Results 1 to 18 of 18
Thread: What do you use to clean stylus?
July 28, 2019, 11:12 PM #1
- Nov 2013
- St. Louis, MO, USA
- 3,067
I've been using Zerodust for years. Recently a turntable guru told me ZD is probably better than nothing but not nearly as good as a brush. I mainly used ZD as more of a safety thing, it just seemed safer than thrashing around with a brush. Especially now that I am using the Maestro where the cantilever protrudes out past the cartridge body.
So opinions on Zerodust? And if a brush is better, recommendations?
ThanksAurender ACS10 w/Audioquest Diamond USB, Esoteric N05xd
SVS PC13 Ultra
Sony XBR-75X940D & BDP
July 29, 2019, 08:48 AM #2
Re: What do you use to clean stylus?
Dan
July 29, 2019, 10:42 AM #3
agree with Dan and I've also been using LAST products for well over thirty years too.
Cheers ! …. Dave
July 29, 2019, 10:51 AM #4
- Nov 2014
- 227
Magic Eraser each session. Dip stylus in & carefully rotate the ME piece back & forth around it to "scrub". Long bristle brush, from various angles against the stylus (especially with bristles orthogonal to stylus shank) plus up & down the cantilever (long bristles far superior to the short bristle pad because of this), each side. I used ZD and still have 2 of them, but the ME and brush is more effective - haven't used the ZD in a long time.
July 29, 2019, 07:18 PM #5
- Jan 2016
- Solana Beach, CA
- 199
Peter Lederman recommends using Bluestik. Have to say it works!
From the SoundSmith website:
How do I clean the stylus?? Do I use a wet cleaner each time, or often? NO!!!
A DRY soft brush is somewhere between good and “OK”, but it is far better is to use some DAP Bluestik* – this is the blue clay-like stuff you get in the stationery department made by DAP. It is used for temporary sticking things on walls and such. Use it just before or after every play. Option one is to craft a “pedestal" on the turntable base and place a small ball of DAP Bluestik* on the pedestal so that you can use the cueing mechanism to allow the stylus to drop onto the blu-stik. CAUTION: Be sure that the top of the DAP Bluestik* is lower than the stylus as it travels across. You don't want the stylus to hit the side of the DAP Bluestik*; it may damage your cartridge.
The other good option is to squash a small ball (half the size of a dime) FLAT (the thickness of a record) onto a heavy coin – such as a quarter. Then place THAT coin on the platter. Then cue DOWN and up on the DAP Bluestik* several times. Be VERY carefull not to DRAG the coin or turn the platter when the stylus is down on the DAP Bluestik* or you risk damaging the stylus or cartridge.
Do this several times, each time moving the DAP Bluestik* to a new spot when the stylus is raised, so that when it comes down it hits a new spot.Analog source: AMG Viella 12; Ortofon Anna cartridge, van den Hul Crimson Stradivarius XGW
Digital source: Totaldac d1-twelve Mk2 DAC, Totaldac d1-player, Totaldac d1-streamer, Totaldac Live Power supply
Pre amp: VAC Master with phono
Phonostage: Constellation Andromeda
Amps: VAC 200iQ monoblocks
Speakers: Magico M3 with MPods
Cables: Synergistic Research Galileo SX speaker, phono, analog and digital interconnects
Power products: Synergistic Research Galileo PowerCell SX and Transporter Ultra. Galileo SX and SRX power cords. Keces P3 LPS for cable modem and router.
July 29, 2019, 07:44 PM #6
- Nov 2014
- 2,104
I had one brush like the one jdandy has. One day I needed it and it had disappeared. Then I remembered that my wife had a lot of make up brushes. So I "borrowed" one of them. She never mentioned it and neither did I.
Still works very well.
July 29, 2019, 07:50 PM #7
July 30, 2019, 06:08 PM #8
I rarely need to clean the stylus when the records are clean
I clean all my records with US and vacuum after purchase and if they look dusty.
Small brush and Lyra SPT every now and then.Source: Technics SP10mk3 - Thales Simplicity II, TW Raven AC-3 - Graham Phantom, SME 3012-R, Exclusive P3,,Linn LP12 - Naim ARO
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
November 21, 2019, 09:50 AM #9
Before every play, I’m using the Onzow or brushing using the Mobile Fidelity brush, from the rear forward - I’ll admit I’m not a fan of brushing understanding the delicacy of the stylus but no issues so far.
And carbon brush the album before and after every play.
Speakers: Wilson Alexias
November 21, 2019, 10:20 AM #10
- Apr 2013
- 238
I use the DS Audio stylus cleaner. Best i have had. Well worth the price.
November 21, 2019, 10:25 AM #11
Brian
November 21, 2019, 02:44 PM #12
- Nov 2013
- 3,067
I have a brush I got with a Stanton cart, the brissels are so tight I can't gt a finger nail in. I mean, they gave it with a cart but I am hesitant to use it on another. Are the brushes typically very tight together?
SVS PC13 Ultra
January 30, 2020, 12:06 AM #13
I agree--I got a brush with the round head and the tight bristles that everyone seems to throw in with a cart. I would be afraid to use it as stiff as it seems. I just usu use the brush that comes out of the LP#9 fluid bottle. And only if zerodust doesnt get everything off. I find it really hilarious that I cannot find one youtube online demonstrating how to use one of those round brushes back to front. I think everyone mist have a problem with them.
McInotsh MC75 (2) amps
Audiophonics LPA-S400ET Class D amp
Marchand XB44 crossover
McIntosh C2500 pre
Luxman 505Ux integrated to drive "B" Speakers
EAT C Sharp with Ortofon Cadenza Blue
TEAC SD1000/Yamaha SACD Blu Ray player
Sonus Faber Olympica I
dual Rythmik sealed subs
AKG and Sennheiser phones, Feliks headphone amp
Vintage Pioneer table and Kenwood 3 head tape deck
Nitty Gritty RCM, and DeGritter
McIntosh, AQ, Nordost, and Cullen Cables
Mytek Brooklyn DAC+/Sonare Ultra Rendu, SGC I transporter 5
Tidal and Roon
January 30, 2020, 11:31 AM #14
LOL, no problem what so ever, in fact they couldn't be easier to use. Not to mention they do a better job than any of the aforementioned ones you speak of, simply because of the density / shortness of their respective bristles.
All one needs to do is have your tonearm at rest and locked, bring the brush till the stylus is in and gently move from back to front, plenty of compliance in ones cantilever suspension for this if done correctly. After this is done you will be surprised at what you see on that little brush !Cheers ! …. Dave
January 30, 2020, 11:37 AM #15
McIntosh C2500 pre
Tidal and Roon
January 31, 2020, 11:28 AM #16
- Jun 2013
- 1,068
A quick little shot of compressed air after brushing (for me, from behind and below.) I pulled off my cartridge recently to change tonearms and noticed some dust build-up inside the body, right where it would be flicked off of the stylus/cantilever when using the small brush from back to front.
February 4, 2020, 06:13 PM #17
- Aug 2014
- 10
I use Onzow or moongel, some generic last type fluid w brush(occasionally) and the tight bristled stylus brush.
Question, what's the best way to clean the small stylus brush?
February 4, 2020, 06:32 PM #18
Upgrade on the way...
