Results 301 to 313 of 313
Thread: AMG v12 TURNTABLES
August 17, 2019, 02:41 PM #301George
September 17, 2019, 09:30 PM #302
- Jan 2016
- Australia
- 24
Re: AMG v12 TURNTABLES
Bob, I traded up to a Turbo arm from the standard one for my V12 and the difference was a significant and worthwhile one. The Turbo arm is beautifully engineered and works seamlessly with the V12 turntable. Adjustments are much easier to make than with the standard arm. I agree with Marcus's comments above. I can't see why you would risk an incompatible match trying something else.
September 18, 2019, 07:06 PM #303
- Jun 2013
- 1,068
August 12, 2020, 06:09 AM #304
- Jan 2014
- 44
I just swapped out the 12JT arm as there’s some issue with the cables.
August 12, 2020, 06:09 AM #305
- Jan 2014
- 44
While the 12JT arm performs at a very high level, better arms do exist
August 15, 2020, 04:56 PM #306
What arm is that...?
/ Marcus, www.perfect-sense.sePERFECT SENSE
Showroom in Stockholm, Sweden | info@perfect-sense.se | 08 518 368 00 | Follow us on Facebook
August 15, 2020, 04:56 PM #307
August 15, 2020, 06:17 PM #308
August 16, 2020, 10:51 AM #309
- Jun 2013
- 1,068
Issue with cables on the 12JT, or the Durand? How does the Durand mate with the Viella?
February 7, 2021, 04:58 PM #310
- May 2018
- 1
How to remove the platter, in case the turntable needs to be leveled? I tried few different ways, but I wasn't able to remove the platter. Any suggestions is appreciated.
February 8, 2021, 04:16 AM #311
The platter can get a bit stuck due to vacuum I believe. Grab it firmly, pull straight up and turn it from side to side carefully until it slides loose.
/ Marcus, Perfect sense | Audio MattersPERFECT SENSE
February 8, 2021, 12:05 PM #312
- Jun 2013
- 1,068
I thought I recognized that arm, Mike Lavigne is very fond of these arms. Did it require a custom armboard?
(And for sure, the cable attachment is much more straightforward than the 12JT. Having the cable need to fit under the table and then turn 90 degrees to get the DIN plug up into the tonearm tower is a weakness in the design of the AMG arm, as is having the arm base free to rotate when adjusting VTA.)
February 8, 2021, 04:51 PM #313
- Jan 2016
- Solana Beach, CA
- 199
There is also a piece of black plastic around the spindle that has to be removed first. But no doubt, it is a PITA to remove the platter. I’ve cursed at it many times!
Analog source: AMG Viella 12; Ortofon Anna cartridge, van den Hul Crimson Stradivarius XGW
Digital source: Totaldac d1-twelve Mk2 DAC, Totaldac d1-player, Totaldac d1-streamer, Totaldac Live Power supply
Pre amp: VAC Master with phono
Phonostage: Constellation Andromeda
Amps: VAC 200iQ monoblocks
Speakers: Magico M3 with MPods
Cables: Synergistic Research Galileo SX speaker, phono, analog and digital interconnects
Power products: Synergistic Research Galileo PowerCell SX and Transporter Ultra. Galileo SX and SRX power cords. Keces P3 LPS for cable modem and router.
Agreed on the new series. Never could get into the older series. One of the reasons I like the newer series is Hiroyuki Sanadai's performance. I remember first seeing him in The Last Samurai.
Shogun
