Results 1 to 25 of 25
January 28, 2020, 10:29 PM #1
- Jan 2019
- 41
(Solved) - Lumin Cannot Detect Music Server
Hello
I am using a USB device to read files from. When I select Music Library in the app I see NOTHING! Any suggestions?
January 28, 2020, 10:55 PM #2
- May 2013
- 3,242
Re: Lumin Cannot Detect Music Server
Providing Peter with a little more information than that about your gear and setup might solicit a more useful suggestion.
January 28, 2020, 11:11 PM #3
- Jan 2019
- 41
Ok...I have my Lumin hardwired to a Netgear extender. The WPS light is solid green. The light on the back of the Lumin where the network cable is Green and Amber. I did recently change internet providers and since then have had no luck having my Lumin Mini U to communicate with my USB (music server) it seems. I am able to use my IPAD and connect to the internet without issues. When I go to setup and select music library nothing happens. I have reboot, repowered , reinstalled and I don't know what else to do. Let me know if I can provide anymore info.
January 28, 2020, 11:25 PM #4
- May 2013
- 3,242
Have you re-booted the whole network chain or just the Lumin?
January 29, 2020, 12:29 AM #5
- Jan 2019
- 41
January 29, 2020, 12:53 AM #6
Can you take any old laptop computer and connect it to the end of the cable that would normally plug into your Lumin, and surf the web? If no internet access is available at the end of that cable, then investigate your Netgear Extender to upstream router connectivity. You may have to reboot the router and extender and then do the WPS sequencing all over.
If you do have internet connectivity at the end of the cable that interfaces with your Lumin, then start looking at your USB to Lumin link and reboot the USB drive/device and/or start checking cables, IP settings on server, etc.
Does your server have both IP connectivity and USB connectivity direct to your Lumin? What Lumin model?Avanti Audio
January 29, 2020, 01:13 AM #7
- Jan 2019
- 41
January 29, 2020, 01:17 AM #8
- May 2013
- 3,242
Can you use the Lumin as it's currently setup and get to Tidal or Qobuz but just not your server?
January 29, 2020, 01:18 AM #9
Is your USB Server connected via Ethernet cable or wirelessly to your home network? Is the USB server also directly connected via USB cable to the Lumin?
What is your USB Server?Avanti Audio
January 29, 2020, 01:25 AM #10
- May 2013
- 3,242
I thing he's just connecting a stand alone USB drive directly to the Lumin. Might want to plug that HD into a laptop or desktop and make sure it's still readable by them.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
January 29, 2020, 01:27 AM #11
Logical next step if its a stand alone drive, Jack.
Avanti Audio
January 29, 2020, 01:47 AM #12
- Jan 2019
- 41
USB drive is connected to the Lumin. No internet radio to choose from. Nothing really shows up on the left side of the app. The display on the Lumin does show my last playlist. Just the numbers...no song names.
January 29, 2020, 02:17 AM #13
No idea what a Mini U is, but I have a Lumin X1 with a 1 TB HD directly attached to the USB port, and that works fine. I see all the files on the Lumin app on both my iPad, and iPhone. However, you say the light on the HD is on solid. That is opposite to the drive on my X1. The only time the drive light is on for me is when it flickers reading a song. Is your drive okay? Can you read it attached to a PC?
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
January 29, 2020, 02:23 AM #14
- May 2013
- 3,242
So you can't get outside on the Lumin at all? No streaming services or Internet Radio. You do have an account with TuneIn and are signed in I am assuming. If your Lumin can't see the Internet then it and your control device can't see each other either. Who is your internet provider?
January 29, 2020, 08:11 AM #15
It happens the same to me my A1 can not detect correclty my USB hard drive connected to the back of the A1.
I was informed it is due some problem with the App (I have a Samsung Tab 3 which is Android and not IOS).
Hope Lumin send a new firmware update for Android in order to solve this and other problems (Tidal does not have any possbility of sort).
Good luck.McIntosh C302 + C2600 - Lumin A1 - Lenco L75 - Marantz SR6007 - Paradigm S6 - Gaia II - Chord Epic Twin Speaker Cable + Jumpers - Bada LB5500
January 29, 2020, 11:03 AM #16
- Jan 2019
- 41
January 29, 2020, 11:04 AM #17
- Jan 2019
- 41
January 29, 2020, 01:27 PM #18
Spectrum is my provider. I use an NAS with my Lumin U1. I have no problem with internet radio (from memory I had to set up a gmail account to sign in to TuneIn Radio - http://www.luminmusic.com/streaming-services.html - see the bottom of the page).
January 30, 2020, 04:44 AM #19
- Jan 2014
- 152
Remember that attached drives need to be single-partition only (and formatted FAT32, exFAT and NTFS only - but this is common).
Another quick test would be to connect a small USB pen-drive/thumb-disk with a couple of very standard WAV files on there.
I think you said that in the app, you could see the USB server show up on the settings under Music Library. That suggests that the LUMIN is showing up on at least the local network correctly.[Associated with LUMIN]
January 30, 2020, 08:59 AM #20
- Jan 2019
- 41
January 30, 2020, 09:03 AM #21
- Jan 2014
- 152
Does Peter still post on this board?[Associated with LUMIN]
January 30, 2020, 10:55 AM #22
- Jan 2019
- 41
Just an update
-I believe I am having an issue with my wifi extender now...so I will reset that again.
-I noticed that the Lumin has a reset button on the back, I will reset that if the extender works and I still do not see the USB drive.
-I will see about logging into my router and see if the Lumin is being blocked somehow.
I wanted to thank everyone on this forum for helping me with this. Much appreciated.
January 30, 2020, 09:24 PM #23
- May 2013
- 3,242
Wasn't aware of the wifi extender but yes if you changed ISP's you will have to do a factory reset on the extender and start over as when it was new. The new provider has a different domain and DNS and the extender was still looking for the old provider while your iPad was signed into the new one. Once you get the extender reset and seeing the network you will have to re-boot the Lumin and the iPad to get them all linked up again as before the ISP swap.
January 30, 2020, 10:49 PM #24
- Jan 2019
- 41
January 31, 2020, 12:50 AM #25
- May 2013
- 3,242
Glad you got it all worked out. It's almost always a network issue.
Clarisys Arrives at Puur...
