Results 1 to 31 of 31
Thread: Amp for Sopra no2
April 9, 2016, 07:02 PM #1
- Apr 2016
- 19
Amp for Sopra no2
Hey guys what amp do you guys recommend for the Sopra no2? Currently using a Rotel class D amp rated at 100 watts 8ohm and 200 watts 4ohm. Do you think this is good enough for now and I can upgrade amps later.
I was looking at the Wadia a315 or the axiom 1250, all input is greatly appreciated.
April 9, 2016, 07:04 PM #2
Re: Amp for Sopra no2
Welcome!
Budget?
April 9, 2016, 07:24 PM #3
- Apr 2016
- 19
I replied twice but neither one worked I hope I am not doing something wrong.
Thanks I am very glad I found this forum.
I would like to stay under 3 grand but the cheaper the better. I don't mind going used but I have no clue what to look for.
Thanks
April 9, 2016, 07:29 PM #4
- May 2013
- 3,243
I know this is Mike's territory, but you might want to take a look at this Odyssey Kismet on Audio Circle. I have one of the exact same amps. Unusually low price seems to be a the result of a small ding on the right rear corner of the chassis case which you would have to walk right up to to see. If it bothers you I'm sure Klaus would sell you another chassis cover, but I would just touch it up and play on.
http://www.audiocircle.com/index.php?topic=141762.0Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
April 9, 2016, 07:29 PM #5
Welcome to the forum, we are glad you found us too.
April 9, 2016, 07:40 PM #6
- Apr 2016
- 19
April 9, 2016, 07:41 PM #7
Amp for Sopra no2
MicroMega M1?? Or maybe a devialet 120 if you can stretch the budget a little. I've never heard the micromega but have extensive use of devialet/focal and it's very good.
Sent from my iPhone using TapatalkSpeakers - Magico S5mk2 Integrated - Vitus SIA-025 Analog - Vpi Prime Signature/Ortofon Cadenza Bronze Digital - Lumin A1
Power - Shunyata Denali 6000S/Alpha HC/Alpha Digital Cables - Kimber KS-6063/Nordost Frey IC
April 9, 2016, 07:48 PM #8
- May 2013
- 3,243
The Kismet is 160 wpc at 8 ohms for the stereo version. Easily pushed the 83 db Vandersteen Treo.
April 9, 2016, 07:51 PM #9
Any of the Odyssey's will drive the Sopra's with ease @ 91db. Ever thought about tubes??
April 9, 2016, 08:08 PM #10
MicroMega M1 is what I would recommend. I've heard the combo. It's wonderful.
It would replace your preamp, DAC, etc. as well.
April 9, 2016, 08:16 PM #11
Amp for Sopra no2
How big is your room? If it's not too big, Pass XA30.5 or INT-30A (integrated) would be wonderful and it'll stay under 3 grands. And don't let that class A 30 watts rating fool you, it has >100 AB watts in reserve.
April 9, 2016, 08:49 PM #12Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
April 9, 2016, 08:55 PM #13
1. Pharaoh Integrated Amplifier
185 WPC/8 ohms 350WPC/4 ohms
- Pure tube mu-follower preamplifier
- Slow-start automated logical turn-on
- Green design with extremely low power consumption
- Standby 6W, 1/2 Power 235W, Full power 435W
- Damping factor > 1000
- Three pairs of line level inputs
- One pair phono inputs, mm/mc with 40/60 dB gain
- One pair balanced XLR inputs
- Adjustable phono loading (custom values available)
- Tube driven 1/4" headphone jack
- Massive high storage linear (!) power supplies
- Mundorf EVO oil coupling caps
- Precision components throughout
- 39 pounds/45 pounds shipping weight
- 18.25" wide x 18" deep (incl. posts and knobs) 6.5" high
- Fully tested, burned-in, and auditioned
- Detachable IEC power cord
- Entirely designed and hand built in the USA
- 3 year limited warranty (6 months on tubes)
2. Union Research Unico Secondo
Output power: 100W RMS on 8ohm 200W RMS su 4ohm
Frequency response: flat @ 10Hz- 0.5dB @ 100kHz
Input impedance: 50kohm // 47pF
Input sensitivity: 375mV
Input stage: Pure A Class. Double tube stage ECC83/12AX7
Output stage: Dynamic A Class double POWER MOSFET complementary pair
Inputs: 5 line unbalanced, (1 phono optional), 1 line balanced
Line Outputs: 1 tape, 1 sub (volume controlled)
Outputs connectors: 4 + 4 bi-wiring
Damping factor: >50 on 8ohm
Feedback factor: 8dB
THD: <0.5% @ 1kHz, 100W su 8ohm
Power consumption: 400W max
Dimensions: 43.5cm x 13cm x 43cm
Weight: 15kgPaul
April 9, 2016, 10:27 PM #14
- Apr 2016
- 19
Hey guys thanks so much for the suggestions very overwhelming. But I think I have narrowed it down to 2 both are way out of my budget.
But first I need something with cinema pass through at least that's what I think it's called. My room is 10 by 12 and half.
I am moving from a pair of Axiom M80s I know big jump so I really want to do this right and not half ass it.
My 3 top choices right now is the Devialet 120, MicroMega M1 and a used Vac Sigma 160i.
I Think I can cross off the Micromega, so my main concern is my room is small and I don't know if the Vac will cause a lot of heat. Plus I worry about Hum. My concern with the Devialet is power I think it should be more than enough but I don't know.
Thanks again for all the input guys.
April 9, 2016, 10:57 PM #15
- May 2013
- 3,243
The VAC is going to put off heat especially in a room that size, whether or not it is a concern depends on where you live and how much tolerance you have for blasting the A/C and the subsequent power bills. At what point did we go from power amp to integrated/all-in-one unit?
April 9, 2016, 11:23 PM #16
- Apr 2016
- 19
April 9, 2016, 11:57 PM #17
- May 2013
- 3,243
What are you trying to accomplish with this system and what other gear are you bringing to the party besides the Rotel. This info will help so that we can tell what you have that is workable and what is not. I for one don't like "all-in-one" solutions that include the digital component as that changes every couple of months and will again soon as the new chips from ESS, AKM, and others that were announced at CES become available for use. If possible keep your front end and your amp separate. If space is an issue there are many more than ever half sized components available.
I am in the Florida Panhandle so we face the same heat challenges. At my house the tube amp goes into the system in November and comes out in April. There is nothing wrong with Class D amps as long as they are good ones with the amps modules mated with a quality buffer board. If you like the sound of the Rotel with the Sopras then just find a higher developed Class D strategy. There are several options available. If you don't like the sound then look in another direction. Like your Sopras my Nola KO's tell you plenty about what is in front of them.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
April 10, 2016, 12:06 AM #18
- Apr 2016
- 19
I have a rsx-1560 and am using an oppo 103. But plan on, Using my desktop for music. I am 50 50 movies and music
April 10, 2016, 12:12 AM #19
Congratulations on choosing a fantastic speaker.
The Sopra No 2 is a gem - give it quality amplification and it will shine.
Focal uses Lavardin amps at a lot of shows. Superb gear.
Don't get fooled by their humble power ratings.
Their integrated models can be found used for $2 to $3k.
If you can wait for something on the used market ...2 Channel Stereo :
April 10, 2016, 12:19 AM #20
- May 2013
- 3,243
Are you just doing 2:1 for both or are there other speakers that need to be taken into consideration. If the later it becomes complicated.
April 10, 2016, 12:25 AM #21
- Apr 2016
- 19
The sopra no2 will be the only speakers powered by the amp my rears and center will be powered by the rotel
April 12, 2016, 04:08 PM #22
https://www.audiogon.com/listings/so...ocust-grove-ga
Just saw this ad and remembered this thread. I can't recommend this amp enough for < $3k range. You can find a ton of reviews on the net. I had this side by side with Bryston 4BSST2 driving Electra 1028 Be a few years ago. Granted 1028 Be are fairly efficient speakers (just like Sopra no.2), but IME, I much preferred XA30.5 and I kept it for 3 years until last year. Do note that 4BSST2 may drive more difficult load better.
April 12, 2016, 04:20 PM #23My Systems: http://www.audioshark.org/showthread...481#post158481
April 12, 2016, 04:32 PM #24
April 12, 2016, 04:49 PM #25My Systems: http://www.audioshark.org/showthread...481#post158481
April 12, 2016, 05:16 PM #26
- Apr 2016
- 19
This decision just keeps getting harder. 5 days ago I was sure I was going Wadia, 2 days ago I was sure I was going Devialet. Today I went all over the map now I am torn between integrated or just pure amp.
I just want to sit down and not worry about do I need more power or, maybe I should of got a DAC. I am starting to drive my wife crazy. Today she said if she hears the word DAC or amp out of my mouth she will cut my manhood off and shove it in my subwoofer. My wife scares me I need to make a decision.
April 12, 2016, 05:26 PM #27
I hope it's a small subwofer. Breath.
April 12, 2016, 05:36 PM #28
lol
Get a sealed sub, so that she can't shove anything in.
If it is integrated, take a look at this one. It's basically XA30.5 amp + a volume control.
https://www.audiogon.com/listings/so...myrna-beach-fl
April 12, 2016, 11:05 PM #29
- Apr 2016
- 19
April 12, 2016, 11:32 PM #30
April 13, 2016, 05:43 AM #31
- Apr 2016
- 19
Ok, thanks very much for the quick response.
