017, 02:33 PM #17
mmm I must remember that , I am afraid to fiddle in case I mess up the warrenty , and its sounding fabulous anyway
