Page 2 of 2 FirstFirst 12
Results 51 to 56 of 56
  1. #51
    Re: Shunyata 6000S V2 Review
    Yoh K, Agree the Cheng was not a good match for my Tube Amp but Ok on the Digital front end-- yes certainly not on any serious power unit/regenerator/conditioner/etc.
    though I was told Nelson Pass packages the Cheng with his Units--interesting
    The Hirakawas were sonically cleaner and gave tad better openess to the staging in my setup.
    YVMV.
    Agree with you on the removal of some of the Hi End cabling bits and bobs--took gritting of teeth but worth it-ha!
    Bruce
  2. #52
    Senior Member
    Join Date
    Dec 2017
    Seattle Washington USA
    Posts
    1,170
    GSOphile, I have a Topaz line isolation transformer. I wired it in line to my power strip. It pretty much 100% evens out the fluctuations in intensity of humming in my system. It keeps it all at a very low level. So I know I have outside influences. But, it does not sound so good. You hear the transformer. I guess we are all hearing a utility transformer, and the transformers in out equipment. But I don't like the sound of iso transformers. I also have a medical Isolation transforner. Same thing.
    I need to test the denali again to see if it stops outside noise. That or get new amps that have a regulated power supply and are less susceptible to noise.
    I play music at night very quiet and it just sucks to hear loud buzzing in the evening when trying to relax. During the day its pretty quiet. You have to listen for the noise between songs. Its definitely there but not in your face.
  3. #53
    Senior Member
    Join Date
    Dec 2017
    Posts
    1,170
    FWIW, this thread is not about cables. But power cables are part of what connect to the Denali.
    Just one diversion. Even though I find some very inexpensive power cables sound good. The exact opposite is true of speaker, digital and to a degree interconnexts. Crappy digital cables are harsh, grating and cloudy. Same for speaker. Interconnect are sensitive but not as intense a negative impact with low quality as the impact of a bad ethernet, usb or speaker cable.
  4. #54
    Senior Member
    Join Date
    Oct 2018
    Argentina
    Posts
    416
    Quote Originally Posted by CGabriel View Post
    Thanks for the information Caelin. I would like to know if they will come out of 4 outlets too, or only 8? Thank you.
  5. #55
    Senior Member
    Join Date
    Mar 2017
    North Carolina
    Posts
    811
    Kingrex, sounds like you already know what you need to do first, rather than putting more/different perfume on the pig.
  6. #56
    Junior Member
    Join Date
    Apr 2019
    Maui
    Posts
    19
    Hi Caelin. Any news on the Denali T V2? I need to get a new conditioner and was about to buy a 6000s V2.
    Main system
    SME 20/12 turntable, SME 3012 arm. Soundsmith Strain Gauge Cartridge. Lumin X1 streamer/DAC. Luxman D-10X SACD player. Luxman C-900u Pre-amp. Luxman M-900u Power amp. Revel Ultimate Salon 2 speakers. Purist Audio Designs cables. Shunyata Power Cables and Conditioners. Finite Elemente Stands and Feet.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
