Results 1 to 13 of 13
Thread: DIY Power Cable
March 29, 2016, 03:08 PM #1mauidanGuest
DIY Power Cable
Any recommendations for DIY raw power cable?
Need something in the 10-12 gauge range.
March 29, 2016, 04:38 PM #2
- Feb 2016
- west Michigan
- 713
Re: DIY Power Cable
VH Audio has both the parts and the recipes for decent tested DIY cables. However There are many good deals on used cables right now on several of the Audio selling sites. IMHO you could pick up something for very little that will exceed most of your DIY efforts. (I know because I have made many). FWIW, one persons opinion.
My System
Acoustic Revive RTP-4
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Reference 3A Reflector's
Pr SVS SB3000 Subs
Core Audio Design Rack
March 29, 2016, 05:06 PM #3mauidanGuest
Re: DIY Power Cable
Like you I've made a number of DIY Power Cables.
I just upgraded my AC outlets with the new Furutech NCFs and will be receiving my new custom PLC with NCF outlets and connectors this week, so I want to use Furutech connectors on my powers cables, which I'm not going to find on the used market.
March 29, 2016, 05:45 PM #4
- Feb 2016
- west Michigan
- 713
Re: DIY Power Cable
You might be surprised, but I understand. I made up some PC's with Furutech ends and their nano PC wire. Mine were the 14 ga for the source components. A very nice DIY cable. Have not tried the larger ga Nano wire.
Again, VH Audio has all the connectors, wire ETC that you need.My System
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Pr SVS SB3000 Subs
March 29, 2016, 06:43 PM #5mauidanGuest
March 29, 2016, 06:49 PM #6
- Feb 2016
- west Michigan
- 713
Re: DIY Power Cable
Maybe some of the dealers on this site might be able to provide you with what you are looking for. Perhaps you may want to list the connector and wire numbers that your after.
DaveMy System
Innuos Pulsar
Lampizator BALTIC4
Cary SLP-05
Pass XA30.5 or
Line Magnetic 845ia
Pr SVS SB3000 Subs
October 21, 2016, 10:29 AM #7
- Oct 2015
- FRANCE
- 353
Re: DIY Power Cable
Hi, any pictures, please ?
Marantz SA7S1/GRIMM AUDIO CC1/MARK LEVINSON 360S+TECHNICS SL1210 MKII/ORTOFON X1-MC/VPI CLASSIC 3 in rosewood/Audio-Technica ART-9/ESOTERIC E03+TAG MC LAREN T32R+JEFF ROWLAND CORUS+JEFF ROWLAND MODEL 625+Magnepan 3.7i+Cables line: all Furutech lineflux+power cord DIY
October 25, 2016, 04:12 AM #8
Re: DIY Power Cable
Looks for the Chris VenHaus designs. I made a power cable for my SS amp a little like his design and it is great. It's not exactly the same though: used two solid core double-shielded (my amp is two-pronged for the AC inlet) which are then twisted (the cord is rather stiff).
January 25, 2017, 07:36 AM #9
- Jan 2017
- 16
Re: DIY Power Cable
Hi, I think that power cable is insignificat regarding solution of power supply of the audio components. Every audio component should have internal EMC filters. It depends on its quality not on power cable quality too much.
January 25, 2017, 05:06 PM #10
Re: DIY Power Cable
I've made dozens of home made cables... mostly using Belden 19364 shielded 14 gauge. or, Belden 83803 12 Gauge... also shielded. (This stuff is pretty stiff though)
You can then add whatever "ends" you like, e.g. Hospital grade from Parts Express or the various Furutech and other high end connectors... just a matter of how much $$ you want to spend. I typically use some Techflex just for looks also.
Lots of raw 10/3 power cable available un-shielded also. I make my own primarily so I can do exact lengths. There's dozens of options out there for quality power cables at reasonable costs as mentioned also.Magnepan 20.7 - CJ ART 300s - CJ GATV2 - Meitner MA-1 V2 -Dedicated JRMC + Synology NAS
February 18, 2018, 07:09 PM #11
- May 2017
- Hudson Valley, NY
- 154
Re: DIY Power Cable
I have made cables using DH Labs raw cable. i used the Red Wave for the power amps and Power Plus for the source components. The plugs were Wattage, standard on the Power Plus and gold plated on the Red Wave,
as per their recommendation. All improved the sound; more oomph on all and focus on the power amps.
February 21, 2018, 05:03 PM #12
- Apr 2013
- New York, New York
- 657
Re: DIY Power Cable
I've had great success with Furutech products. I've been using FI-50NCF
connectors. Same as Audience uses on their $5,000 cable.... The quality and selection are second to none..T+A MP3100HV, T+A PA3100HV. Custom made Furutech cables with ETP-609 distributor with NCF outlets, Harbeth 40.2 Anniversaries.
March 14, 2020, 09:27 AM #13
- Feb 2020
- Carlsbad
- 26
Re: DIY Power Cable
Penthouse-D - you better be careful about giving out all of Audience's secrets! I'm guessing all of their $5K cables require "hundreds of hours of break-in". Ha!
hikerneil
McIntosh C2600 Preamp
McIntosh MC452 Amp
Martin Logan Montis Speakers
Sony HAZ Z1ES Music Server
Technics SL-1200G Turntable
Analysis Plus Oval 9 Cables
Personally Made Room Treatments
Spinning various Al Di Meola disks. Just saw him Friday night. He played for over 2 hours. Awesome show and so much energy for someone about to be 69.
