Results 1 to 27 of 27
July 20, 2015, 06:04 PM #1
Tone Arm Related- Compressor for Air-Bearing Arm
I've been running a Kuzma Airline for a long time and like it. The one sore point for me has always been the compressor, which is supplied by Silentaire. It works fine, but, because it has a relatively small surge tank, it has to kick on fairly frequently (the Kuzma arm sees about 65 psi). Over the years, I've replaced a few parts on the compressor, but it has soldiered on, so I can't say it's a bad product, perhaps just 'undersized' for the purpose. Obviously, since the arm is sold as a complete package, with inline driers as well as the compressor, supplying it with a bigger compressor would add to the not insignificant retail price of the arm. So, when the compressor started acting up, I decided to super size. This just arrived at world HQ here in NY and with some help from the local cross-fit team, will get carried up two flights and installed in the utility room adjacent to my listening room.
http://
July 20, 2015, 06:30 PM #2
- Aug 2014
- Canada
- 580
Re: Tone Arm Related- Compressor for Air-Bearing Arm
Nice looking unit how much noise does it make. I do not run and never have run air bearings. But I do have a lot of years with air running to sandblasts and to Lazars with the lazars humidity is a killer to keep it down we use over sized hoses to run the air the less friction the less heat . Warm air holds more water. You can also use a refrigerated dryer . If you have a problem or would like a cheap way to see if a refrigerated dryer would help. Do the following take 6 or 8 coils of the air line leaving the compressor coil it in a 5 gallon plastic bucket fill the bucket with ice. If that fixes the problem you need a refrigerated dryer. Never bought a small one but it should not be much. a bar fridge would work. Put your water trap after the dryer. Water is a big problem over time in air lines I can not think it is good for air bearings . Get rid of the heat you get a lot less problems. Just IMO
Lyra Atlas, tri-planner, clear audio statement, Burmester 100, Ayre KXR20, Ayre MXR20, Ayre DX5, Adept Response line conditioner, Ayre signature interconnects, Cardas clear power cables,cardas clear speaker cables and Martin Logan CLX with Decenti subs with Cardas hex link.
Not in use Infinity QLS and Ohm F
July 20, 2015, 06:36 PM #3
Wow! I can't imagine why it would need so much pressure. Oh well, I'm not a tonearm designer and I don't play one on TV.Regards,
Steve
https://www.audionirvana.org/forum/t...geezr-s-system
I only do what the voices in my wife's head tell her to tell me to do.
July 20, 2015, 06:48 PM #4
Helpful. I usually keep the room like a meatlocker (cold) in the summer, but added cooling, if it isn't a big deal, may still make a difference- will look into it. Noise- i think it is 2 db louder than the one that came with the tonearm, around 42 db. It will be installed in a room adjacent to the listening room- when there is no music playing, I could faintly here the compressor kick on, so it is there. The big constraint is that to eliminate the electrical 'zap' that the compressor creates when it kicks on, I have it plugged into a 220 volt step down, and that's located in the music room area. I've thought about installing it in the basement and running a long line but we've been trying to sell the house (for some time), so I'm not sure I'm going to do major work until we finally move.
SlowGeez: I suspect the high pressure bearing is one of the ways Kuzma was able to make this thing work in practice; I had an ET eons ago, and remember all the hoops people had to jump, the DIY, the smoothing baffles, etc. The Kuzma, while it is not the ultimate arm for all purposes, is really well executed given how tricky these arms can be. It's pretty foolproof once you learn how to set it up. (And I don't consider myself a set-up guru by any means).
July 20, 2015, 07:01 PM #5
Wow, just looked up the Kuzma Airline. Very interesting. How much maintenance is involved either with the arm or the compressor?
BTW, Bill, love your recent articles on The Vinyl Press: RLJ, Fleetwood Mac, Tull, etc - great stuff! The RLJ made me go buy an older Mofi of her S/T LP!
Allen
July 20, 2015, 07:02 PM #6
- Aug 2014
- Canada
- 580
Your welcome if you do run a long line keep it big and you can add a second tank near the table it will do two things and be silent doing them first it takes any surge out of the line because if their is a drop it does not have to go all the way back to tank in the basement to get air. Second mount it vertically and put a swing valve at the bottom and the exit air line at the top the input air line mid way up the tank and it will trap water . Open the swing valve once a month drain any water and your golden. Air tanks are cheap and the less the compressor cycles the better. IMO
July 20, 2015, 07:16 PM #7
Thanks Allen. Glad you like the site. Arm is pretty low maintenance, hardest part is getting it dead level, and you have to do that by playing it, and checking it, rather than measuring it. I check it with various levels, but that only gets you into the 'zone' because you have to set it so it tracks 'downhill' just a tad. The compressor thing has always been a bit of a thorn in my side, but it comes with the territory, I guess. Overall, it has been a very reliable product, and I am a fan of Franc Kuzma's work, having owned a couple of his tables and this arm, so far.
July 20, 2015, 07:17 PM #8
Garth, if I go that distance, literally and figuratively, I may, to paraphrase the Godfather (from I): 'Someday, I may call upon you...".
July 20, 2015, 07:26 PM #9
- Aug 2014
- Canada
- 580
July 20, 2015, 07:39 PM #10
- Sep 2014
- 365
Hi Bill
I have an Airline arm on my XL4 . Some comments :
1. I use a Silentaire Super Silent DR-150 Air Compressor which is much smaller than the monster you're showing in your pic . Exceptionally quiet , despite which I have it in an adjacent room . Running at 60 PSI as per spec .
2. I'm wondering why your compressor is kicking in that frequently - it might be that the inline air filters haven't seated their seals at the bottom properly ? There's a technique to do that , PM me.
3. Interestingly, Franc suggested to me that the table shouldn't be dead level. I introduced a tiny amount of tilt in the table which has the effect of nudging the arm ever so slightly from the outside of the table towards the lead-out grooves. We're talking the thickness of a playing card here. So it helps to have the table on a platform or base that has the capability to adjust very fine amounts of level. I use a Cartridge Man turntable digital level as otherwise, conventional levels are a waste of time.
Happy to help anytime
July 20, 2015, 07:42 PM #11
Wow, very impressive! I use an ADA MG-1 Linear Tracking Air Bearing arm and I use an AL-15A Alita Aquarium air pump which has a maximum output of 1.4 psi. It has worked fine for the past 6 years. I tried using a Hi-Blow 80 for the heck of it but it was too much. I could have used an inline valve but I just swapped back in the original air pump instead. I have thought about using a surge tank to even out the flow but haven't gotten around to it.
Main 2ch/HT:Acoustat 2+2,Axiom EP500,Ray Lumley M-100, Bedini BA-803,Threshold T3,JRDG Consumate Phono, Lenco L75, ZYX Universe cart,Oppo BDP 95(transport), Calyx Femto DAC,Bryston BDP-2,Pioneer F-91 tuner,Studer A807 r2r,Consonance d-Linear15 power filter, DVDO Matrix 4x4,Mitsubishi HC-5 projector, Audience Au24e and LectraLine Xe cables,Cullen Power Distribution Box with upgraded cable
Bedroom 2ch/HT:Tetra 406, Forte model2pre,Forte model3amp,TeacUD503,Faroudja DV1000,PioneerCLD-97 ld player,Thorens TD-146,PioneerTX-9800,Mitsubishi HC5 projector,Tetra Artet cables
July 20, 2015, 08:16 PM #12
BoBo- sent you a PM.
I may have the PSI wrong, running from memory;
I detailed the issues re compressor cycling in my PM to you, as well as my method for seating the dryers;
Re level, I wasn't entirely clear in my earlier post b/c I said dead level, but then qualified it by saying that it is canted in a 'tad' (I have measured it in tenths or hundredths of a degree, so I think we are doing the same thing on level). Happy to talk off-line in more detail, and thank you for your input.
best,
bill hart
July 20, 2015, 08:41 PM #13
July 21, 2015, 02:51 AM #14
- Jun 2015
- 7
I use a Jun Air compressor with 4 liter tank for my Rockport 6000 arm, which runs around 33psi. The compressor switches on every 4 mins or so.
Including the set right at the output of the compressor, I have a total of 3 sets of regulators between the compressor and the arm. The first regulator is set at 100+psi, which also supply air to my pneumatic table. The 2nd set takes it down to around 60psi, and the last set right before the arm is set at around 33 psi.
July 22, 2015, 07:25 PM #15
Postscript: The new, larger compressor was installed with no difficulty. In fact, the only thing I had to do was remove the "quick release" fitting from the old compressor and thread it (with fresh teflon tape after removing the old tape) into the output/regulator of the new unit. Things I like about the new unit: the motors and lines are exposed and easier to access and manage (though if things are working properly, there's very little to do, other than check oil level occasionally and empty the waste jar). I suspect my old compressor was tired- it had various oil leaks and seemed to spit oil outside of the waste collection jar (we'll see if that happens as the new unit breaks in). The unit is 2 db louder than the small 'suitcase' compressor that came with the tonearm, but that's not really noticeable when isolated in an adjacent room. And, because of the much larger tank, it doesn't seem to cycle very frequently. Only apparent downside: size and weight.
If you have an older Airline arm and eventually need to replace or refurbish the compressor (these things don't live forever), I would be inclined to go for the larger one. The cost- directly from the compressor manufacturer in the States- is not that much greater than the price of a direct replacement, despite the considerable difference in size/capacity/power. (1HP vs 1/2 HP motors; 13 gallon v 2.25 gallon tanks).
Thanks for everyone's input, including Bobo's. (We traded emails offline). I'll update this if I change my view after living with the larger unit for a while. It's nice to have the system back up and running!
July 22, 2015, 08:01 PM #16
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
July 22, 2015, 08:35 PM #17
Bill, very cool.
Before the Airline, did you use Kuzma's 4point arm? If so, how does it compare to the Airline? What improvements do you get with the Airline?
Allen
July 22, 2015, 09:05 PM #18
Knowing a bit about compressors, and being very reliant on them for dry air in my office, I agree with Garth.
I want to emphasize the drain valve must be AT the bottom, the very lowest point in the tank, NOT NEAR the bottom, nor should there be a nipple or part of the valve extending inside the tank that would allow any water to remain in the tank after draining the tank. The inner aspect of the tank where the valve is connected MUST be flush with the surface. The direction of the air inflow should be horizontally at the mid-height of the tank and the outflow should be vertical at the top of the tank. This will minimize any potential splashing in the tank (there ideally should never be any water that far down the line anyway) and prevent inflowing and outflowing air from blowing against each other. The drier should be immediately after the compressor and BEFORE any tanks which could collect water. The drain vales in the tanks are purely for a safety back-up.Listening Room: McIntosh C46, MEN220, MCD500, MR78-Modafferi modified, MPI4, MC602 (2), Pass Labs XVR1 (three-way), tri-amplified Infinity IRS Series V, TailTwister T2X rotator, AtlasSound FMA Rack, dedicated electrical sub-panel, NO TV!
Living Room: McIntosh C28, MC2300, Revox B226, Tascam CD355, Thorens TD125 MKII w/vacuum platter, Rabco SL-8E, Grace F9-E, McIntosh ML-2C (2) & ML-1C (4) stacked, MQ-107, SAE 2800, Nakamichi Dragon, Tandberg 64X, JL Audio f113 (2), NO TV!
July 22, 2015, 09:37 PM #19
Hi Bill, silentaire makes a great compressor. have you considered a scuba tank? an acquaintance of mine ran a pr of 80 cu ft tanks on his ET-2. using the system daily, he got several months use between refills. the air is absolutely dry with no pulses, surges or oil emanating from a pump (not to mention dead silent). they run 2500+ pSI and regulated down to whatever you need. depending on how 'lossy' the kuzma bearing is, a scuba tank could handle 60 PSI with no problem.
July 22, 2015, 09:38 PM #20
Thanks, Gary. For now, I'm not going to do a long run with a separate tank. I trust that SIL designed the new compressor properly; I know there is an electronic 'auto' drain function that I opted to add. In any event, I'll look at it more closely in the morning. The spitting I seemed to experience with the original, smaller (also SIL) compressor seemed to be a result of the oily water being fed to the waste jar, but not deposited into the jar; instead, it appeared to accumulate on the outside of the waste jar; whether that was because there were filtered air holes in the top of the waste jar, or some form of leakage from the drain pipes to the jar, was hard for me to tell. The new compressor is laid out more simply, and all of these parts are far more accessible. My recollection is, the motors draw air in, feed the tank and there is a desiccant type? or "coalescing" filter/dryer that is part of the output regulator. I believe the auto drying device is connected to that, but I'll look at it more closely and go over the manual (which isn't very good) again. The auto drain is described by SIL as a tank drain. The in-line dryers are connected a very short distance from the compressor output, and then, a fairly short distance to the tonearm itself, e.g. approximately 3 foot lengths at each interval.
July 22, 2015, 09:57 PM #21
Nope, the Airline was on the market for a while before the 4Point came out. Before the Airline, I had the then current (circa 2006?) Triplanar, and was using on the Kuzma Reference table- a more conventional looking table with a great internal suspension system. When I switched to the Kuzma XL, I bought the Airline. The XL was far trickier to isolate than the Reference. All of these components are now relatively "old" in high-end terms; Kuzma recently upgraded the XL turntable to use a DC motor; I'm not sure what additional changes, if any, he has made to the Airline since mine, but I believe it is still in the product line. (I know there have been upgrades to the dryers, and some of the associated stuff, including a 'damping' kit which I never bothered with). This combo, though I've had it since roughly 2007, has largely been trouble-free and still works extremely well in my system. I guess that speaks volumes for the manufacturer.
July 22, 2015, 10:02 PM #22
Hey, man! Good to see you.
Myles had actually suggested using some sort of air tanks without a compressor a while ago (when I was bitching about the compressor a couple years ago) - I never dug down on it. I like the idea, when I used to suffer from cluster headaches, I had a guy delivering 02 tanks to my house- they were cheap (possibly because of insurance/health related). I guess the only issue is that I think the ET doesn't require the pressure the Airline does, so I'd hate to run out of air while I'm in a groove. (Almost as bad as running out when under water). Let's catch-up at some point!
July 22, 2015, 10:42 PM #23
What you do is hook two 95% air/5% CO2 tanks (hopefully not oxygen!) in tandem and set one at a lower pressure. This when one runs out, the second tank kicks in. Then replace the empty tank. That's how we ran our tissue culture incubators so for instance, nothing would happen if a tank ran out over a weekend. And the stakes were almost as high!
Of course as I mentioned the first time, one MUST securely fasten the tanks to a wall with say a chain or otherwise could be violating a fire code and they could become lethal missiles if the tank falls over and the top breaks off (sure people have seen this trick done in some action movies).Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
July 23, 2015, 12:28 AM #24
Yes indeed, it's a big reason why I chose to sell Kuzma in the first place: Franc does things once, correctly. The Stabi Reference hasn't changed since introduction over 20 years ago with the exception of the power supply which has a digital speed display and push buttons for fine speed adjustment. Other products including the ones you mentioned see small changes but the fundamental design remains. The DC motor for the XL is said to give significantly better performance than even the 4-motor XL4, but I haven't seen or heard it. If and when my customer who purchased the XL4 upgrades to the DC motor and power supply I'll have a chance to check it out.
Well done, Bill. You own a classic.Brian Walsh
Music Direct
July 23, 2015, 01:07 AM #25
i'm subscribed to the vinyl press (great site, btw). i've been reacquainted with lots of fabulous music/vinyl finds. i think i now own every james gang on vinyl, i just need a '69 boss 302 to complete the package. yeah, me doing smoky burnouts leaving a traffic light while blasting "funk 49" "bomber" and "walk away" you've got mail.
July 24, 2015, 12:57 AM #26
Greetings fellow air bearing denizens. I keep my compressor in the basement and ran the hose through the wall. I used a push-lock bulkhead fitting mounted in a wall plate for a nice clean install. You can find push-locks in various sizes. Later I slid some expandable sleeving over the hose with some short sections of heat shrink on each end to keep it from unraveling. (The sleeving you would find on power cords).
Make yourself necessary to someone. Ralph Waldo Emerson
Speakers Salk SoundScape 8's Amp Krell KSA-250 Pre amp Audio Research Reference 3 Phono Preamp Bottlehead Eros SUT Park's Audio Budgie Turntable DIY Heavy Plinth Lenco Arm Advanced Analog MG-1 Linear Air Bearing Cartridge AT33PTG/II on Ultra P Arm DAC DIY Buffalo III Dual Mono Speaker Cables Harmonic Tech Pro 9+ & Pro 11+ Acoustic Treatments GIK Tri Traps and Panels Power Richard Gray 600S & PS Audio Cables
April 10, 2017, 07:10 PM #27
I have to chuckle a bit over your air-bearing compressor woes. This is all it takes to run the Trans-Fi Terminator tonearm. It runs nicely on 0.09psi.
I know it apples to oranges but I couldn't resist.Basement
Pre-amp: Wright WLA12A
Power-amp: Transcendent SC-150 monos
CD: Arcam Alpha 9
Tuner: Kenwood KT-6500
Phono Stage: K&K Maxed-Out
TT: VPI TNT Mk-6/Trans-FI T3 Pro Air bearing tonearm/Ortofon Jubilee
Speakers: Acoustic Zen's Adagios
Cables: DIY twisted pair ICs, TG Audio Speaker Cables
Breezeway
Pre-amp: Cary SLP-98
Phono stage: DIY AD797 Hypnotized
Power-amp: Latino ST-120
Tuner: Kenwood KT-7300
CD: Arcam CD82
TT: VPI TNT MK3.5/SME-V/Benz Glider/SDS
Speakers: Salk HT 2TL-s
Cables: DIY Twisted Pair, Star Quad Speaker Cables
Upgrade on the way...
