Results 1 to 26 of 26
Thread: Lumin Network Transport
September 15, 2019, 09:57 AM #1
- Jan 2019
- 13
Does Lumin have any plans to release a transport only model that features fiber and ethernet connection, like the X1? The U1 has only ethernet connectivity.
September 18, 2019, 03:53 AM #2
Re: Lumin Network Transport
As far as I know, there wont be such transport from LUMIN round the corner. But I can tell you that the performance of the X1 as a transport exceeds the U1, An U1 with the X1 power supply is also a very interesting combo.
LUMIN / WestminsterLab
September 18, 2019, 09:17 AM #3
- Jan 2019
- 13
Thanks for your reply, Iscangus. Has anyone compared the transport section of the X1 to the Bryston BDP-3 or the Auralic Aries G2?
September 19, 2019, 10:46 PM #4
- Apr 2016
- 590
I have... without using the “audiophile” nonsense the Lumin is a much more natural sounding transport. The Lumin app is miles ahead of Brystons interface.
September 19, 2019, 11:02 PM #5
- Mar 2019
- La Canada, CA
- 50
I owned the Aries G2 sold it and bought the U1. I'm glad I did.
September 19, 2019, 11:43 PM #6
- Jan 2019
- 13
Thanks for giving your opinions. I am currently using the transport section of the Lumin X1 into a Bryston BDA-3 DAC connected via the USB output of the Lumin. I use the optical fiber and not the ethernet connection to the Lumin. Also running Roon with the Nucleus Plus as my Roon core. The sound is excellent.
Since I have the Bryston DAC I was wondering if there was some kind of synergy with the Bryston digital players. I guess not....
September 20, 2019, 12:26 AM #7
Why not use the X1 DAC instead of the Bryston DAC? You will eliminate the interconnect and power cable to the DAC.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
September 20, 2019, 12:38 AM #8
- Jan 2019
- 13
The internal DAC of the X1 is excellent sounding. But the Lumin allows no digital input to connect to it. I use the Bryston DAC to stream the classical music sites Idagio and Primephonic. I can Airplay these to the Lumin but I experience intermittent dropouts and pauses in the music. Also the Bryston allows me to connect my CD player or CD transport to it as well.
September 20, 2019, 01:12 AM #9
Okay. Thanks.
Bud
Sony XA-5400ES SACD
September 21, 2019, 08:53 AM #10
- Apr 2016
- 590
In that case simply sell the the X1 and buy a U1 mini. I dont see why you have a $14K player feeding into a $3800 DAC.
September 21, 2019, 09:05 AM #11
September 21, 2019, 07:17 PM #12
- Jan 2019
- 13
dznutz and Andik777, I have thought about doing that. But it doesn't make sense for a few reasons. That is why I was asking about other transports such as the Bryston digital player and the Auralic. The consensus is that the X1 is better. And even Iscangus says that the X1 transport is better than the U1.
The transport is the foundation of your digital streaming . The analogy is the Linn philosophy of turntable first. You are suggesting that I sell the superior X1 and downgrade? If you were telling me to get the superb Extreme server, all 100 pounds of it and over 26K, then I would understand. And the Bryston DAC is excellent sounding as well, especially paired with the X1.
The economics also doesn't make sense. The 14K X1 would sell for only a fraction on the used market. I would then have to buy another transport. That would leave me with an inferior transport with very little cash left over.
September 21, 2019, 07:34 PM #13
- Apr 2016
- 590
The transport matters but the DAC matters more. I cant argue with your logic either.
September 21, 2019, 07:45 PM #14
- Jan 2019
- 13
Also, keeping the X1, I always have the option to upgrade the DAC. But I'm very happy with the Bryston for the present.
September 21, 2019, 09:37 PM #15
- Jan 2019
- 13
Does the DAC matter more than the transport? My friend with the Extreme Server says the opposite. He claims that any DAC he uses with the Extreme sounds good.
Both the Lumin X1 and the Extreme use fiber connectivity. Coincidence?
And while we are discussing transports has any one done any comparisons with the highly regarded Innuos Statement?
September 22, 2019, 08:47 AM #16
@audiobear
Sorry for this hijack, but I am very interested in your comment about streaming Idagio via Bryston without using Airplay. I did not think that possible without a Sonus piece of hardware.
How do you do it? I too have had dropouts with Airplay while streaming Idagio.Lumin A1
Pre Amps: Mini DSP SHD, Threshold NS-10 (Recapped)
Amps: Modwright KWA150SE, Threshold 400A (Recapped)
NAS: Synology DS1513+
Turntable: VPI HW19 MKIV DVxx2mkII Moerch arm VPI SDS
September 22, 2019, 10:38 AM #17
- Jan 2019
- 13
Here is how I stream Idagio and Primephonic into the Bryston DAC. This also works for youtube, etc.
I use the Idagio and Primephonic apps for my ipad. Connect an Apple Lightning to USB adaptor to your ipad. Then use a USB cable from the ipad to the Bryston USB input. Works perfectly with no dropouts at all. Sound quality is OK but not as good as streaming classical from Qobuz. But Qobuz has a very limted selection. You can find almost any performance you want from the 2 dedicated classical streaming sites. Idagio is limited to 16/44 whereas Primephonic has (very few) higher resolution recordings. Airplay, other than the dropout problem, is limited to only 16/44.
Hope this helps, rodrigaj.
September 22, 2019, 07:10 PM #18
- Jan 2019
- Singapore
- 37
September 22, 2019, 08:50 PM #19
September 22, 2019, 08:53 PM #20
Bud
Sony XA-5400ES SACD
September 22, 2019, 10:48 PM #21
If you're having audio dropouts using AirPlay, it's usually due to either less than ideal network conditions (e.g. slower Wi-Fi, or too much competing network activity) or a slower transmitter like an old computer. Assuming no bugs or other issues in the hardware or software involved.
In terms of sound character and quality, the DAC should make a much bigger difference than the transport, as long as the transport is not outputting incorrect data.Neko Audio
September 23, 2019, 09:09 AM #22
- Jan 2019
- Singapore
- 37
September 23, 2019, 09:11 AM #23
- Jan 2019
- Singapore
- 37
September 23, 2019, 09:19 AM #24
I agree on both counts.
The dropouts I experienced with airplay were too infrequent and too short lived to do any kind of trouble shooting. I gave up my Idagio subscription after 8 months because of them. The OP's solution unfortunately is not a viable one for me.
Regarding the transport, for a while I owned a Sonore ultraRendu and found that functionality matters far more than the difference in sound quality between transports.Lumin A1
September 23, 2019, 11:35 AM #25
Bud
Sony XA-5400ES SACD
September 27, 2019, 12:02 AM #26
Anyway, to finish my posts, the X1 is better than the S1 with an X1 power supply. The musical soundstage is wider, more open, and more powerful than the S1 with an X1 power supply. I can only imagine what the Z1 will be like. Now that I am retired I am saving my money for it.
Bud
Sony XA-5400ES SACD
