Results 1 to 11 of 11
  1. #1
    Senior Member
    Join Date
    Apr 2013
    Florida
    Posts
    267
    flat vs round interconnect, cables, speaker wire.
    Are there any macro- physical advantages of round vs flat wires in terms of being able to lay them out , manipulate them etc?
    Vintage Bedroom Gear: Dual CS 5000, McIntosh C29, McIntosh MC300, MR78 Sonus Faber Concertino
    Listening Room Gear McIntosh MT10, McIntosh c2300, McIntosh MC275MKVI Mono'd, Sonus Faber Elipsa SE
  2. #2
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    Re: flat vs round interconnect, cables, speaker wire.
    Macro? No. Micro? Maybe. Its like anything with cables - it opens a whole can of worms. I believe the argument with flat is that they are able to separate individual strands of copper (rather than twisting them together like you typically find with "round" cables)....but others with more experience can hopefully shed some light here.
    My personal opinions are:
    1. Speaker cables with silver is bad - unless you're using dull gear and dull experience and need to add some brightness to your system. You can get away with silver in PC. I'm unsure about silver in IC's. No desire to try it.
    2. Buy the best single strand OCC copper you can afford. Flat or round.
    3. I'm generally not a fan of "little boxes" on cables....although, I did hear the MIT cables and was impressed....but the session wasn't long enough to make a clear determination.
    I'm about to try some AcousticZen speaker cables (will purchase from Jeff). Looking forward to comparing those to my existing WW cables. Spec wise, the AcousticZen looks superior.
  3. #3
    Senior Member
    Join Date
    Apr 2013
    Seattle Area
    Posts
    1,381
    Don't get me started !! Use coat hangers !!! LOL ...just kidding...
    Hey bill, why don't you try my DIY cable deal ? For a few reasons..they do work awesome, look awesome and I know you are a DIY guy (this wont hurt your arm)...the final result takes you down to about 10ga ..for a refresher..look here (and by the way...use a cordless drill to twist the cables - one that's reversible so you can do the two directions)
    Low-Inductance DIY Braided Hi-Fi Speaker Cables
    Warning, these will make a cable about 3/4" across with the sleeve but way cool and sound incredible...
    MAIN RIG: Equipment: Marantz SR4023 as Pre / Velleman K4040 Tube Power Amp / Yamaha M65 Power Amp / Polk Monitor 70's with Polk Sub / ClearAudio Concept table with Musical Surroundings Phonomena II Phono Stage and ClearAudio Concept MC cart /Pioneer PL500 TT with AT440MLa
    Be the person your dog thinks you are...
  4. #4
    Senior Member
    Join Date
    Apr 2013
    Florida
    Posts
    267
    Quote Originally Posted by ohbythebay View Post
    There are a slew of people who have tried the silver coated copper (eclipse 6 silver) who claim it adds some brightness. If people follow me on this forum they know I am always turning up the treble a little to bring out the high notes.
  5. #5
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    You're right Bill. It just might really be to your liking. If I had some, I would send them to you to try.
  6. #6
    Senior Member
    Join Date
    Apr 2013
    Seattle Area
    Posts
    1,381
    You'll get in treble if you keep doing that...LOL
    Really curious about your lack of brightness..I wonder if its a preference more than most or you are lacking high detail for some reason...could be tube or cart related also
    Mike - correct me if I am wrong, but brighter cables would not compensate to the degree where one is turning up the treble, yes ? What I mean is there should not be THAT much brightness from the cables, true ?
  7. #7
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,094
    For me it was quite bright. About 3 notches up on the old treble. Maybe more.
  8. #8
    Senior Member
    Join Date
    Apr 2013
    Florida
    Posts
    267
    Thanks Mike that was kind of you. The real question is : Does copper attenuate some of the current from amp to speaker? The concept is that silver allows a transfer of current without the same resistance of copper.
  9. #9
    Senior Member
    Join Date
    Apr 2013
    Florida
    Posts
    267
    Where does the wood come from
  10. #10
    Senior Member
    Join Date
    Apr 2013
    Seattle Area
    Posts
    1,381
    Trees...why ? LOL
    I didn't do the wood on mine (kinda silly actually) and just shrink tubed the ends...
    Remember these...VERY low inductance and noticeably different...without high cost... 12 ft lengths
  11. #11
    My preference has always been flat for SC's, simply because of the full length equal spacing of conductors.
    Its a whole nother ball game for IC's.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
