Results 101 to 150 of 240
Thread: Accuphase E-800
February 22, 2020, 11:32 PM #101
February 23, 2020, 12:45 AM #102
Re: Accuphase E-800
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
February 23, 2020, 10:47 AM #103
- Apr 2016
- 590
Re: Accuphase E-800
Glad to hear you are happy. One way to confirm is for you to reach out to Accupahse Japan with the Serial number and confirm who the original Dealer is. If its been tampered with you will know then.
There is also no way for me to have direct knowledge as I would never spend any money on a 100V device.
March 9, 2020, 12:39 AM #104
Re: Accuphase E-800
EQ: DEQX HDP-4
April 5, 2020, 07:35 PM #105
- Apr 2018
- 26
Re: Accuphase E-800
Has anyone compared the E650 to the E800, and would care to comment on specific differences in the two? Currently own the 650 and considering selling it for an 800, but listening to one is almost impossible. Would appreciate any feedback.
Thanks
April 12, 2020, 08:33 AM #106
Re: Accuphase E-800
My E-800 arrived several days ago. With about 150 hours on the clock, I continue to be amazed with its performance.
April 12, 2020, 09:04 AM #107
Re: Accuphase E-800
Congratulations with your E-800 , i am sure its great , as i enjoy my E-470 and know that the E-800 is much better
Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
April 12, 2020, 09:07 AM #108
- Oct 2017
- 25
Re: Accuphase E-800
Hi Greg, can you please describe how the E-800 compares to luxman 590axii.
Thank you.
April 12, 2020, 09:21 AM #109Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
April 12, 2020, 02:38 PM #110
- Apr 2016
- 590
Re: Accuphase E-800
Congrats, post some pics as some of us cant view them on that other forum
April 12, 2020, 02:56 PM #111Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
April 13, 2020, 07:55 AM #112
April 13, 2020, 10:42 AM #113
Re: Accuphase E-800
It’s a chunky integrated, but I like the looks.
April 13, 2020, 11:39 AM #114
Re: Accuphase E-800
Hi Joe - yes it does look a bit chunky but I am getting used to it!
April 13, 2020, 11:47 AM #115
Re: Accuphase E-800
I’m so happy for you. And, a little jealous. Enjoy in great health.
April 13, 2020, 11:48 AM #116
June 1, 2020, 10:12 AM #117
- Oct 2017
- 25
Re: Accuphase E-800
Just pulled a trigger trading my Luxman 590axii towards Accuphase E-800. I did not hear it, but trust the recommendation of the dealer who I know for a long time. He is saying that that model sounds as good as A-48 amplifier and C-2850 pre-amp. When I asked him if its a just jumper change only to switch power to US based, he told me that as a final step they insert the transformer for US models specifically designed for US voltage.
June 1, 2020, 11:55 AM #118
Re: Accuphase E-800
June 1, 2020, 12:52 PM #119
- Oct 2017
- 25
Re: Accuphase E-800
Let me rephrase,
When I asked my dealer if for the gray market units from accuphase it's just a jumpers change to switch to US 120v, he told me - no, it is not possible anymore. Currently, before shipping to US distributor, any model that intended to be used in US gets transformer specifically manufactured for the US market. This dealer (and I assume any legit US dealer) will never be selling any gray market audio.
June 1, 2020, 01:17 PM #120
Re: Accuphase E-800
Okay
Thank you for the clarification.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
June 1, 2020, 03:41 PM #121
June 7, 2020, 01:32 PM #122
- May 2020
- England
- 16
Re: Accuphase E-800
When I look at Luxman amps and Accuphase amps, they look like they were designed by the same ampbuilder/designer, all the same nobs, meters just the chassis metal covering looks different. If I was forced to purchase one of the amps without audition how would you describe is the difference in their Sound Quality?
June 10, 2020, 12:19 PM #123
Re: Accuphase E-800
Accuphase = detailed, sterile and un-engaging
Luxman = detailed, warmth and very engaging
Accuhase
I really didn't know how much I loved Luxman until I had both brands in my audio room.
June 10, 2020, 12:43 PM #124
- Aug 2014
- lachen / sz
- 1,061
Re: Accuphase E-800
i find accuphase to sound good. on the negtive side i would say they are a bit soft, so it is very musictaste dependent.
June 10, 2020, 12:56 PM #125
June 10, 2020, 01:16 PM #126
Re: Accuphase E-800
The real challenge with Accuphase, at least in the US, is that few dealers actually stock any Accuphase gear. I would venture to say that more than 50% of US buyers have purchased the E-800 without hearing it first. There has been a significant amount of hype (emulating from one dealer in particular) about this amp being in a "different zip code" in terms of comparing it to the E-650. I owned the E-600 and I would characterize the difference between Accuphase models being more along the lines of "super sizing" a Mc Donald's meal.
The difference that my Luxman 900 combo brought to the table compared to the E-800 was not subtle. Of course, YMMV.
June 10, 2020, 01:35 PM #127
Re: Accuphase E-800
Greg and Paul: does your comparison between Accuphase and Luxman apply to their Class A offerings or to their Class AB integrated amps as well? Also, how would Esoteric’s integrated stack up relative to the other two brands?
Gary
Main: Lumin A1, Accuphase E-650, Tannoy Canterbury GR, Shunyata, Audience
Secondary: Lumin M1, Linton Heritage, Shunyata, Audience
June 10, 2020, 01:52 PM #128
Re: Accuphase E-800
Accuphase A-75, C-3850, DP-750, T-1200, C-37, P-530 / Magico S7, Mcoat Red w/Mpod / LessLoss C-MARC Entropic cables (Spk. IC's PC's) / Clearaudio Innovation Wood, 9" Universal arm ,VTA adj. Outer Limit platter ring, Statement clamp / SteinMusic PI Carbon Signature Mat /My Sonic Lab Ultra Eminent EX MC cart./ Clearaudio 24v Battery PSU / Magnum Dynalab Signal Sleuth / B]Onyx Plus[/B] Sirius XM Sat Radio / Synergistic Research Galileo PowerCell SX ,Active Ground Block SE ,Black Box ,Acoustic ART, Atmosphere Infinity ,UEF panels /Stillpoints Apeture II panels /Furutech GTX-D NCF duplex outlets, NFC Booster-Braces/ 20a dedicated lines / SteinMusic H2 Harmonizers / Adona Eris II 5C racks / Symposium Acoustics Svelt Shelves /HRS Damping plates / KLAudio Ultrasonic RCM / Clearaudio Smart Matrix Pro. RCM /Kemp Electroniks SR plugs,/ Akiko Audio Corelli PLC,Tuning Sticks/ LessLoss Firewall 640X, Blackbody v.2, BlackGround Power Base 10X, Blackground Speaker Base 8X, Firewall for speakers
June 10, 2020, 01:58 PM #129
- Aug 2014
- lachen / sz
- 1,061
June 10, 2020, 02:02 PM #130
Re: Accuphase E-800
Hi Gene - based on my personal listening preferences and experience with the amps, I would say the hyperbole is not warranted. I would argue that the Luxman L-590AXII actually sounds as good, if not better than the E-800 at less than half the MSRP. I had high hopes for the E-800 - don't get me wrong, it's a great integrated amp and it performs very well, just my cup of tea. I have wanted very much to like Accuphase but each it seems like I keep coming home to Luxman. At this level, it is always a question of personal preference and I respect those who own and love Accuphase!
June 10, 2020, 02:08 PM #131
- Oct 2017
- 25
Re: Accuphase E-800
Greg interesting how your opinion is changing within few weeks. On A-gon forum you wrote:
the AccuphaseE-800 is the real deal. Its performance is simply amazing. I was not totally enamored with it when I initially had it in my audio room and after 250 hours or so, I actually considered going back to Luxman. I did, however, decide to give it some more time and it was improved significantly after 400 hours. It is a keeper.
I did not buy my E-800 (waiting for delivery in 2 weeks) from cape code dealer. The dealer I bought mine from, I know for a long time and he is the largest accuphase dealer in US. I trust his ears. His recommendations hav been proven many times. He is saying that E-800 sounds exactly like his c-2850 and a-48 combo. According to him its a very unique and specially made model.
Greg, what is your digital source; luxman d-05u? I think one need at least luxman d-08u or esoteric k-03xs or DCS rossini to properly evaluate downstream gear of this caliber. But I may agree with you, that the luxman 900 series combo is outstanding, especially considering its price.
As for me I always prefer integrated for simplicity and cost efficiency. The luxman 590axii I have now is outstanding for the price, but I decided to jump for E-800 since its more powerful, has much better dumping factor, has much better binding posts than Luxman 590axii and its an accuphase limited edition model. I am sure I made a right choice, even so I did not hear e-800. Well of course I will say it...lol. And one more thing, if anybody in US is buying accuphase for a full retail - they are not making a wise decision.
June 10, 2020, 02:49 PM #132
Re: Accuphase E-800
All that I said was correct at the time until I actually compared the E-800 to the Luxman 900 combo. While I would have perhaps been happy with the E-800, through a series of fortunate events, I was able to purchase the Luxman 900 combo at a very, very good price. I figured I would take the plunge and see how the two set ups compared. As for sources, I don't play my SACD player that much. I stream music with Lumin U-1 and Chord DAVE DAC.
I will say this about the E-800, the power comes on incredibly quickly. I was actually shocked at how loud it played at the "2" setting on the volume control! You are correct about pricing on Accuphase, Once should expect at least a 30% discount off US list price.
June 10, 2020, 02:51 PM #133
- Aug 2013
- Canada
- 246
Re: Accuphase E-800
Did you compare the E-800 with Luxman separates? or integrated? What are the speakers you’re using? I had the Accuphase C3850/A200 3 years ago. Haven’t tried any newer Luxman gears.
June 10, 2020, 02:53 PM #134
June 10, 2020, 03:09 PM #135
Re: Accuphase E-800
Guys - I am not trying to bash Accuphase or the E-800. In my case, it did not make the cut when compared to the Luxman 900 separates. I have no doubt that most new owners will be thrilled with their E-800s!
June 10, 2020, 03:10 PM #136
- Jul 2013
- Orlando, FL
- 250
Re: Accuphase E-800
Thanks for describing the differences and your experience listening to all of these.
It's interesting that there are so many varying opinions of the "Accuphase sound" when one reads threads all over the place.
Would you say that Class A, in and of itself, doesn't give an indication of the sound of the component?
I can't remember - did you try the Gryphon Diablo, too? For some reason I thought you did.Christian
south: Mark Levinson No. 52 pre, Bricasti M28 amps, Lumin A1, Oppo BDP-205, Pioneer CT-43, Sony SS-AR1 Speakers, Audioquest PCs, Audioquest speaker cables, Audioquest & Iconoclast interconnects, HB Power Design Powerslave Star Galaxy power distributor
north: Vitus SIA-030, Luxman D-10X, Sony TC-KA3ES, Harbeth 40.2, Siltech cables
June 10, 2020, 03:30 PM #137
Re: Accuphase E-800
Christian - you raise a very relevant point regarding one's expectation of Class A indication of sound.
I used to think Class A meant warmth, or perhaps a closer stride towards the warmth of tubes but based on what I have owned, I would venture to say that has not always been the case for me. My first Luxman L-590AX represented to me what a Class A amp should be, it had warmth and detail with a sweet, engaging musical presentation. My second Luxman, the L-590 AX II, improved upon that. Now the questions becomes, at least for me, was it the Class A that I liked so much or was it the Luxman sonic signature?
It was my belief however (right or wrong) that it was the Class A magic that I was after - hence the purchase on many other amps, including the Gryphon Diablo 300 (purchased from Miike) in pursuit that "just right sound".
June 10, 2020, 03:39 PM #138
Re: Accuphase E-800
The Diablo 300 isn’t class A. Folks loving their Diablo 300 have got to hear the Essence stereo amp. That’s class A and woefully underrated power wise. Me thinks it’s a Antilleon Evo in a Essence chassis. I have one on order.
Greg, congrats on the Luxman combo. You know what I think of it! I used it with the M6’s/Q-Sub 18’s at the Florida Audio Expo. They’re THAT good!
Sent from my iPhone using Tapatalk ProMy Systems: http://www.audioshark.org/showthread...481#post158481
June 10, 2020, 04:43 PM #139
- Aug 2014
- lachen / sz
- 1,061
Re: Accuphase E-800
class a is a big world by its own with so many various designs.
the best ones sound clear, pure and rich. pass xs pre and xs amps as the best example.
accuphase in general is a bit on the tame and soft side. not my cup of tea either.
they have great synergy with some speakers. for piega speakers it is one of the best pairings. guess it does generally well with the brighter side of tweeters.
as well i guess the luxmans have a lot more grip, especially if you have the monos. nothing wrong with prefering the luxman over the accuphases
June 10, 2020, 04:49 PM #140
- May 2020
- England
- 16
Re: Accuphase E-800
On just the build and looks both Accuphase and Luxman products look sumptuous, on just the looks the Luxman wins it for me because of its silver looks and those pristine nobs, but I read that some owners of the Luxman do not like the 'cheap binding posts' so maybe there is a chink in Luxmans armour? I would love to audition both brands either using seperates or Integrated amps with reasonable power output but that would be very difficult to arrange in UK as I don't know any dealer who stocks both brands? Even trying to audition a Accuphase amp is not straight forward as the nearest dealer would be not so near and would only stock a very limited range of Accuphase. Its also a mystery to me what warranty is offered on a Accuphase component in UK?
June 11, 2020, 12:21 AM #141
Re: Accuphase E-800
Hi Oly. In my case it was just on Class A comparison as I mentioned the E650 vs 590 axII on my 107db speakers.
I also like the Esoteric class A at the dealer with same speakers as mine. I found the Esoteric sound some what similar to Accuphase.
June 11, 2020, 02:08 AM #142
Re: Accuphase E-800
Thanks, Paul. That’s very helpful.
Gary
June 11, 2020, 10:14 AM #143
Re: Accuphase E-800
That may well be the case, though I doubt it’s a “US-spec”transformer they use, rather than internal wiring of the 110V tap for the USmarket.
It’s certainly true that Accuphase take on board allregional safety and environmental regulations, for example their EU-destinedmodels include a “go to standby” feature after a period of no input signal, andtheir speaker sockets can’t be used with bananas unless the coloured plasticparts have their knock-out patches knocked out. Peter
Sources - NAD M50.2 (streamer, CD player, CD ripper, hard drive music store)
Amplification - NAD M33 all-in-one, NAD M12 preamp (in reserve), Atma-Sphere Class D monos
Speakers - Avantgarde Duo XD, Avantgarde Duo (2006) - both aesthetically modified
June 11, 2020, 04:28 PM #144
June 12, 2020, 12:01 PM #145
- Apr 2016
- 590
Re: Accuphase E-800
Very interesting thread. I hope that everyone reading has learned to take what you read with a grain of salt. If you simply rely on peoples testimony online, even when they are from genuine owners (who really knows who they are or what their motives are), then you are doomed to fail in your pursuit of this hobby.
June 12, 2020, 12:05 PM #146
- Apr 2016
- 590
Re: Accuphase E-800
If I was to take a guess I would think this whole recent special "US-spec" transformer story is a bunch of bull. Rest assured that no Manufacturer wants to increase their parts count or complexity of components/assembly. If there is enough money and desire behind it then perhaps they will... but again, rest assured that the US and Canadian Distributors are cheap, barely surviving and they are not paying for this customization.
June 12, 2020, 12:09 PM #147
- Apr 2016
- 590
June 12, 2020, 01:10 PM #148
June 13, 2020, 06:17 PM #149
- Apr 2016
- 590
Re: Accuphase E-800
Yes, we all know you don't agree with their pricing. Don't buy it and move on.
June 13, 2020, 08:35 PM #150
Yes, the Digital Director was used in that setup with MSB monoblocks, and Magico M2's.
