Results 1 to 47 of 47
January 10, 2020, 11:44 AM #1
- Jan 2020
- HK
- 23
Lumin App crashes after updated to 6.1.14
Just updated the Lumin App on my IOS 13.3 iPad to the latest 6.1.14 version. Display of Album, etc are fine.
But when I tap a song to play, the app crashes and quit.
Please help fix
January 10, 2020, 12:18 PM #2
Re: Lumin App crashes after updated to 6.1.14
Welcome to the forum.
January 10, 2020, 01:02 PM #3
Welcome to AS!
I upgraded to the Lumin 6.1.14 version of their app this morning. I have an iPad running on iOS 13.3. The Lumin app is working flawlessly. Loaded and played music from my library and from Tidal with no issues.
May want to shutdown and restart your iPad._______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
January 10, 2020, 01:26 PM #4
If it still crashes, please find the crash log from Settings - Privacy - Analytics - Analytics Data and send it to info@luminmusic.com
Meanwhile you can use Esoteric Sound Stream app.Peter Lie
LUMIN Firmware Lead
January 10, 2020, 04:42 PM #5
I just had the upgrade as well , and dont have any issues so far. , apart from that i will say welcome to the forum , and hope you will get your problem solved.
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
January 10, 2020, 09:47 PM #6
I'd like some clarification on this: where did you tap the song to play? In the left hand side playlist (that you've already had music added), or in the right hand side where you're adding from a NAS? If you're doing it on the right hand side, was that a single tap or double tap? If you hold the album or track then add via pop-up, does it crash? Still waiting for your log.
Peter Lie
LUMIN Firmware Lead
January 10, 2020, 11:21 PM #7
- Jan 2020
- HK
- 23
Thanks everybody for quick reply.
Hi Peter, just sent you the crash log.
The app was working fine up to the last 6.1.13 without any issue since two, three years ago.
6.1.14 crashes when I tap a song on the right hand side in album view, genre, etc. It crashes immediately when I tried adding song(s) to playlist as well.
Tried reset my iPad and install the app. Also, tried running the app after resetting my iPad. None helps.
Tom
January 10, 2020, 11:28 PM #8
- Jan 2020
- HK
- 23
Hi Peter,
I have also sent you the log for version 6.1.13, which was working fine on my iPad for your reference.
January 10, 2020, 11:39 PM #9
- Jan 2020
- HK
- 23
Hi Peter,
Just downloaded the Esoteric Sound Stream app. It works fine without any issue.
I am having the Lumin app running at the same time. Lumin doesn't see any song I am playing in the Esoteric app.
My other music app, fidata and Kazzo, can see the song I am playing in the Esoteric app.
January 10, 2020, 11:58 PM #10
- May 2013
- 3,242
Because it's an earlier version of the same app. If you want even another color screen try the Teac version.
January 11, 2020, 12:20 AM #11
- Jan 2020
- HK
- 23
Thanks Jack. Just did and Teac's theme is more appealing to me.
BTW, my other iPad with 6.1.12 on it can see the music playing.
Seems like something wrong with the part sending music to the player. The latest version sees my player but crashes when sending music to it.
January 11, 2020, 12:29 AM #12
- May 2013
- 3,242
I just switched to my second system and when I opened the Lumin app it did the update and is playing fine.
January 11, 2020, 12:58 AM #13
While I am sure the poster has an issue, I suspect it is with his gear/software. It is working fine for me on an iPad mini, and an iPhone 7.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
January 11, 2020, 01:17 AM #14
- Jan 2020
- HK
- 23
Just updated the app on my iPhone XR to 6.1.14, and it crashes the same. It works ok before the udpate.
My Cary Audio DMS-600 is connecting to QNAP HS453DX NAS via lan cable. There are about 5,000 albums and 60,000 songs on the NAS. I am using TwonkyServer paid version.Tom
January 11, 2020, 01:36 AM #15
- May 2013
- 3,242
Just curious why are you using the Lumin app on a Cary streamer instead of their designated app and also not using Minimserver insted of TwonkyServer as Lumin suggests.
January 11, 2020, 01:40 AM #16
- Jan 2020
- HK
- 23
The Cary streamer is a new purchase. I have been using the app for a few years and simply got used to it.
I prefer TwonkyServer over Minimserver as it comes with more choices for display settings and preferences.Tom
January 11, 2020, 02:00 AM #17
- May 2013
- 3,242
That kind of confirms Bluefox's assertion earlier that your problems are system specific. I would suspect that as time goes one the updates to the Lumin app are aimed at the products they officially support and not situations like yours. Unless there are others that I don't know about the Lumin family of apps which include the Teac and Esoteric app are designed for compatibility with the products they have app support agreements with. That is probably why the Esoteric and Teac versions still work as they haven't been updated in some time. In the case of the Teac app over a year. If those two apps still work the way you are used to then just use one of them and be happy. Really not up to Peter and his team to revise their apps for other products. I have had to revert to the Teac app several times when a specific Lumin app caused an issue that was later fixed unintentionally. The very latest updates are usually Lumin product specific and may or may not work with other brands. Same with using TwonkyServer instead of Minimserver.
January 11, 2020, 03:32 AM #18
- Jan 2020
- HK
- 23
I was using X1 until recently I replaced it with the Cary. It's natural that I keep on using the App since it is still compatible with the Cary. Will you or others do the same ?
If Peter or the company says the latest update is Lumin specific and no longer supports other brands, surely will not using it any more.Tom
January 11, 2020, 03:59 AM #19
Bud
Sony XA-5400ES SACD
January 12, 2020, 12:50 AM #20
- Jan 2020
- HK
- 23
January 12, 2020, 09:30 PM #21
January 12, 2020, 10:30 PM #22
- Jan 2020
- HK
- 23
Yes, it does. On the other app "fidata", it shows Open Home next to the server name.
I've been using the app for a few month with my new DMS-600 on iPad Pro 11-inch. It's been working flawlessly up to 6.1.13. My another iPad with version 6.1.12 still works without any issue.
Is there a way to send me an older version so that I can install it manually ?Tom
January 12, 2020, 10:34 PM #23
To my knowledge technically there is no way to do this on iOS.
Peter Lie
LUMIN Firmware Lead
January 12, 2020, 10:37 PM #24
- Jan 2020
- HK
- 23
Noted and I'll wait for your update.
Tom
January 12, 2020, 10:38 PM #25
Tom - I did a quick search and found this site which appears to still have older versions of the Lumin app available including 6.1.13. You can translate the site easily in Chrome, and hopefully Peter can confirm it as a legitimate source for their software. Hope this helps!
January 12, 2020, 10:43 PM #26
- Jan 2020
- HK
- 23
January 13, 2020, 10:48 AM #27
January 13, 2020, 12:27 PM #28
- Jan 2020
- HK
- 23
January 18, 2020, 08:34 AM #29
- Jan 2020
- HK
- 23
There's another user reporting the same issue on Apple App Store.
Tom
January 18, 2020, 08:45 AM #30
Still running flawlessly for me.
_______________
January 19, 2020, 12:50 AM #31
- Jan 2020
- HK
- 23
January 19, 2020, 02:36 AM #32
Based on e-mail feedback, so far crashes of this type only occur to app users without Lumin hardware.
Peter Lie
LUMIN Firmware Lead
January 19, 2020, 02:58 AM #33
- May 2013
- 3,242
Peter
Are there any features on the latest Lumin update that would apply to the operation of the Cary device any differently than the Teac or Esoteric versions of the app? I have switched back and forth between all three apps and never found an operational difference with the NT-505.Main - JVC QL-Y7/Denon DL-301 Mk II, Gold Note PH-10, Jays CDT3 Mk3 , Auralic Aries G2.2, Holo May KTE, Supratek Cabernet, Kinki Studio EX-B7 monoblocks, Verity Audio Otello, (2) Rythmik F12SE, Audio Envy IC, SC & PC's, Triode Wire Lab PC's, Inakustik USB and I2S, (2) Puritan Audio Labs PSM-156 with Groundmaster City, Timbernation rack
January 19, 2020, 03:06 AM #34
We never put in anything that blocks non-Lumin hardware users from using our app on purpose (so far). The only thing that is hardware specific is the hardware settings. So this issue is unexpected.
Peter Lie
LUMIN Firmware Lead
January 19, 2020, 03:13 AM #35
- May 2013
- 3,242
So he loses nothing from a function standpoint by sticking with the other two apps.
February 2, 2020, 10:43 PM #36
- Jan 2020
- HK
- 23
Thanks for the note, Peter.
Not sure what changes you have put in 6.1.14. If it is hardware specific, just wonder why your 6.1.12 and 6.1.13 still work normally without any issue.
I can't help suspecting it's the new changes that cause the issue.
Anyway, thanks for your effort.Tom
February 4, 2020, 09:29 PM #37
Please try 6.1.15 and see if it makes any difference (or not).
Peter Lie
LUMIN Firmware Lead
February 4, 2020, 11:23 PM #38
- Jan 2020
- HK
- 23
Thanks very much, Peter.
Just downloaded and tried. Followings are the results on my iPhone XR and iPad Pro 11-inch
1. Music server connected and loaded without any issue (using Twonky and MinimServer)
2. Songs can now be played as usual without any Crash.
3. Songs and Ablums can be added without issue.
New Problems:
1. NOTHING shows up in the playlist side. It's totally blank. However, the playlists are shown normally in the Esoteric Sound stream and HR streamer apps.
2. There are NO controls on the top right hand corners, even when songs and albums are being played. (see image 1)
3. However, when I go to Settings and then quit from it, Controls show up now. But only Volume works; other controls are disabled. (see image 2)
Above are pictures captured on my iPad. Same things happened on my iPhone.
I opened HR Streamer and Egoteric Sound Stream simultaneously, the playlists are shown normally.
One suggestion: since version 6.1.12 and 6.1.13 work normally, you may rework the updates from these two update points again -- Probably you are doing it already.
Also, the font for album name on the playlist in 6.1.13 is different from 6.1.12; not sure if it has anything to do with the issue; just a thought.
BTW, since we are both in Hong Kong, you can contact me by phone or whatsapp 9470-3803 for more details about the issues and my system, if needed.
Thanks very much
TomTom
February 5, 2020, 12:14 AM #39
We have not experienced these problems with Lumin hardware or even Linn hardware.
Peter Lie
LUMIN Firmware Lead
February 5, 2020, 12:47 AM #40
- Jan 2020
- HK
- 23
It is the same piece of hardware and firmware that I am using for the last 6 months with 6.1.12 and 6.1.13, and even earlier versions.
My NAS is Qnap's HS453DX. It is connected to the Cary via Ethernet connection. The NAS does have a few firmware and Multimedia Console app updates. But I don't think they causes the issue as the new 6.1.15 reacts the same when I connect to another server on Synology NAS.Tom
February 5, 2020, 02:41 AM #41
I'm afraid we don't have a Cary or other competitors' products. We keep a Linn for compatibility testing (Linn created OpenHome after all).
Peter Lie
LUMIN Firmware Lead
February 5, 2020, 02:41 AM #42
- Jan 2020
- HK
- 23
February 5, 2020, 02:44 AM #43
- Jan 2020
- HK
- 23
Tom
February 5, 2020, 03:19 AM #44
- Jan 2020
- HK
- 23
February 16, 2020, 02:51 AM #45
- Jan 2020
- HK
- 23
No worry, Peter.
I've found a better app.Tom
February 16, 2020, 11:35 AM #46
February 17, 2020, 01:49 PM #47
Upgrade on the way...
