Results 1 to 42 of 42
Thread: Stylus Care: What's Your Method
May 10, 2015, 05:46 PM #1
I am learning how to care for Ortofon Windfeld Cartridge and Stylus.
I am using two Last products as well as a gentle brush. [See photo] Because I am so thorough cleaning my vinyl, I rarely use the brush.
Suggestions and what is your method?
May 10, 2015, 06:42 PM #2
- May 2013
- 2,013
Re: Stylus Care: What's Your Method
I think you have things pretty well covered in my opinion.
Most times for me it's a dip into a piece of Magic Eraser before each side. Sometimes it's a gentle pass with a dry stylus brush if I'm feeling particularly OCD. I've never seen anything on or around my stylus or come off on the M.E. or brush, (signs of a clean record).
I'm thinking about getting a Zerodust, but how much different in function and performance is it than M.E?
I am on the fence about using liquids on my stylus.
~Eric
May 10, 2015, 06:48 PM #3
The Zerodust Stylus Cleaner looks very interesting!
See it in Action
Buy Music Direct
May 10, 2015, 07:05 PM #4
- Aug 2014
- Canada
- 580
I play a Nirvana record it sucks the Grunge right off the needle
Lyra Atlas, tri-planner, clear audio statement, Burmester 100, Ayre KXR20, Ayre MXR20, Ayre DX5, Adept Response line conditioner, Ayre signature interconnects, Cardas clear power cables,cardas clear speaker cables and Martin Logan CLX with Decenti subs with Cardas hex link.
Not in use Infinity QLS and Ohm F
May 10, 2015, 07:41 PM #5
David.......I use a combination of the Zerodust and the dense stylus brush that was provided with my Ortofon Cadenza Black cartridge. I do the same for my Ortofon Cadenza Blue cartridge in the living room system. Periodically I examine the stylus tips using a Bausch & Lomb 10x jeweler's loupe and a bright flashlight. This routine works well for me.
Dan
May 10, 2015, 07:52 PM #6
Ortofon recommends against using any liquid cleaners or treatments with their cartridges, and specifically endorses the use of Zerodust. I'd suggest sticking with their recommendation to avoid possible warranty issues if you need their support any time during ownership.
May 10, 2015, 07:55 PM #7
May 10, 2015, 07:59 PM #8
Bill.......I agree. Even though Ortofon recommends against liquid cleaners, I have always been concerned with liquid chemicals leeching up the cantilever and doing damage to the stylus suspension system. If I wasn't using the Zerodust cleaner I would probably use a small piece of Magic Eraser. The micro bristles do a good job of keeping debris off the stylus tip. No liquid cleaners for me.Dan
May 10, 2015, 08:17 PM #9
- Apr 2015
- Long Island, NY
- 120
Clean records and Zerodust for me. I usually give them the zero dust treatment once to twice a week. I used to use a brush before I got the Zerodust. Not going back ever!
Audio Den
Audio Physic, B&W, Dynaudio, Magnepan, Paradigm, Golden Ear, Wilson Audio, Audio Research, Anthem, Arye, Bel Canto, Classe, Constellation Audio, Esoteric, JL Audio, Marantz, McIntosh, NAD, Parasound, PrimaLuna, Rotel, Simaudio, Technics, Clearaudio, Dr. Feickert, EAT, Pro-Ject, Thorens, Benz Micro, Denon, Grado, Ortofon, Sumiko, Audioquest, Nordost, Shunyata, Transparent Cable, Audeze, Sennheiser, King Sound, Master and Dynamic, Okki Nokki and many others.
May 10, 2015, 09:49 PM #10
- May 2013
- 2,013
I think that is why I've been on the fence about stylus cleaning fluids. I have an Ortofon 2M Bronze. I've also read some suggestions against it from a couple of other cartridge makes. So I figured if there are a few who are against the use of liquids, there must be good reason.
May 10, 2015, 09:52 PM #11
- May 2013
- 2,013
I may pick up a zerodust just to have on hand, even though I use Magic Erasure.
May 10, 2015, 10:16 PM #12
This type of Magic Erasure? http://www.amazon.com/s?ie=UTF8&page...magic%20eraser
May 10, 2015, 10:36 PM #13
- Feb 2014
- 1,861
Onzow Zerodust on every record turn. Nothing else. It is recommended the safeset way is to dunk only... but many of us push with our confidently steady hands.
Speakeasy
May 10, 2015, 10:38 PM #14
David.......That's it. Cut a square about one inch out of the Magic Eraser and glue it to a quarter. The coin will give it weight and make it easier to move under your stylus. If your are worried about scratching the turntable plinth with the quarter put a small piece if sticky-back felt on the bottom of the quarter.
Dan
May 10, 2015, 10:56 PM #15
Dan...what do you use: Magic Eraser or ZeroDust?
May 10, 2015, 10:59 PM #16
I use the Ortofon supplied little stiff/dense black brush every record turn and the zerodust about every five LP's. Sometimes the zerodust gets stuff unseen or adhered that the brush must miss.
When my zerodust gets fouled with little micro-blobs of crud I wash it with warm soapy water and rinse well and air dry to renew it. I do this about every 6 months or so.Avanti Audio
May 10, 2015, 11:00 PM #17
Use the brush that came with your stylus (brushing back to front only, obviously). Nothing more, nothing less.
May 10, 2015, 11:00 PM #18
David.......I use Zerodust. It' simple to use and works very well to keep the stylus spotless. I just lower the stylus onto the Zerodust, then raise it back up. That's it.
Dan
May 10, 2015, 11:08 PM #19
- May 2013
- 2,013
Yes, but you want to make sure you get the plain original/standard version.
One four brick box will last you for at least a decade. You cut a small square from a brick, say 1 to 1.5 inches. I got little plastic containers with lids and cut to size. Then use the same way you would a zerodust.
May 10, 2015, 11:11 PM #20
- May 2013
- 2,013
May 10, 2015, 11:15 PM #21
- May 2013
- 2,013
May 10, 2015, 11:19 PM #22
- Apr 2015
- Long Island, NY
- 120
Audio Den
May 11, 2015, 06:30 AM #23
- Sep 2014
- 365
I'm honestly surprised. The Zerodust costs virtually nothing and lasts a very long time. You're talking about cartridges that cost sometimes thousands of dollars , its amazing anyone would want to take the risk. I have 10 tonearm/cart combos and the Zerodust is pretty much all I use. Liquids are a no-no - since they can travel up the cantilever and as far as the brush is concerned its all too easy to damage the suspension using this.
May 11, 2015, 08:19 AM #24
If you already clean your records with a Record Cleaning Machine you really don't need anything except for a small brush to wipe any fluff off from time to time.
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
May 11, 2015, 08:44 AM #25
- Sep 2014
- Philly
- 101
Zerodust - why didn't I think of that?
Bruce in PA
May 11, 2015, 09:33 AM #26
Speakers: Magico M-Project w/MPods
Amps: CAT Legend -> CAT JL7s
Analog: Kronos Pro Limited Edition / Black Beauty tonearm / Zyx Universe Premium, Ortofon A95
Digital: Roon->Vivaldi DAC/Upsampler
Cables/Power: Kubala Sosna Elation ICs & SCs / Shunyata Denali 6000T & PC's / Furutech outlets
May 11, 2015, 10:14 AM #27
May 11, 2015, 10:27 AM #28
- Feb 2014
- 1,861
Even so, we don't play records in a vacuum. There are many forms of particulates, most of which are oily excretions that flake off our bodies and vacate our orifices.
Speakeasy
May 11, 2015, 10:56 AM #29
- May 2013
- 2,013
I'm not clear what you are getting at or getting from what I said.
Just to be sure though, I never even inferred that the zerodust doesn't last or that it was in some way an inferior product. I'm even picking one up myself now that it can be easily had. I only commented on Magic Eraser in particular in a direct answer to a direct question from the OP. The only mention of zerodust was regarding the way one uses magic eraser. I also never stated that one should only use magic eraser. I happen to use magic eraser since I did not have a zerodust and both work essentially the same way only the zerodust is stickier while the M.E. uses a different material.
It has never been proven that using magic eraser is taking a risk or any more risk than using zerodust. The only risk there is and it's the same for both, is misuse or careless use of them and the results would be the same.
I'll soon have both M.E. and Zerodust, so what is the problem.
I totally agree about liquids too. In fact, the other risk with those I was thinking about is the way the stylus is mounted, such as the bonding agent used and what interaction the chosen liquid may have with it. I see liquids as the big risk and it don't matter if it's a $5000 Lyra or a $100 Ortofon or whatever. Who wants to damage an uber expensive cart and stylus or purchase a less expensive cart/stylus every 3 months because the liquid did something?
May 11, 2015, 11:04 AM #30
- May 2013
- 2,013
Also the particulates in the air in our homes from the kitchen and any pets and if there is a smoker and and all manner of stuff that land on the record when you take it out of the sleeve to play it, especially if you like to play without the dust cover on. Even regular "dry" dust is not so dry, it mixes with the other particulates that are sticky and that what makes some dust fall faster due to the extra weight from other particulates. (This is one reason I don't use the air dry in the dish rack method).
No cause for paranoia. It may be that the needle picks nothing up, especially if one also does a dusting brush before or after playing a record, it's still considered a best practice to take care of the stylus while your up.
May 11, 2015, 11:49 AM #31
- Sep 2014
- 365
Getting at ? Or Getting? Problem?
Inferences?
Feel free to draw your own as you've obviously seen fit to do. I am making no comments implied, insinuated, assumed or tacitly suggested. My surprise was simply at the usage of a product for an application it was not clearly designed for. Whether it works or has been "proven" (by whom ? who's actually going to fess up to wrecking a multi-thousand Dollar cartridge by using a ME?) , I find that I would rather buy a product designed for the job, that lasts a very long time and whose cost is de minimus in the context of cartridge cost. But that's me , some may feel the risk is very worthwhile.
May 11, 2015, 12:33 PM #32
Some dark humor on the topic...I read this thread yesterday and realized I hadn't cleaned my Benz lps in awhile. Pulled the Zerodust out and shazam clean needle right before bedtime. But all night long I had a dream I was carrying my cartridge with me with needle exposed, at a hotel among people needing to cross a river etc. One long dream of my expensive cartridge being held by me and in peril.
May 11, 2015, 12:42 PM #33
Dan
May 11, 2015, 12:57 PM #34
- Sep 2014
- 365
May 11, 2015, 03:40 PM #35
- May 2013
- 2,013
Sorry, I may have misunderstood part of what you said. I know what you mean here and I can't argue it because there is no argument. There are some folks with expensive cartridges that will use magic eraser, believe it or not, I've run into them. On the other hand in backing your statement, I do wonder that if they bothered to spend four digits or something on the cart, why not spend the extra $60 (less now) on a zerodust? I admit it makes no sense (unless of course they spent all the money they have on the cart, but where it me, I would have factored in the cost of the zerodust, but that's me).
I'm only saying the two products do the same thing with different material and the damage risk is the same, however with the zerodust being a lot more sticky than M.E., it may be that it does a better job. (That's why I ordered a zerodust, to see for myself and it certainly won't hurt to use it from now on anyway).
I read someplace that the material we know as zerodust was not originally designed for cleaning needles either, but I'll be darned if I can find that now. Doesn't much matter though since it works.
May 11, 2015, 05:12 PM #36
May 11, 2015, 05:49 PM #37
- May 2013
- 2,013
Just for clarity, this is even after being cleaned to within an inch of the record's life with fluids, vacuum, ultrasonics or all of that?
Don't get me wrong, I am habitual about cleaning my stylus as mentioned, no matter the record. With that statement, I can hardly wait to get delivery of my Zerodust. I've never seen anything come off on my magic eraser or stylus brush. Doesn't mean there isn't something still on the stylus though even with my religious habit.
I agree about recleaning LPS, but I would think it would be any LPs and not just US ones, accounting for what settles on them when they are out of their jackets, I could be wrong. I wonder if it has something to do with the way LPs are pressed in the US verses elsewhere?
May 11, 2015, 05:53 PM #38
- Aug 2014
- east of Seattle
- 821
I apologize if the following is repetitive as I've not read every post in this thread.
I use the zerodust about every third or fourth side, lightly. barely dipping the stylus into the surface. I always make sure my glasses are on for that action.
the Magic Eraser is more for when I feel a more aggressive cleaning is needed. sometimes I will take a q-tip and dip it in water and dab that on the stylus first to allow anything that might have built up and dried on to dissolve slightly. I know the water will not wick up the cantilever like some chemicals. my philosophy is always "don't mess with stuff any more than you need to", and "beware of unintended consequences". and I always do this un-muted so the system will tell me if I got too aggressive.
if you observe Magic Eraser under a microscope you see lots of stiff/sharp little loops that grab and cut at stuff. so it's critical that you drag the magic eraser softly in the correct direction since it can easily snag and ruin your day.
May 11, 2015, 05:56 PM #39
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
May 11, 2015, 06:53 PM #40
Myles.......Trust me, there's plenty of airborne particulates out here in the country. Pine tree pollen, oak tree pollen, hay fields being cut in the summer with plenty of stuff floating away. Yes, the country air is sweet to breath but there's plenty of airborne micro debris that loves to find its way into our homes and ultimately wants to settle on everything including my records when they are out of the inner sleeve and jacket.
Dan
May 11, 2015, 07:07 PM #41
- May 2013
- 2,013
This is why I use the Magic Eraser like you do a Zerodust. Any of those little loops, even with the lightest touch can ruin your day. I never drag the M.E. in any direction in any manner. Then again, I'm timid using a stylus brush too even though I do.
I don't know that I would use water myself either. Water may be an actual solvent when you break down it's parts, but not string enough to much of anything as a solvent. However, while it may not do anything to the stylus itself, doesn't the cantilever pretty much wick any liquid it comes in contact with and wouldn't water rust it? I could be wrong, just my personal thinking it through.
May 11, 2015, 07:10 PM #42
- May 2013
- 2,013
Upgrade on the way...
