Results 1 to 13 of 13
March 1, 2014, 01:05 AM #1
Vicoustic Panel - Mounting when Gluing to the Wall isn't an Option
I knew that Vicoustic Panels were the look I was going for, but gluing to the wall wasn't the answer for me. I wanted to hang them like a picture. The following is one way to make this happen...
For my application, I wanted two panels hung together to make a larger 2'x4' panel....
I started with a 19"x42" piece of 1/8" plywood - finished on both sides. It's important to recognize that the foam on the back of the panel slopes in and the plywood should be cut to fit the back of the panel. If using the front dimensions, your plywood will stick out and look messy.
Next, I spray painted the edges of the plywood black to help them blend with the black foam.
I used "Z Bracket" hangers as the way to attach them to the wall. The Z Brackets are a slim mount and allow for a generous amount of sliding that allow you to get the panels perfectly placed during final installation. Here, one of the brackets has been attached to the plywood.
Now it's time to start gluing the Vicoustic Panels to the plywood. I used Auralex Foamtak spray adhesive. I bought it at my local Guitar Center and it's made for acoustic foam applications.
Here, you can see the recommended application of glue. All around the perimeter and an "X" running through the middle. Notice the scrap piece of plywood I used to shield the glue from getting everywhere during application. A neat end-result is mandatory! Please excuse the terrible picture here....
Next, mount the second part of the Z Bracket to the wall. Notice, I only used the center screw of the mount. The panels are so light that one screw is more than enough, and because, even a dead-level mount can sometimes look out of level because of the things around it, using only the center screw will allow you to fine tune for a perfect look after mounting the panels.
Finally, after allowing the glue to dry with some weight applied to the panels, it's time to hang them on the wall. Why glue these things directly to the wall when an extra $20 and an hour of your time allows you to fine tune them in the current application and remove them altogether without damage to the foam or the drywall if needed?
Brent
Tannoy Canterbury GR; Allnic T2000 MKII; T+A DAC8 DSD; Audioquest Niagara 5000; iBuyPower 7700K Liquid Cooled PC; Roon (upconverting everything to DSD 512)
March 1, 2014, 01:22 AM #2
- Feb 2014
- 1,861
Re: Vicoustic Panel - Mounting when Gluing to the Wall isn't an Option
Good solution option. Well done!
Speakeasy
March 1, 2014, 01:23 AM #3
WOW...It was worth to send me a text at 12:20 AM lol .
Nice. Thanks for share. Excellent Job! Mr Handy man. Man....I wish you are near by.
I it ~!!!!!!!!!!!!!!!!Paul
March 1, 2014, 01:37 AM #4
Brent, good job, I like it.
March 1, 2014, 01:40 AM #5
Brent
March 1, 2014, 08:36 AM #6
Congrats! Great job. Very intuitive. I wonder if the Z brackets would have worked for an angled wall? I have a feeling the bottom would have pulled away.
March 1, 2014, 09:16 AM #7
Brent, that was really well done, excellent work !!
Mark
Kharma DB9 Signature
Pass Labs XP32......incoming
Pass Labs X350.8
Esoteric N-05XD
Manley Chinook Phono Pre
Kharma Elegance interconnects
REL Subs
March 1, 2014, 09:36 AM #8
Wow….Thanks. Looks great.
March 1, 2014, 11:52 AM #9
McIntosh MC501s, XRT29s, XR27, WS350s
ModWright LS 300 preamplifier
ModWright PH 9.0XT phono stage
Oppo UDP-205 with ModWright Signature Truth Tube Modifications
Cambridge Audio CXNv2 with ModWright Truth Tube Modifications
Clearaudio Performance SE TT with Hana ML MC cartridge
Outlaw 7000x HT Amplifier
Denon AVR-X4700H HT Receiver (pre-amp mode)
JL Audio F113 subs with CR-1 Crossover
ASC & RealTraps Panels; APS PurePower 2000; Daedalus Audio DiDs
WyWires, LAT International, Wireworld Cables
March 1, 2014, 01:06 PM #10
Brent
March 1, 2014, 01:12 PM #11
My room has a long way to go. The slap echo is still loud and proud after the installation of the Vicoustic panels....but only four were installed. I do notice an increased focus in the soundstage, but not a taming of highs quite yet. I have three GIK panels on the way that will be mounted on the ceiling that should go a long way in eliminating slap echo and tame the high frequencies a bit.
Brent
November 15, 2017, 04:32 AM #12
- Nov 2017
- 1
It still should be a lot better than without panels.
Did you install bass traps, too?
November 15, 2017, 11:04 AM #13
Welcome to the forum Pop, thank you for joining.
Good idea. We are working in the background to upgrade software and servers. Sent from my iPhone using Tapatalk Pro
Forum Software Update
