Results 1 to 11 of 11
Thread: Integrated Amp
July 31, 2014, 10:40 AM #1
Integrated Amp
My daughter tried to hook up my vintage NAD 3155 integrated to some speakers, but she crossed the speaker wires. I replaced the blown fuse and now only the right channel is working. I don't think the cost of getting it fixed would be worthwhile.
Soooooo. What should I look for boys? I need it to be able to switch between indoor and outdoor speakers, so this limits things (unless I get some kind of external switch box). Cost is definitely an issue - I want to keep this fairly cheap. Tubes would be nice.Vine, Vide, Velcro - I came, I saw, I stuck around.
July 31, 2014, 10:50 AM #2
Re: Integrated Amp
line mag 211ia el34 integrated, real nice and very inexpensive
Steve
TUBES & VINYL
Is there anything else?
Rega/Ortofon/Viva 300b/KR
Music Reference 2A3
Altec/JBL
July 31, 2014, 11:34 AM #3
July 31, 2014, 12:25 PM #4
Re: Integrated Amp
I want it to drive both my indoor speakers and outdoor speakers, so a switch on the unit allowing "A" or "B" or "A+B" is what I would prefer, or some kind of external box /switch that can accommodate the same.
July 31, 2014, 12:27 PM #5
July 31, 2014, 12:40 PM #6
Re: Integrated Amp
Find an old receiver, like a Marantz 2275, that has dual speaker connections. Then you can just turn a knob to select which speakers you want to listen to.
Doug
July 31, 2014, 12:57 PM #7
Re: Integrated Amp
Yeah; an A/B will be tough to find. Why not another NAD?
C 356BEE Stereo Integrated Amplifier - NAD ElectronicsCD
DAC/Pre-amp - PSAudio DsJ > Power-amp - > Speakers - PMC TwentyFive 23s
July 31, 2014, 03:10 PM #8
Re: Integrated Amp
It's easy to find a switch box that will suit my needs, so the A/B switch is not a deal breaker.
July 31, 2014, 07:22 PM #9
Re: Integrated Amp
What speakers will you be driving (please describe sensitivity, nominal/min/max impedance)?
Budget?
Is this primarily used for background music (obviously yes for outside speakers but are inside speakers your main listening speakers or just background)?Cyril
July 31, 2014, 09:23 PM #10
July 31, 2014, 11:27 PM #11
- Jul 2014
- Abbotsford B.C.
- 43
Re: Integrated Amp
Dirt cheap decent quality option with a tuner built in, Onkyo TX-8050 stereo receiver, 80wpc, sounds not too bad and can do the A/B switching, not glitzy but it'll get the job done.
Small bedroom 2 channel
Pioneer Elite DV-45A
Cambridge Audio Topaz SR20 Reciever
Wharfedale Diamond 225 Speakers
It's like music you're only as good as your latest hit, LOL Last year it was the minuet, this year, well, it wasn't. I notice that each online magazine seem to have their picks or favorites they...
