Results 51 to 100 of 107
Thread: Ultrasonic Record Cleaners ???
September 23, 2014, 05:24 PM #51
Re: Ultrasonic Record Cleaners ???
Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
September 23, 2014, 05:32 PM #52
September 23, 2014, 05:35 PM #53
- May 2013
- 2,013
I've recently been thinking about that. I'm not in need of doing that at this point, but I also think that it may not be universally necessary. I think it does depend on your environment, but still kind of hard to say for certain. My current environment gets dusty quick, but that's about it mostly, not a whole lot of other contaminates mixed in that are sticky or make the dust stickier. That said though there is much we don't see and I used to live in a house where there was dust, cooking particles from a gas kitchen and a heavy smoker and pets. That is pretty much every bad thing that can land on a record and stick in the grooves just in the amount of time it takes to take it out of the sleeve.
In such an environment I can see benefit of running one's records through a cleaning every 10 to 20 plays.
Micheal Fremer says one should only have to clean a record once and then just use a carbon fiber brush to dust it before play. I find that to mostly be the case for me in my environment currently, but again, I don't think that is universally true and I think that is completely dependent on one's environment.
September 23, 2014, 05:43 PM #54
Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 23, 2014, 05:48 PM #55
Another alternative.
Record Genie Dave BurtonMyles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 23, 2014, 05:59 PM #56
Just a follow up on the mold issue with LPs. From the following piece.
Paper sleeves are also hygroscopic (water absorbing) and as a consequence facilitate the growth of mold or fungus on the LP. Older audiophiles may remember the original Discwasher record cleaning fluid that used sodium azide to kill and remove these organisms from the record grooves. (Sodium azide was, unfortunately, removed from the market several years later when it was found to react with copper pipes and cause explosions.) As we know from early enzyme based record cleaning fluids from Buggtussel and more recent products from Audio Intelligent and Walker Audio, not to mention two newly released items from Mobile Fidelity and Musical Surroundings, microorganisms lurking in the record grooves contribute to the record's background noise and the occurrence of pops and tics. These various organisms, according to Dr. Bruce Maier, founder of Discwasher, "produce vinyl etching enzymes." (see BAS, vol.3, no. 10, 1975.) Paper sleeves also contain and shed debris that is trapped by "sticky" record mold release compounds. (Note, other particles can also be trapped–and that's a compelling reason to clean brand new LPs.) Glassine paper is no better than ordinary paper because of its hygroscopic properties.
http://www.positive-feedback.com/Issue38/lp_sleaves.htmMyles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 23, 2014, 06:03 PM #57
This was a followup piece on Todd Garfinkle's new LP inner sleeve.
MA Record Sleeves
Bottom line is where you place your LPs after cleaning is very important too!Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 23, 2014, 06:13 PM #58
- May 2013
- 2,013
Good point with the humidity. Can't say that is a problem where I am at except just a few days a year perhaps in which case it is far more harmful to me than to my records or sleeves which remain uneffected.
That said though I refuse to purchase or even take for free, any record with signs of moisture being present on the sleeve at any time in it's life. I can remove all the fungus and bacteria in the grooves of the record in one shot, but I would not want to put it back into the outer sleeve with signs of moisture damage, I don't care how much audiophile poly there is wrapped around the record. I also don't enjoy going out and trying to find another copy of the sleeve in better shape either, so I just don't go there in the first place.
September 23, 2014, 06:16 PM #59
Thanks for the link and review Myles. I think I will order some to try !
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 23, 2014, 06:32 PM #60
- May 2013
- 2,013
Oh darn, so we blow up a few copper pipes to save our records. LOL!
Seriously though, every record gets cleaned in my house, new or used and for the very reason you state. I recently saw a silver face plate of a vintage receiver that was kept in some storage area where mice got in and partied. The face plate ended up looking like the surface of the moon without magnification. So I liken the microorganisms from waters, proteins and anything of the like floating around in the air or somehow getting on the record doing the same thing. Make all the more important to clean records and ditch all paper sleeves of any type and use new, clean, high quality/audiophile quality, HDPE inner sleeves such as MoFi or Diskeeper or similar (don't know about using these in humid climates though) and not even picking up any outer sleeves with signs of time in moisture at all.
Great article on sleeves Myles!
September 23, 2014, 06:39 PM #61
September 23, 2014, 07:01 PM #62
September 24, 2014, 08:41 AM #63
- Feb 2014
- 1,861
So would a bio-enzyme additive as used by the Audiodesk offer some further anti-fungal growth protection for vinyl whilst in storage where RH & temperature is higher?
Speakeasy
September 24, 2014, 09:12 AM #64
That's a good question Steve.
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 24, 2014, 09:38 AM #65
- Feb 2014
- 1,861
Fungal mould is the biggest & deadliest vinyl killer & it can spread throughout your collection. Even microscopic spores will lead to damage. RH % is not such a problem in Melbourne provided there is no persistent damp storage environment to begin with.
Of course there is a risk of spores spreading across washes with contaminated water. Filtration would help some & you would hope that ultrasonics would neutralise anything floating in the water. I would be very happy to live with minute traces of bi-enzyme residue on my washed & dried records if I knew that such traces were working as a protective barrier against potential fungal mould growth when in storage.
Speakeasy
September 24, 2014, 11:05 AM #66
- May 2013
- 2,013
Heat is not much to worry about unless it's enough to warp or comes with high RH. High RH even at room temp is a concern. Ultrasonics don't really neutralize anything, but does lead to breaking up, dissolving and removing most contaminants from your records. Using enzyme cleaners helps in attacking any protein-based contaminants and neutralizing fungal mold as would some sort of anti fungal mold growth protectant. (Although I don't know of anything that would be good to use on records off hand. I don't know that products like GrooveGlide provide that sort of protection and personally I would not use such a product as it does more harm to your stylus than it helps your records in any way. Perhaps someone here knows of something).
I think the best defense is making sure rinse water is nice and clean and using proper inner sleeves and where you store your records. I don't think the ultrasonic RCMs have a rinse cycle with separate water, do they? Of course, it's not really needed with the first 2 or 3 records, but after that I can well hypothesize that lighter contaminants that don't dissolve, such as spores could be floating around in the tank. I'm thinking one can change out the water of the RCM every 3 or 4 records, but that could be a PITA depending on how easy it is to do on any particular machine.
If the RCM has a good strong vacuum though, that should take care of anything not actually stuck to the record. Blow-drying and especially room air-drying (as in setting in a dish-rack or something) would not be as effective against spores as vacuuming. With blow-drying there is potential that the spores would still be floating in the air after being blown off. Of course, room air-drying has obvious draw-backs even to the casual observer. Not to illicit paranoia or something, but remember, just taking a record in and out of a sleeve to play it exposes it to having spores and other contaminants land on it. Of course, that's why we have carbon fiber brushes and such.
If RH is of concern, you could use the inner sleeves Myles suggested, otherwise you should not have much to worry about depending on where you store your records.
Don't store your records near any heat source of course and not in any areas that are prone to dampness (even a little), such as basements (unless it's a finished basement turned into a man-cave or something with climate control and all that), etc. Do not store near windows either.
Just my 2 cents.
September 24, 2014, 12:16 PM #67
- Feb 2014
- 1,861
When it comes to vinyl, no doubt I'm a paranoid vinyl Nazi with a systematic regime.
I wash new vinyl & re-sleeve with new MoFi inner sleeves before any play. After each play, I wash & use the new sleeve. I never sleeve a played record. That's why I bought the Audiodesk & a stack of consumables before getting back into vinyl & investing heavily into the medium & associated playback equipment.
I'm inclined to think that a bio-enzyme additive will help to disinfect the water & help to maintain machine tanked water purity levels longer. If there is a chemist with an Audiodesk and/or Klaudio, please run some extended water quality tests & post your results. Most of us, store our units filled with water, top up on evaporation & change the water periodically after x washes.
Speakeasy
September 24, 2014, 12:38 PM #68
- May 2013
- 2,013
...and there is not anything wrong with being a paranoid vinyl nazi with a systematic regime when it come to vinyl care. (Well, perhaps the "nazi" part may be a bit much).
So you wash and use a new sleeve after each play? I don't think you need to do that, but then I do not know your environment, so you may need to do that for all I know.
Hmm...I would think storing the unit filled with water is not a good idea. Think about it. A totally wet environment and also storage temperature could lead to bad bacteria and contaminate growth in the tank, especially if there are any things such as spores left over in it and it only takes one.
September 24, 2014, 01:18 PM #69
September 24, 2014, 04:41 PM #70
- May 2013
- 2,013
Was not aware that sonic action could do that. Makes me wonder why they don't use it more in medical procedures.
Yes, adding anything to the surface of a record is a no-no, that's why I recommend against products like GruvGlide and anything else like it. It not only effects the sound, but can potentially do harm to both the record and the cartridge.
September 24, 2014, 05:30 PM #71
US can be used to sterilize but there are more effective means.
But US is often used by biochemists to rupture cells and release the internal contents as say for doing enzymatic studies.
It's not necessarily how well RCFs work but what they leave behind that matters. Just as the issue with with vacuum machines is hydrodynamics. In other words, as the amount of fluid on the record decreases, the surface tension increases. So records cleaned with machines like the VPI Typhoon with big vacuum motors sound better eg. quieter, more transparent, etc. Of course one does have to be careful with high vacuum motors not to pull the plasticizer out of the record.
It's only a hypothesis but the sonic differences between the Audio Deske and KLaudio may simply be due to the AD's use of a surfactant in the water. IIRC correctly, MikeL commented somewhere that some people had actually reduced the amount of AD additive being added to the water.Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 24, 2014, 05:36 PM #72
- May 2013
- 2,013
I know US is also used for things like kidney stones, but that's all I'm aware of and that is not the effect we are talking about. I suppose there may be safety considerations regarding certain organs in the body as well if US was to be applied in such a way. You know, sure it killed the bad bacteria and all, but also killed the patient. Not the outcome we were looking for.
September 24, 2014, 05:43 PM #73
September 24, 2014, 06:44 PM #74
- Jun 2013
- 1,068
I wonder if this "fat" is what I have occasionally found on the surface of my new LPs that had a trip through the KLaudio? I mentioned I think in another thread. I occasionally find some small gobs of goo on the surface that did not exist when the new record went into the machine. I've had to use an enzyme cleaner to remove these, with a fair amount of scrubbing with a microfiber cloth.
I didn't know mold-release compound included a "fat" but it makes sense.
Maybe Miles can comment, he's the vinyl guru?
September 24, 2014, 07:03 PM #75
As I remember, there are some stearates in the vinyl mix. Mold release is always described as a type of PAM. As I understand it, it's not sprayed on but part of the plastic mix.
What I found with some cartridges, most notably the Atlas, is that there is a buildup of gunk on the stylus after playing. Noted the same thing with the Audio Deske too.Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
September 24, 2014, 07:18 PM #76
- May 2013
- 2,013
Thanks Myles, that sort of answers a theoretical question on my mind from way back.
I know the vacuums on machines such as the VPI Typhoon and even the 16.5 (could be the same vacuum) are strong, but I don't think they could pull the plasticizer out of a record, could they? They aren't atomic strength vacuums or something. Anyway, isn't the plasticizer added into the mix of PVC to make the record in the first place and therefore locked in you could say. I mean it doesn't sit on the surface or anything? Hmm...however, it does say in the instructions for all models of VPI machines and the Okki Nokki, Clear Audio, etc. "do not turn on the vacuum while the platter is not turning" or something to that effect, so that kind of makes one wonder. I mean, who is going to do that anyway, but still....
That said though, I would think the cleaning fluid used would have more effect if "pulling out the plasticizer" and whatnot. For instance, a mixture with too much alcohol of any grade would potentially do that, not to mention cause the protein-based contaminates to harden to the groove walls of the record making them next to impossible to remove.
Most record cleaning fluids have a surfactant added, I think. I wonder though if a US RCM would really need one though?
September 25, 2014, 07:42 AM #77
- Feb 2014
- 1,861
So how often do owners of the Audiodesk & Klaudio change their water?
I have had water in the Audiodesk for approx. 1 month, no smells or apparent nasties.
Even the rollers were still moist. I pulled them to check & they were as clean as a whistle. I have perspex cover on it with spacers, so it breathes & would evaporate very slowly. The unit sits in an Ikea Besta unit ready to be turned on & used. The doors show no condensation marks. I fired it up & ran a blank cycle just to recirculate the water.
Speakeasy
September 25, 2014, 08:43 AM #78
Every 100 cleans/cycles. I keep a log (pad of paper and check marks).
September 25, 2014, 08:51 AM #79
Steve, I think you are sounding a little paranoid about problems that don't really exist
I have been buying records for over 30 years now and only got an RCM probably 15 years ago. All my records from 20 and 30 years ago are still perfect, after many hundreds of plays.
The number one preventative maintenance I have always used is to have every lp in a plastic/poly lined inner sleeve. This protects your precious vinyl from everything - Period.
If you feel the need to buy more expensive mofi or whatever inner sleeves, knock yourself out, but they do exactly the same job as the cheap round bottomed plastic inners.
Having a RCM or US RCM really is cream, not necessary but hard to live without once you have experienced them.
CheersSource: Technics SP10mk3 - Thales Simplicity II, TW Raven AC-3 - Graham Phantom, SME 3012-R, Exclusive P3,,Linn LP12 - Naim ARO
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
September 25, 2014, 08:52 AM #80
My Klaudio US cleaner is on it's way to me, delivery scheduled for next Tuesday
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 25, 2014, 08:55 AM #81
Congrats Mark!
September 25, 2014, 09:01 AM #82
September 25, 2014, 09:04 AM #83
Good news Mark. Maybe you'll like it so much that you'll clean the record when you go to flip it over. 😃
Sent from my HTC One.Doug
September 25, 2014, 09:21 AM #84Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 25, 2014, 09:22 AM #85
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 25, 2014, 09:27 AM #86
September 25, 2014, 09:38 AM #87
- Feb 2014
- 1,861
Congrats Mark! Please post your experiences.
Speakeasy
September 25, 2014, 09:47 AM #88
- Feb 2014
- 1,861
Yeah, you're probably right. I only use one new MoFI sleeve per record, as they go back in washed.
My paranoia stems from 2 small gifted collections that were fungal ridden. One was from a house in a rainforest up in the Dandenong ranges. The other was from my ex wife! Both were duly disposed of.
Speakeasy
September 25, 2014, 10:34 AM #89
Mark
Pass Labs X350.8
Esoteric N-05XD
REL Subs
September 25, 2014, 12:15 PM #90
yes mark please let us know. im borrowing an audio desk for a couple weeks to try. i got to be honest and say i cut it out of the box brand new yesterday at the show and though it was very cheap feeling for a $3000 machine. but ill know better after i get it here and try it next week. so id be curious to your experiences with the klaudio. its about time i stepped up from the spin clean.lol.
congrats !!!!Steve
TUBES & VINYL
Is there anything else?
Rega/Ortofon/Viva 300b/KR
Music Reference 2A3
Altec/JBL
September 25, 2014, 07:54 PM #91
EQ: DEQX HDP-4
September 25, 2014, 08:40 PM #92
- Aug 2014
- 685
Analog-VPIClassic3-3DArm,Lyra Skala+MiyajimaZeroMono,2xAmpex ATR-102,Otari MX5050B2, Merrill Trident Tape Preamp, Herron VTPH-2A&BottleheadPhonoPre,
Dig Rip-Pyramix,IzotopeRX3Adv,MykerinosCard,PacificMicroso nicsModel2 AD
Dig Play-Lampi Horizon, mch NADAC Roon/HQPlayer,Oppo105
Electronics-DoshiPre,CJ MET1mchPre,Cary2A3monoamps
Speakers-AvantgardeDuosLR,3SolosC,LR,RR
Other-512 Engineering Tim Marutani Symmetrical Power IsoTrans and cables,AudioDiskVinylCleaner,
Music-2.3KR2Rtapes,1.5KCD's,500SACDs,60TBripped files
September 25, 2014, 09:08 PM #93
September 26, 2014, 07:59 AM #94
- Feb 2014
- 1,861
Ha! When the new lady came along, she inquired about the mound of dirt in the backyard. The mound looked like a grave. I told her "not to worry because 'she' is long gone, already a skeleton. Jack (my dog) dug part of an arm out, I'm always chucking dirt over it, the little digger he is....".
Out of 700, I saved approx. 100 after excluding most from a first round cleaning attempt. I have yet to play approx. 30. Vinyl condition EX or better after Audiodesk washes. Most sleeves are VG+ or better. New inner sleeves & poly/jap covers. I did my best to hang onto 60s vintage & not surprisingly the older heavy vinyl faired much better.
Speakeasy
January 1, 2015, 06:27 PM #95
January 1, 2015, 06:51 PM #96
Where is the cleaner that MF was talking about, when one can drop 8 records halfway into a vat and performs a similar process to the KLaudio Cleaner? I heard it was about $2K?
it was mentioned in this Youtube Video.
https://www.youtube.com/watch?v=hJotc_K0LQI
narrowed the spot, the above video is an hour long.
here: http://youtu.be/hJotc_K0LQI?t=51m45s
January 1, 2015, 07:10 PM #97Myles B. Astor, Senior Editor, PF, www.positive-feedback.com
January 1, 2015, 07:30 PM #98
January 1, 2015, 08:49 PM #99
Yes! ^ thank you thank you!
September 22, 2018, 09:59 AM #100
- Sep 2017
- Europe
- 150
Hi,
Just want to tell my experience with Audiodesk (not PRO). I wouldn't buy one again! The pump on mine broke down just 1 month after guarantee coverage finished and about 500 records cleaned. Luckily one might think, my version enabled a pump replacement as some earlier versions for some reason didn't. Instead of Audiodesk playing along with some goodwill, fully aware that plenty units have had problems, I was charged the healthy sum of 700 USD for the repair! Next time this unit will break down it will be scrapped and another non-Audiodesk unit will be looked for. Any suggestions?
It cleans ok, but even new pressings need sometimes 2 runs to be cleaned.
Not overly happy/MikeMain system: Aavik Acoustics U-300 (upgraded internals), Accuphase C47 + TechDAS AF V Premium + Kuzma 4P11" Gemstone/Kondo silver + Ortofon Diamond, Naim streamer SSD + TAD DA-1000 DAC, Sonus Faber Stradivari 35 Anniversary, mostly full cable loom Ansuz Acoustics, D and own silver constructions on signal side, Mainz DTC/D2 + Mainz8 D-TC power distributor. All individual equipment and cables rest on Ansuz Acoustics Darkz DTC (Tungsten balls). Dedicated mains supply (Audience Conductor) with Klangmodule fuse system and Furutech receptacles. Other systems: Collection of Sonus Faber classics (Franco S design), tube gear and transistor designs, CD-transports and players, turntables and collection of cables
Yes, and it does. Room costs (we had 3 rooms, including a large ballroom), materials, marketing, brochures, banners, all the staff, shipping, meals, hotel rooms, flights, etc. Figure on $40k. ...
Clarisys - Axpona 2024
