Results 1 to 47 of 47
  1. #1
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Lumin App crashes after updated to 6.1.14
    Just updated the Lumin App on my IOS 13.3 iPad to the latest 6.1.14 version. Display of Album, etc are fine.
    But when I tap a song to play, the app crashes and quit.
    Please help fix
  2. #2
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Re: Lumin App crashes after updated to 6.1.14
    Welcome to the forum.
  3. #3
    Senior Member
    Join Date
    Jul 2013
    Florida
    Posts
    3,848
    Welcome to AS!
    I upgraded to the Lumin 6.1.14 version of their app this morning. I have an iPad running on iOS 13.3. The Lumin app is working flawlessly. Loaded and played music from my library and from Tidal with no issues.
    May want to shutdown and restart your iPad.
    _______________
    Phono Pre: Pass XP-27
    Speakers: MBL 101E MKII
    Rack: Artesania Exoteryc
  4. #4
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    If it still crashes, please find the crash log from Settings - Privacy - Analytics - Analytics Data and send it to info@luminmusic.com
    Meanwhile you can use Esoteric Sound Stream app.
    Peter Lie
    LUMIN Firmware Lead
  5. #5
    Senior Member
    Join Date
    Aug 2016
    Denmark
    Posts
    639
    I just had the upgrade as well , and dont have any issues so far. , apart from that i will say welcome to the forum , and hope you will get your problem solved.
    Flemming
    Lumin X1
    Rotel Michi S5
    Focus Audio FS788
    LS cable : Yter
    Nordost QB8
    Rack : Finite Elemente Pagode
  6. #6
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    Quote Originally Posted by tmtsui View Post
    I'd like some clarification on this: where did you tap the song to play? In the left hand side playlist (that you've already had music added), or in the right hand side where you're adding from a NAS? If you're doing it on the right hand side, was that a single tap or double tap? If you hold the album or track then add via pop-up, does it crash? Still waiting for your log.
    Peter Lie
    LUMIN Firmware Lead
  7. #7
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Thanks everybody for quick reply.
    Hi Peter, just sent you the crash log.
    The app was working fine up to the last 6.1.13 without any issue since two, three years ago.
    6.1.14 crashes when I tap a song on the right hand side in album view, genre, etc. It crashes immediately when I tried adding song(s) to playlist as well.
    Tried reset my iPad and install the app. Also, tried running the app after resetting my iPad. None helps.
    Tom
  8. #8
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Hi Peter,
    I have also sent you the log for version 6.1.13, which was working fine on my iPad for your reference.
  9. #9
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Hi Peter,
    Just downloaded the Esoteric Sound Stream app. It works fine without any issue.
    I am having the Lumin app running at the same time. Lumin doesn't see any song I am playing in the Esoteric app.
    My other music app, fidata and Kazzo, can see the song I am playing in the Esoteric app.
  10. #10
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Because it's an earlier version of the same app. If you want even another color screen try the Teac version.
  11. #11
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Thanks Jack. Just did and Teac's theme is more appealing to me.
    BTW, my other iPad with 6.1.12 on it can see the music playing.
    Seems like something wrong with the part sending music to the player. The latest version sees my player but crashes when sending music to it.
  12. #12
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    I just switched to my second system and when I opened the Lumin app it did the update and is playing fine.
  13. #13
    Senior Member
    Join Date
    May 2013
    Silicon Valley
    Posts
    2,838
    While I am sure the poster has an issue, I suspect it is with his gear/software. It is working fine for me on an iPad mini, and an iPhone 7.
    Bud
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Three 20 amp circuits.
  14. #14
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Just updated the app on my iPhone XR to 6.1.14, and it crashes the same. It works ok before the udpate.
    My Cary Audio DMS-600 is connecting to QNAP HS453DX NAS via lan cable. There are about 5,000 albums and 60,000 songs on the NAS. I am using TwonkyServer paid version.
    Tom
  15. #15
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Just curious why are you using the Lumin app on a Cary streamer instead of their designated app and also not using Minimserver insted of TwonkyServer as Lumin suggests.
  16. #16
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    The Cary streamer is a new purchase. I have been using the app for a few years and simply got used to it.
    I prefer TwonkyServer over Minimserver as it comes with more choices for display settings and preferences.
    Tom
  17. #17
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    That kind of confirms Bluefox's assertion earlier that your problems are system specific. I would suspect that as time goes one the updates to the Lumin app are aimed at the products they officially support and not situations like yours. Unless there are others that I don't know about the Lumin family of apps which include the Teac and Esoteric app are designed for compatibility with the products they have app support agreements with. That is probably why the Esoteric and Teac versions still work as they haven't been updated in some time. In the case of the Teac app over a year. If those two apps still work the way you are used to then just use one of them and be happy. Really not up to Peter and his team to revise their apps for other products. I have had to revert to the Teac app several times when a specific Lumin app caused an issue that was later fixed unintentionally. The very latest updates are usually Lumin product specific and may or may not work with other brands. Same with using TwonkyServer instead of Minimserver.
  18. #18
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    I was using X1 until recently I replaced it with the Cary. It's natural that I keep on using the App since it is still compatible with the Cary. Will you or others do the same ?
    If Peter or the company says the latest update is Lumin specific and no longer supports other brands, surely will not using it any more.
    Tom
  19. #19
    Senior Member
    Join Date
    May 2013
    Silicon Valley
    Posts
    2,838
    I might try something different, but if something was wrong I would go back to the X1 and verify the issue.
    Bud
    Sony XA-5400ES SACD
  20. #20
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Quote Originally Posted by BlueFox View Post
    "Replaced" normally means the unit was sold for another device. No audiophile will keep a device forever, I believe.
    Tom
  21. #21
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    DMS-600? Does it support OpenHome (which Lumin app requires)? I don't see this feature listed in its specifications.
    Peter Lie
    LUMIN Firmware Lead
  22. #22
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Quote Originally Posted by wklie View Post
    Yes, it does. On the other app "fidata", it shows Open Home next to the server name.
    I've been using the app for a few month with my new DMS-600 on iPad Pro 11-inch. It's been working flawlessly up to 6.1.13. My another iPad with version 6.1.12 still works without any issue.
    Is there a way to send me an older version so that I can install it manually ?
    Tom
  23. #23
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    To my knowledge technically there is no way to do this on iOS.
    Peter Lie
    LUMIN Firmware Lead
  24. #24
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Noted and I'll wait for your update.
    Tom
  25. #25
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Tom - I did a quick search and found this site which appears to still have older versions of the Lumin app available including 6.1.13. You can translate the site easily in Chrome, and hopefully Peter can confirm it as a legitimate source for their software. Hope this helps!
  26. #26
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Quote Originally Posted by audio.bill View Post
    Thanks a lot Bill. The information are comparing different versions. Don't see any link for download.
    Tom
  27. #27
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    Sorry about that... my mistake!
  28. #28
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Not at all. Thanks
    Tom
  29. #29
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    There's another user reporting the same issue on Apple App Store.
    Tom
  30. #30
    Senior Member
    Join Date
    Jul 2013
    Florida
    Posts
    3,848
    Still running flawlessly for me.
    _______________
  31. #31
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Quote Originally Posted by Ritmo View Post
    Good to you but there are still people cannot run the app.
    Tom
  32. #32
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    Based on e-mail feedback, so far crashes of this type only occur to app users without Lumin hardware.
    Peter Lie
    LUMIN Firmware Lead
  33. #33
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    Peter
    Are there any features on the latest Lumin update that would apply to the operation of the Cary device any differently than the Teac or Esoteric versions of the app? I have switched back and forth between all three apps and never found an operational difference with the NT-505.
  34. #34
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    We never put in anything that blocks non-Lumin hardware users from using our app on purpose (so far). The only thing that is hardware specific is the hardware settings. So this issue is unexpected.
    Peter Lie
    LUMIN Firmware Lead
  35. #35
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    So he loses nothing from a function standpoint by sticking with the other two apps.
  36. #36
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Thanks for the note, Peter.
    Not sure what changes you have put in 6.1.14. If it is hardware specific, just wonder why your 6.1.12 and 6.1.13 still work normally without any issue.
    I can't help suspecting it's the new changes that cause the issue.
    Anyway, thanks for your effort.
    Tom
  37. #37
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    Please try 6.1.15 and see if it makes any difference (or not).
    Peter Lie
    LUMIN Firmware Lead
  38. #38
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Thanks very much, Peter.
    Just downloaded and tried. Followings are the results on my iPhone XR and iPad Pro 11-inch
    1. Music server connected and loaded without any issue (using Twonky and MinimServer)
    2. Songs can now be played as usual without any Crash.
    3. Songs and Ablums can be added without issue.
    New Problems:
    1. NOTHING shows up in the playlist side. It's totally blank. However, the playlists are shown normally in the Esoteric Sound stream and HR streamer apps.
    2. There are NO controls on the top right hand corners, even when songs and albums are being played. (see image 1)
    3. However, when I go to Settings and then quit from it, Controls show up now. But only Volume works; other controls are disabled. (see image 2)
    Above are pictures captured on my iPad. Same things happened on my iPhone.
    I opened HR Streamer and Egoteric Sound Stream simultaneously, the playlists are shown normally.
    One suggestion: since version 6.1.12 and 6.1.13 work normally, you may rework the updates from these two update points again -- Probably you are doing it already.
    Also, the font for album name on the playlist in 6.1.13 is different from 6.1.12; not sure if it has anything to do with the issue; just a thought.
    BTW, since we are both in Hong Kong, you can contact me by phone or whatsapp 9470-3803 for more details about the issues and my system, if needed.
    Thanks very much
    Tom
    Tom
  39. #39
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    We have not experienced these problems with Lumin hardware or even Linn hardware.
    Peter Lie
    LUMIN Firmware Lead
  40. #40
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    It is the same piece of hardware and firmware that I am using for the last 6 months with 6.1.12 and 6.1.13, and even earlier versions.
    My NAS is Qnap's HS453DX. It is connected to the Cary via Ethernet connection. The NAS does have a few firmware and Multimedia Console app updates. But I don't think they causes the issue as the new 6.1.15 reacts the same when I connect to another server on Synology NAS.
    Tom
  41. #41
    Senior Member
    Join Date
    Jul 2014
    Hong Kong
    Posts
    3,078
    I'm afraid we don't have a Cary or other competitors' products. We keep a Linn for compatibility testing (Linn created OpenHome after all).
    Peter Lie
    LUMIN Firmware Lead
  42. #42
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    By the way, the Controls on the top right hand side also were not shown in the 6.1.14 version, in which the app crashed when a song was tapped. So, the issue is not new to 6.1.15.
    Tom
  43. #43
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    I'm afraid we don't have a Cary.
    Not really sure if it is the hardware issue since the 6.1.12 and 6.1.13 are still working perfectly. Also, the Controls on the top right hand side also were not shown in the 6.1.14 version. So the issue isn't new to 6.1.15.
    Tom
  44. #44
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    Regarding the disappearing of Controls on the top right hand corner, they show up again ONLY after I tapped on the options in "Stream Icon Location" item. Hope this helps.
    Tom
  45. #45
    Junior Member
    Join Date
    Jan 2020
    HK
    Posts
    23
    No worry, Peter.
    I've found a better app.
    Tom
  46. #46
    Senior Member
    Join Date
    Aug 2013
    Chicago suburbs
    Posts
    1,583
    No worry, Peter.
    Would you care to share what it is?
  47. #47
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    783
    No worry, Peter.
    Linn Kazoo?
    Marcin
Posting Permissions
  • You may not post replies
  • You may not edit your posts
