Page 3 of 3 FirstFirst 123
Results 101 to 139 of 139
Thread: Lumin U1
  1. #101
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: Lumin U1
  2. #102
    Senior Member
    Join Date
    Apr 2017
    Central FL
    Posts
    793
    Re: Lumin U1
    Quote Originally Posted by stax View Post
    Ok, the Lumin U1 is working now!
    I ran a 25 foot ethernet cable from another switch in another room to the U1 and it works fine so there is something going on with the switch at my audio rack. Interestingly, before I did that I did put the Lumin U1 in the place of another working device at my audio rack switch (my dac) using it's working ethernet cable and the Lumin was still not working.
    Welcome to the forum. I had my house prewired (including Ethernet) and I have upgraded Ethernet cables going from the router (in my office) and then from the jack in back of my U1. If I move things around (e.g. dust), sometimes the connection to the wall jack will become slightly loose and I get the 'Network Error' message too.
  3. #103
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Hi, wonder if someone can help me with this problem. I brought a chord Dave home for audition. I am unable to stream music with the USB connected to the Dave through my U1. I have tried everything possible including keeping the lumin unsampling off but just can’t get the Dave to play in the DAC mode
    any compatibility issues that I am not aware of or am I doing something incorrectly. Grateful for some help
  4. #104
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Re: Lumin U1
    Quote Originally Posted by Sujay View Post
    Nope. We use that setup in the store all the time. Make sure the DAVE is set to USB input.
  5. #105
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    I did. I cycled a couple of times to ensure it’s on USB. It shows as USB 768khz on the left hand top corner as per display1. But no music. Not sure if there is some setting in the Lumin U1 I am missing.
  6. #106
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Re: Lumin U1
    You shouldn’t be on 768hz unless you have the M-Scaler or Blu2
  7. #107
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Absolutely right! But it displays exactly that. There is no problem when I revert to my original DAC though. Strange!
  8. #108
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    Please power cycle both Lumin and Chord, try different cables, try different ports.
    Peter Lie
    LUMIN Firmware Lead
  9. #109
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Quote Originally Posted by wklie View Post
    Will, do. Thanks!
  10. #110
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Hi,
    I pulled the trigger on the upgraded power supply for my U1. It’s now been about a month and it is fully run in. In short, the upgrade is unbelievable- honest to God I had not idea a power supply upgrade will throw such results. I can clearly hear more information, with a better soundstage which is separated incredibly well. And oh the bass! The delineation of the bass lines is uncanny! Anyway, I will stop here as it’s beginning to get too hyperbolic lest people should wonder whether I am being sincere. But yes, truly special imo.
    i would recommend anyone sitting on the fence to take the plunge. Though expensive, it’s worth it
    cheers
    sujay
  11. #111
    Junior Member
    Join Date
    Sep 2019
    Teshenechi
    Posts
    5
    Re: Lumin U1
    Sujai,
    Which LPSU do you use?
  12. #112
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Hi, I should have mentioned....I upgraded to the new lumin X1 power supply which is available as an upgrade for U1 users as well
  13. #113
    Senior Member
    Join Date
    Oct 2018
    Argentina
    Posts
    416
    Re: Lumin U1
    Hi, could you tell me what difference you noticed by changing the font, if there is a difference. Thank you.
  14. #114
    Join Date
    Jan 2019
    Singapore
    Posts
    37
    Re: Lumin U1
    Quote Originally Posted by Andik777 View Post
    Changing the Font? I guess you mean changing the power supply? Yes if so, my impressions are there in my previous post (#110). Clearly I could hear more detail, better bass delineation and soundstage width and specificity. I presume it’s all to do with lowering the noise floor even further.
  15. #115
    Senior Member
    Join Date
    Oct 2018
    Argentina
    Posts
    416
    Re: Lumin U1
    Yes, I was referring to the power supply. Thank you very much for the reply.
  16. #116
    Join Date
    Mar 2019
    La Canada, CA
    Posts
    50
    Re: Lumin U1
    Can I ask the price of the X1 power supply? Thanks.
  17. #117
    Senior Member
    Join Date
    Apr 2017
    Central FL
    Posts
    793
    Re: Lumin U1
    Believe it is $2k but not sure.
  18. #118
    Junior Member
    Join Date
    May 2017
    Drammen, Norway
    Posts
    5
    Re: Lumin U1
    I recently bought a Lumin U1. Does anyone have experience with testing different cabling and cables (brands) between the streamer and Devialet 250 Expert Pro? I've read the balanced cabling could be preferred, but my DAC (Devialet) doesn't support DSD over AES/EBU. I believe RCA/coax OR USB would be the option for me. I really appreciate your opinions and comments.
  19. #119
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: Lumin U1
  20. #120
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    Devialet Firmware 8.1.0 manual states that the "entire Expert range" supports DoP over USB, XLR, toslink and SPDIF. Since Lumin also supports DoP on all outputs, playback of DSD music should be ok regardless of which connection type you use.
    Please try both AES and USB for 44.1kHz music and see which sounds better to you. Note that these must not be connected simultaneously.
    Peter Lie
    LUMIN Firmware Lead
  21. #121
    Junior Member
    Join Date
    May 2017
    Drammen, Norway
    Posts
    5
    Re: Lumin U1
    Thanks for quick update, @wklie! I totally agree with you, Devialet should be ok with DSD regardless of with connection. But; when reading the specs of 250 Pro Expert on Devialet's own site, the following comes up:
    SUPPORTED FORMATS
    Up to 32bits / 192kHz PCM (USB)
    Up to 24bits / 192kHz PCM (AIR®, UPnP, AES/EBU, Coaxial)
    Up to 24bits / 96kHz PCM (Optical)
    Up to 1bit / 3.072000MHz DSD64 (USB, Coaxial)
    That was the main reason for my questions
  22. #122
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    These are almost contradictory, but I'd believe the text. Please test AES and let me know.
    Peter Lie
    LUMIN Firmware Lead
  23. #123
    Junior Member
    Join Date
    May 2017
    Drammen, Norway
    Posts
    5
    Re: Lumin U1
    Today, I got confirmation from Devialet support. You're absolutely right, of course, @wklie "Our AES/EBU input indeed supports DoP streams".
    I just have to buy an AES cable and test Let you know how it goes.
  24. #124
    Junior Member
    Join Date
    May 2017
    Drammen, Norway
    Posts
    5
    Re: Lumin U1
    @wklie,
    My Lumin U1 is now connected to my Devialet with a Weiss AES/EBU cable, playing DSD. The Devialet shows DSD64 in its display. Soundquality seems to be great.
  25. #125
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    Great! Please burn in the Lumin with repeat playback of playlist 7x24. Then you can compare AES against USB. When using AES or other SPDIF outputs, USB must be disconnected first.
    Peter Lie
    LUMIN Firmware Lead
  26. #126
    Junior Member
    Join Date
    May 2017
    Drammen, Norway
    Posts
    5
    Re: Lumin U1
    I have now teste back and forward, changing between Weiss AES/Heimdall2 USB/Synergistic Research Galileo USB, always disconnecting the USB when listening with AES. The AES always sounds better than USB in my setup, with more transparency, dynamic and more defined bass.
    Thanks for all your help regarding this matter, @wklie!
  27. #127
    Junior Member
    Join Date
    Sep 2019
    Teshenechi
    Posts
    5
    Re: Lumin U1
    I think to improve the performance of Lumin U1 and replace the power supply. My choice of Paul Hynes SR5 or Clones Audio Power Station Deluxe. Does anyone have any comparison experience or any thoughts?
  28. #128
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    Please consider the official X1 power supply upgrade for U1.
    If you wish to have someone custom make a LPS for you, please note the special DC connector.
    Peter Lie
    LUMIN Firmware Lead
  29. #129
    Junior Member
    Join Date
    Sep 2019
    Teshenechi
    Posts
    5
    Re: Lumin U1
    Yes, I know it's a good LPSU, but its price matches the SR7. And I couldn't find reviews comparing to Clones and Paul Hynes.
  30. #130
    Join Date
    Dec 2019
    Italy
    Posts
    41
    Re: Lumin U1
    Hi All.
    Here is how Lumin App looks
    after the upgrade to Android 10 of my Nokia 9 . Any idea?
  31. #131
    Join Date
    Dec 2019
    Italy
    Posts
    41
    Re: Lumin U1
    What is the list price for the X1 power supply upgrade ?
  32. #132
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Re: Lumin U1
    Quote Originally Posted by power View Post
    You would have to ask the Italian dealer/distributor.
  33. #133
    Junior Member
    Join Date
    Mar 2020
    Alpharetta, Georgia
    Posts
    15
    Re: Lumin U1
    Hi Peter, new to this forum and considering the U1 as my transport streamer. Reading the threads with the X1 PSU upgrade as a significant improvement, can’t Lumin offer the optional PSU upgrade at purchase so that the purchaser won’t have an extra PSU on hand and perhaps a price reduction for the trade in?
    Thanks
    Andre
  34. #134
    Re: Lumin U1
    Hi,
    I have a question, I have a U1 connected to EMM Lab dac versus usb cable, and xlr cable connected from emm dac to new active speaker since there is no volume control on the EMM dac.
    Can I use the U1 for volume control? if yes what setting should I use?
    Thanks
  35. #135
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: Lumin U1
    Quote Originally Posted by TheGiant View Post
    Thanks
    Andre
  36. #136
    Re: Lumin U1
    Thank you Joe, been joining this forum for 3 years but never post only do reading and research.
  37. #137
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: Lumin U1
    So happy you finally spoke up Andre! Thank you.
  38. #138
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,081
    Re: Lumin U1
    Quote Originally Posted by goone55 View Post
    Thanks
    Yes.
    Enable Volume Control and Leedh Processing Volume in Lumin app for U1.
    Turn down the volume before playback.
    Peter Lie
    LUMIN Firmware Lead
  39. #139
    Re: Lumin U1
    Thank you Peter, I will give it a try
Lumin U1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
