Results 1 to 48 of 48
April 7, 2015, 09:09 AM #1
Moving gear to front of the room? Pro's? Con's?
I am considering moving my gear to the front of my room. The 11 meter XLR run becomes quite an investment as I look into moving to Siltech cabling. My thought is to have Timbernation build me some low profile racks (27.5 inches tall max). The racks would sit BEHIND the speakers by 4-6 inches. The 27.5 inches would match the height of the stacked XS150's. The 27.5 inches is even with the top woofer of the Strads and yet remains below the midrange and tweeter. I could fit two 39 inch wide (27.5 inch tall) racks (with three shelves at 7.25 inches), giving me a total of 12 "slots" for gear. My Turntable and POSSIBLY R2R could go on top. I think I may just keep the R2R off to the side if it will affect diffusion in a negative way (but I will try it to see).
My question is will this affect sound diffusion in a negative way or should I be ok so long as the rack remains low profile?
Thoughts?My Systems: http://www.audioshark.org/showthread...481#post158481
April 7, 2015, 09:21 AM #2
- Feb 2014
- 1,861
Re: Moving gear to front of the room? Pro's? Con's?
If the speakers are forward, the effects should be negligible, IMO, otherwise imaging and focus can be compromised.
I've experimented a little with such placement given space limitations and high racks. My speakers are forward (contrary to older pics on my system thread which show forward faces from rack line only, which was still OK for Dali performance).
However, Dali's are not towed in per their recommended placement. This attribute probably contributes to their versatility of placement. Other loudspeakers could be more critical. YMMV.
Speakeasy
April 7, 2015, 09:32 AM #3
April 7, 2015, 09:37 AM #4
April 7, 2015, 09:53 AM #5
Mike did you ever get that room acoustically like you wanted ? I remember you were changing speakers , repositioning speakers a while back. Also just wondering about the new proposed distance from the back and side walls. I had a room like that and a little movement impacts a lot due to the room design but those Stradivari's might enjoy a little more forward air. But should be fun.
April 7, 2015, 10:16 AM #6
Chris - I did get things sorted out. I really want to try some panels from Resolution Acoustics (who will be at Axpona with two VERY unique rooms - one treated, one not - same systems in both - COOL!). Right now I would say my room is a pinch too damp. I could remove a few absorbing panels and that should do the trick.
I went back to STRADS because they sound amazing and they just work in my room. They have soul! And I love the sound of wood!
I'm tempted to try some Scala V2's or Stella's since I love my Scala's so much downstairs - but I best not mess with it I figure.
Since the STRADS are wide (and therefore the drivers further away from the side wall), the edge of the speaker can be a pinch closer to the side walls. I have them out a little more than 4 feet. I followed the Sumiko setup procedure to determine this. I have ZERO bass issues or high frequency issues. I have a glorious midrange. Man, I better not mess with trying some other speaker. And the XS150's just bring everything to life! Thunderous!
Sent from my iPhone using TapatalkLast edited by MDP; April 7, 2015 at 11:33 AM.
April 7, 2015, 10:18 AM #7
My guess is that the "negative" effects of moving the equipment between the speakers will be offset by not needing such a long run of interconnects. Thus the total effect will be a good one.
Jock
April 7, 2015, 10:29 AM #8
I prefer to have as little gear as possible between the speakers. I do have my amps sitting between my X2's but even on their stands they stand less than a foot off the floor.
Jim
April 7, 2015, 12:10 PM #9
You shouldn't have too many issues re: Diffusion. If anything, I think the pros and cons will balance everything out.
The upside is that you will be dealing with shorter cable lengths. This should pay dividends. On the downside, by putting the rack directly behind the speakers, you're basically throwing it into your loudspeakers 'firing range'. There's going to be a lot of energy hitting that rack - which will more than likely generate a lot of resonance. Whether or not this will be audible however - I can't say.
April 7, 2015, 12:16 PM #10
As long as the rack is open on the sides, rear, and front, with adequate space between the top of gear and the bottom of the next shelf, and placed behind the edge of the baffle then there should be minimal issue. If anything it will help mitigate reflections off the wall behind the speakers.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
April 7, 2015, 12:50 PM #11
April 7, 2015, 12:51 PM #12
April 7, 2015, 12:52 PM #13
April 7, 2015, 01:08 PM #14
Harbeth C7ES-3/30 • Pass Labs XA30.5 • McIntosh C220 • Modwright/Sony SCD-XA5400ES • VPI Scout+ADS/JMW-9/Nagaoka MP-500
"[N]ot everything that can be counted counts, and not everything that counts can be counted." -William Bruce Cameron
"Measurements do not lie, but neither do they tell the whole truth." -John Atkinson
April 7, 2015, 01:50 PM #15
- Feb 2014
- 1,861
Sure, rack performance counts. This is where the design and material elements of the Quadraspire racks excel! I have a turntable on a HRS platform sitting on a tall Quadraspire rack close to a loudspeaker on timber floors. Zero problems with resonance, vibration and feedback. The racks are spiked and decoupled on isolators.
I think of the rack's performance working in harmony like an orchestral stage or pit. The Quadraspire racks are open with vented and fluted shelves. They sway with the energy of the music.
Speakeasy
April 7, 2015, 01:58 PM #16
- Jan 2014
- Los Angeles
- 1,775
I think it makes a difference and doing this for high end cabling seems excessive as room effects trump cables in my experience. i switched positions in my old room and it was clear as day. fwiw, Rives (when they were around) would only allow an amp in between the speakers for their room setups.
you might try both positions with the cables you have, first, before ordering a very expensive XLR. that would isolate the room component at minimum?Brinkmann Bardo w/ EMT HSD-006 cart, MSB Reference DAC --> Linear Tube Audio MicroZOTL --> Ampzilla 2000, 2nd Edition --> Fyne Audio F1-12
April 7, 2015, 02:10 PM #17
April 7, 2015, 02:11 PM #18
April 7, 2015, 03:16 PM #19
The place to have your front end of your system is where there are bass nadirs in the room where your gear will see the least amount of vibration. There is no guarantee that will be in the middle of the speakers!
Since the balanced line system exists to eliminate cable artifact, I used it to allow me to place the front end in the most effective spot in the room, which proved to be just a few feet from my listening chair. It should not cost a lot of money to run long interconnect cables if your gear supports the balanced line standard. If not- then you will have to get more expensive cables.... I use Mogami Neglex, about 30 feet of it. I've yet to hear any cable sound better, or for that matter, different. They all sound the same, but my setup supports the balanced line standard so that is predictable.
I have LP storage between my speakers. They behave as fairly effective diffusers. It seems as the system improved in every way by placing them there. I have the front end placed on a custom built Sound Anchors stand, which has custom platforms for the turntable and preamp. I can play any volume I want and the system is impervious- it stays relaxed and does not sound loud at all even when the sound level pressure meter says it is. That makes long listening sessions a lot easier
April 7, 2015, 04:01 PM #20
Mike,
You've clearly poured a boat load of time and money into your system - so why purposefully compromise the effort just so you can accommodate more stuffs? Go for the quality solution.
April 7, 2015, 05:43 PM #21
April 7, 2015, 05:46 PM #22
Well, it's actually not for more stuff - it's to stick to a new cabling budget. An 11 meter run of Siltech Royal Signature would take most of my budget! Now, I COULD do Classic Series 550 or maybe 770 and do the long run.
The other side is kind of silly, but, I kind of miss looking at all my gear. The KRONOS TT, the R2R and now the T+A PDP 3000HV. All eye candy. Silly, I know....but...
April 7, 2015, 06:13 PM #23
I agree with that. While the sound is the obvious factor, aesthetics has its place. Just as some people say they enjoy the ritual of dealing with vinyl as part of their listening session, I enjoy the appearance of the gear as I listen. However, since the gear is in front of me, the lights on the gear drive me crazy at night when the interior lights are dim. I moved the Lumin into the main system Friday afternoon, and that night the blue ring around the power supply button was driving me nuts, so I ended up moving the power supply to a marble end table in the corner behind the left speaker. Out of sight and out of mind.
Bud
Sony XA-5400ES SACD
April 8, 2015, 03:01 PM #24
Mike, I'm guessing that most of your gear have remotes associated with them except, of course, for the Kronos. Are you willing to have to get up and walk all that way to flip a record over when listening to analog? Just imagine the amount of steps involved when listening to 45rpm records.
Doug
April 8, 2015, 04:15 PM #25
I know. The horror of all that exercise must clearly be taken into consideration. However, could we then consider spinning vinyl a sport? Surely it's better for one than golf - the only sport where one is in worse shape after they play than before (beer, hotdogs, etc).
April 8, 2015, 05:43 PM #26
There is something that is partially touched on previously in this thread & that is the room. IMO, "if" the room is sorted & treated properly sound-wise where the optimal positioning has been found with speakers, having the components in between the speakers is negligible if you have these 2 things. The room to have your racks against the front wall with the speakers forward of them & the racks kept to the minimum height. This has been my finding in the past in purpose built rooms that I have owned.
April 8, 2015, 05:46 PM #27
April 8, 2015, 05:48 PM #28
If you rack is off the front wall and a little off-center from the sides you should be able to get it close to a room mode dip (nadir). You may also want it a little farther off the floor than you might think, for the same reason.
My rack front is over 2 ft behind the front speaker baffles (which are just over 5 ft into the room). When I moved from a side wall location which I thought was good (based on avoiding first reflections and being in a bass dip) to the present (off) front wall location, the sound actually improved noticeably. Although I use balanced cables either way, I think it's possible that the cables being shorter might be part of that improvement.Rob
__________________________
Tascam BR-20; Technics 1506 with tape path upgrades, FM head, DeHavilland 222 tape head pre; Modwright Oppo 205 full tube mod w/LPS; Euphony Summus server, EtherRegen, HDPLEX LPS; MSB Discrete DAC (dual PS, ISLPro, balanced out); Pass Labs XP-12, XA60.8 (pair); Daedalus Audio Apollo 11’s, VMPS Larger Sub; Daedalus/Wywires, Acoustic Zen, Sablon Audio, Wireworld, Shunyata Research cables; Core Power Equi=Power;
Adona rack, Stillpoints, IsoPods, ASC, GIK Acoustics accessories
April 8, 2015, 06:34 PM #29
April 8, 2015, 06:49 PM #30
- Feb 2014
- Spokane,Wa
- 28
Mike, There is a an excellent article in the Jan-March 2015 issue of HiFi Critic about the exact issue you are looking at. You can go on line at HIFIcritic.com and buy the issue if interested. The article is titled Relocation, Relocation, Relocation. In a nutshell the reviewer found, as was recommended by Jim Smith in his Get Better Sound book, that by FAR the best place for your equipment rack is at the mid point of the side wall. Just one persons opinion I guess.
April 8, 2015, 06:52 PM #31
April 8, 2015, 07:41 PM #32
I don't think anyone is arguing the point that a rack not in the centre of the speakers is best, as all is room dependent,but, as Rob above & myself as well have found,it wasn't as good as we thought it was going to be. I honestly wondered why I bothered to put my gear at the halfway point on the side of one of my rooms & actually moved it all back to between the speakers about 4 months later. Once having done so the result was evident but nothing I noticed a day later by much.
April 8, 2015, 07:43 PM #33
April 8, 2015, 07:51 PM #34
April 9, 2015, 08:56 AM #35
by FAR the best place for your equipment rack is at the mid point of the side wall. Just one persons opinion I guess.2chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
April 9, 2015, 09:15 AM #36
Jim's book also says turn off the WiFi in your house. How much difference do you think that makes to the sound? Also that having a 30' cable run to one speaker with a 6' run to the other sounds fine. How many of us do that?
Rob
April 9, 2015, 09:17 AM #37
April 9, 2015, 09:21 AM #38
April 9, 2015, 09:24 AM #39
April 9, 2015, 09:52 AM #40
So how does one decide what parts of Jim Smith's advice to take? Only one way, of course; try it yourself. So I think that ends up being the "answer" to Mike's OP in this thread.
Rob
April 9, 2015, 10:45 AM #41
Hi Rob as you noted "Only one way, of course; try it yourself". I really don't think out of all the forum members and "paid reviewers" our rooms are the same nor do we all have identical equipment or music taste or budgets to make them so.
We moved to beach a few years ago to downsize after we both retired and I have this small cube of an office that is impossible to get right. Coming from a dedicated listening room that resembles Mikes' main room to a 11x11x11 cube with a 5 foot opening in one end of an office has been extremely difficult. We still have a "family room area for HT and other music but when I want to get out of the way, it usually means I put on a pair of headphones in my office .2chl : Vincent Sp331MkII, W4S STP-SE Stage 2, Kef 201/2, KEF 140, Vapor Breeze, Lumin, Bryston CD, BHA-1, Quicksilver Headamp, HD650, HD800s, HD820's, Dan Clark 1.1, Focal Stellia, OPPO 203, 105. ( Boxed up: Pass Xa-30.5, VPI Classic, Dynavector DV-20XL, Manley Chinook, Cadenza Bronze)
March 9, 2019, 08:09 PM #42
- Dec 2017
- 52
Being an old thread, and struggling with this decision myself, I am curious of those that have chimed in have made additional tests or come to any further conclusions. I have a dedicated room (12x20x9), and have tried both side wall and in front between (and behind) the speakers. Either it truly doesn’t make a difference in my room or I don’t have the ear for it, but for the life of me, I cant seem to really perceive a difference. Probably need to work on speaker/seating location. Anywho, would love to hear from others.
March 9, 2019, 08:23 PM #43
- May 2013
- 3,242
I've tried it both ways in my dedicated room and I couldn't tell the difference either so in the middle it stayed though the rack is several feet behind the rear of the speakers.
March 9, 2019, 08:44 PM #44
I also have racks in between the speakers. Reading Jim Smith's book it really sounded like the speakers should be out in front a bit. I feel I have gotten more air and a much better sound stage having the speakers move out in front of the racks!
― Neil deGrasse Tyson
March 9, 2019, 10:06 PM #45
- Dec 2017
- 52
The front of my speakers are about 6 feet from the front wall, so my rack is about 2-3 feet behind the speakers. Probably why the racks behind them don’t interfere too much? Since my rack is modular, I think I am going to try for shorter and wider in front and have the ability to look at them while playing (mike’s notion of enjoyment from watching a record spin).
March 10, 2019, 03:45 AM #46
I would just test it. Sit in the sweet spot and listen, then you can observe where the image manifests itself. If the sound comes from where your gear is placed, you might want to adjust. In my system it forms above the gear (my rack is not very tall).
March 10, 2019, 04:07 AM #47
- Apr 2015
- 634
Yes, I haven't pursued that strategy. I have a low rack between and slightly behind the speakers, and me and all my visitors love the deep and layered soundstage with great location within it. The speakers completely disappear in the soundstage. Especially listening in the dark the illusion of being transported to another venue can be strong.
Properly taking care of the room acoustics is more important. It has taken me years to get where I am on that.Simaudio Moon Neo 260 DT CD Transport / MIT SL-Matrix Plus AES/EBU digital cable / Schiit Yggdrasil Analog 2 DAC / Octave HP 700 preamp / Octave RE 320 stereo amp with Super Black Box / Reference 3A Reflector monitors on Sound Anchors Signature Stands / dual JL Audio Fathom 112 v2 subwoofers on ASC SubTraps / ZenWave Audio D4 and SMSG cables / Acoustic treatment: tube traps, Tri-panels, window plugs, ceiling diffusers (all ASC), large absorbing panels (Acoustics First), diverse carpets chosen for acoustic properties: wool, polypropylene basket-weave
March 12, 2019, 08:09 AM #48
- Jan 2017
- Leyden
- 596
If my g/f allows it I'd like to build some diffusers for mid/high and place them at the first reflection points at the long wall.
https://dngmns.home.xs4all.nl/fwd.htmlPre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
Upgrade on the way...
