Results 51 to 74 of 74
Thread: Audionet STERN & HEISENBERG
February 20, 2020, 12:00 AM #51
- Sep 2014
- 40
Re: Audionet STERN & HEISENBERG
Hello
Did anyone had the opportunity to directly compare this combo to Dartzeel preamp /monoblock ?
Thanks
Alex
Sent from my SM-N9500 using Tapatalk
July 22, 2020, 12:25 PM #52
- Jun 2015
- 4
May I ask if you still would prefer the Stern over the L1 (with or without X1) with a different amp neither Heisenberg nor CH Precision? At the moment I play music with an EMM Labs DV2 directly feeding two EMM Labs MTRX2 amps and I'm not sure if the DV2 is able to completely replace a preamp.
Now I have the chance to get either a demo L1 or a Stern (with a better offer for the Stern) but don't know which way to go and which preamp would be the better match.
July 26, 2020, 04:23 PM #53
- May 2017
- Guildford, UK
- 123
I would put them in the following order, best to worst: L1 + X1, Stern, L1, all listened with Berning Quadrature Z's as power amps. It therefore depends on whether you think you'll end up with the X1 if you go the L1 route, and if you ever think you will change the power amps. If so, then Audionet wins for me. If not, then depends on X1.
Adding the X1 to the L1 adds the strengths that the Stern has around noise floor and soundstaging to the L1. L1 has a bit more flow to the music than the Stern, hence the L1 + X1 outperforming.
July 26, 2020, 04:36 PM #54
I also thought of the Stern but since i'm getting Mephisto stereo i will most likely purchase L1+X1.
Speaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
Headphone Rig : Hifiman HE-1000SE - Kennerton Ondin Mk2 - Chord Hugo 2 - Smartphone - Qobuz & Tidal.
July 26, 2020, 04:41 PM #55
If you're planning to go the CH route, the A1.5 or M1.1 makes more sense partner with L1 (+X1 potentially) than mixing things up with Gryphon in my opinion. Borresen has great synergy with CH as well as Audionet.
/ Marcus, Perfect sensePERFECT SENSE
www.perfect-sense.se
Showroom in Stockholm, Sweden | info@perfect-sense.se | 08 518 368 00 | Follow us on Facebook
July 27, 2020, 09:17 AM #56
- Jun 2015
- 4
Many thanks, heihei, for your response and the ranking. If I'd go with the L1 I'll definitely consider also a X1, but that's roughly double the cost of the offered Stern. So I have to negotiate with myself if L1+X1 is worth the extra effort.
At the moment I have no plans to change my MTRX2 amps, they are quite something. For me it's more the question if the EMM DV2 will be outperformed with either the L1+X1 or the Stern or if it the outcome is rather a matter of taste.
Unfortunately I can't compare the preamps for myself before buying, therefore I don't really know if I should invest such an amount blindly. I also tried to ask other DV2 owners if they already compared it with any ultra High-End preamp, but it always ends just in a theoretical discussion about pro and contra preamps vs. volume controls in Dacs. Fact is that the DV2's volume control implementation is different than others.
July 27, 2020, 11:58 AM #57
I happen to have the four box CH X1-L1 mono preamp paired with Gryphon Mephisto monos.
I am hoping to be able to do a direct comparison of the Heisenbergs and CH M1.1 in my system in the near future if logistics work out. But until then, I can tell you that CH L1-X1/Mephisto combo provides a wonderfully live musical experience - not a weak link in any sense of the word.
Sent from my iPhone using TapatalkRockport Lyra speakers; TotalDac Amp-1 mono blocks; four box CH Precision L1/X1 pre/power supply monos; CH precision P1/X1 phono/power supply; TotalDac d1-driver monos; Pacific Microsonics Model 2 DAC; TotalDac d1-12 MkII DAC with two reclockers; Kodo The Beat Turnatable with LT Schroder magnesium tonearm and Lyra Atlas cart; Taiko Extreme server; Kalista Dreamplayer CD Transport; Taiko Audio Daiza Platforms; Nordost Odin2 Power Cords and Analog ICs; 512 Engineering/Tim Marutani Balanced Transformers (30 amp for sources; 50 amp for amps); Rives designed dedicated room.
July 27, 2020, 03:18 PM #58
- Aug 2014
- lachen / sz
- 1,061
i would love to read a mephisto-heisenberg comparison.
also....@heihei, i remember you mentioned you and your friend will probably have the opportunity to compre the stern/heisi vs the humboldt. did that ever happen?
December 21, 2020, 09:43 PM #59
- Aug 2014
- lachen / sz
- 1,061
December 22, 2020, 04:02 AM #60Speaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
December 22, 2020, 05:54 PM #61
- May 2017
- Guildford, UK
- 123
December 23, 2020, 05:49 PM #62
- Aug 2014
- lachen / sz
- 1,061
humboldt is incredible, sound and pricerelative wise, no doubt. best sound i have ever heard. as i have stated sometime before, power is its only limit.
burning in was a pain, the stage was as small as a coin for weeks.
heisenbergs seems to be different burn in. they are excessive in every sense.....lol, very very massive. the little sabrinaX sounds like a big clubspeaker.
i do enjoy it, yes. potentially a lot better than with the humboldt.....if all that weight gets more structure.
November 1, 2022, 11:00 PM #63
- May 2021
- Australia
- 65
November 4, 2022, 07:09 PM #64
- Aug 2014
- lachen / sz
- 1,061
hi icutoo. glad to hear you wanna fly
certainly there is headroom above the humboldt. imho, for longterm satisfaction the answer is simple and clear: get a deal on a pair of heisenbergs!
from what i hear from others the heisenbergs are ways more refined, balanced, soundstage vs mephisto.
and mephistos performance seems to be quite system dependent while heisenbergs have a 100% positive feedback around the globe in various systems.
hey, gryphon is cool, however it is dark vader at best and sharp grills in 2022 is i dont know what to say. i mean if you can get the mephisto for an incredible price, sure, go for it. most likely it will be fun to expirience and should outperform the humboldt.
November 5, 2022, 04:10 AM #65
- May 2021
- Australia
- 65
Hi, u-sound.
I think you are quite right- what I need is a pair of Heisensbergs.
The Humboldt is clarity and tone-colour personified, the Mephisto is control and power without limit. Stunning volumes without any loss of control or pitch or timbre. Heisenbergs should give me both.
But they are SO expensive- I will have to think about the compromises I am willing to accept, knowing that they are out there...
November 8, 2022, 05:18 PM #66
November 16, 2022, 05:40 PM #67
- Aug 2014
- lachen / sz
- 1,061
i really like the humboldt. with the little wilson tuntots it was a match in heaven.
beside sonics, it was pefect power, very juicy. when i switched to sabrina x, it was still nice but far from unlimited. with the heisenbergs, it sounds unlimited again. only big amps sound like big amps, question of torque.
your question is good, since they are buildt out of the same parts, so in some ways its steroids only, but the subjective impresission is quite dramatic. much more stable, the realism, etc etc.
the humboldt is like you can watch them perfectly, the heisenberg is an invitation to be with them.
the comment of my closest audiophile friend who joined my journey was: the humboldt is a toy. well, that was with the sabrina x which is known to be powerhungry. the difference with other speaker and smaller rooms might be much smaller.
overall, i cant describe how happy i am still after 2 years. have heard a lot of other top amps since and never ever even thought about to change.
that said, a friend from germany has a very similar system....heisenberg, wilson, nordost....and evaluated a lot of pre amps with the heisenbergs and stated the heisenberg would sound a 1000 times better with the nagra hd pre hv than the stern.
cut the story short, big shock, i should get one of thouse in about 10 days.
i feel a bit stupid as the sound is perfect right now and dont want anything else. i am scared of the nagra pre, lol. part of the deal is to sell the humboldt and stern, so i have no way back.
will do an update when i know more.
November 16, 2022, 08:04 PM #68
- Aug 2014
- lachen / sz
- 1,061
since you already have a top system, my recommendation would be to follow a strategy of patience.
focus on your weakest links in the system, find out a couple of dream replacements and then wait until one of them comes around for a very good price. i can tell you from experience that whatever you dream of in audio, withhin 2 or 3 years you will get it for less than half price.
November 18, 2022, 10:41 AM #69
November 18, 2022, 10:58 AM #70
- Aug 2014
- lachen / sz
- 1,061
thx yes, going to report, really thinking about it a lot myself. got to tell it to my wife somehow as well...
November 29, 2022, 06:54 PM #71
- Aug 2014
- lachen / sz
- 1,061
very happy, nagra hd pre works fantastic with the heisenbergs.
tonality is almost identical as with stern, a bit more natural, ease, lushness and substantial more low level information. big thx to the universe!
i got an unused unit, then again it is not the new hv version. about 100 hours now and cant imagine further improvements.
December 16, 2022, 07:04 AM #72
I would be very interested to know if there would good synergy between the Vitus SL-103 linestage and the Heisenbergs.
December 16, 2022, 02:16 PM #73
Not happy with the SIA-025 anymore ?
Do you know where the changes are between the mkI and mkII SIA-025, don't see anything on the Vitus website, also I don't see the mkII anywhere on the backplates of the SIA-025.
I am still on the fence between the SIA-030 and the Humboldt, slight advantage for the SIA-030 at the moment.Moon 700i V2, YG Acoustics Hailey, Aurender N10, dCS Rossini, Oppo BDP103D (audiopraise board), Ansuz Mainz 8 D2
December 16, 2022, 02:39 PM #74
Yes i am for now but for my speakers i will need to go monoblocks at some point when funds permit.
The difference between Mk1 and Mk2 is only 50w class A/B more for the Mk2 version if i recall.
If you can afford the SIA-030 or the Humboldt you will be happy with either one of them, both very good choice.
Since i already own the SIA-025 i'm going to skip the Humboldt and get the Heisenbergs when possible.
I'm trying to figure out if i can find a better linestage than the Stern in the same price range and smaller form factor.Speaker System : Thiel CS 3.7 - Vitus SIA-025 Mk2 - Aqua Acoustics LinQ - Aqua Acoustics Formula xHD Rev 2 - Fanless Intel NUC + Sbooster Mkll - Farad Super 3 - Paul Pang Quad Switch - Pink Faun LAN cables - Cardas Clear Beyond IC and SC - Furutech DSP 4.1 Power cables - Audioquest Niagara 3000 Power Conditioner - Woodlink Rack - Roon Rock - Qobuz & Tidal.
Man, the ads are getting out of control. You often can't eliminate them without uninstalling the affected apps. Is there a good simple, effective, ad blocker for Android? Recommendations?
What is a good, simple, effective,...
