Results 1 to 12 of 12
November 14, 2019, 07:24 AM #1
- May 2016
- 574
Can I "bottleneck" my system using a superior speaker cables but, lower end interconnects from same brand?
Hi,
This is most likely subjective but, wanted to get some feedback to this question.
I also certainly don't want to start a "cable war" :-) by posting this. Thus i don't even want to mention the brand of cable.
Let's say I have the opportunity to purchase a set of speaker cables that are top in their product portfolio.
However, I'm still using a "lesser' model throughout the rest of my system. For example, on my interconnects.
The question is ; Am I "bottlenecking" my system by using such good speaker cables if my interconnects aren't of equal caliber?
For example, if it isn't captured at the source then what is the point of having high end speaker cables?
Or, is it best to save money and just for a full loom/system of the entire line of interconnects and speaker cables throughout my system?
November 14, 2019, 08:33 AM #2
Re: Can I "bottleneck" my system using a superior speaker cables but, lower end interconnects from same brand?
Tough questions and so many factors involved. I see these questions on another forum where most peoples gear won't even reveal cable differences. I personally have had more luck hearing differences with ICs and PCs than with the few Speaker cables I have swapped around.
I have tamed a bright system with ICs touted to have more bass, and they did.
So, depending on your own gear, it's synergy, and your preferences in sound, some will suggest full loom, others will say experiment as best you can. The Cable Company lets you borrow cables.-----------------
Brian
November 14, 2019, 08:35 AM #3
I would say no. My theory is that the cables that carry the most current are most important:
Power, than speaker, than IC.
I would say it’s only a bottleneck if you don’t do it.
But please don’t ignore the power cables. The Shunyata NR series is excellent and will really help lower the noise floor.My Systems: http://www.audioshark.org/showthread...481#post158481
November 14, 2019, 01:06 PM #4
Tend to agree, any upward move should provide an improvement.
November 14, 2019, 01:19 PM #5
- May 2017
- Cleveland, Ohio, USA
- 534
No, speaker cables are a different ballgame.
November 14, 2019, 10:58 PM #6
Power is King!
Speakers: Wilson Alexias
November 14, 2019, 11:11 PM #7
Full loom is King Kong .
November 14, 2019, 11:17 PM #8
Power is King, it’s what you’ll hear, get it right and your on top, ignore it and your leaving sound in the box!
November 14, 2019, 11:17 PM #9
November 14, 2019, 11:24 PM #10
November 15, 2019, 07:51 AM #11
- May 2016
- 574
November 15, 2019, 07:53 AM #12
- May 2016
- 574
Dave, another choice may be the Cambridge Audio MXN 10. $499 on Amazon. High-level specs: StreamMagic Gen 4 Module – fast music retrieval & high-quality sound ESS SABRE ES9033Q DAC – for the...
Streamer selection
