Page 3 of 3 FirstFirst 123
Results 101 to 132 of 132
  1. #101
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    Re: Active Speakers - would you consider?
    Quote Originally Posted by AJ Soundfield View Post
    Apparently neither can Mike, since he liked a bunch of active speakers at Munich and he doesn't use your imaginary Class A amp with his AGs.
    Unless of course, it's your imagination....
    There are meds to help your cognitive dissonance , indulge ....!
  2. #102
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    I was very impressed by some active speakers at Munich.
    But tubes rule!
  3. #103
    Senior Member
    Join Date
    Apr 2013
    SE Michigan
    Posts
    3,767
    I’ve tried several class A (Pass, Gryphon, Luxman). Tubes rule.
    Mike, Tubes rule at doing what with what speakers?
    Jim
  4. #104
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Quote Originally Posted by a.wayne View Post
    Any suggested meds for your imaginary speakers?
  5. #105
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Quote Originally Posted by still-one View Post
    I think Avantgardes, but don't quote me
  6. #106
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Any. Active Speakers - would you consider?
  7. #107
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    How are you measuring AJ , anechoic or GP ..?
  8. #108
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    How are you measuring , anechoic ? Ground plane ..?
    regards
    Lets see your speakers and measurements. Tough when it all imaginary eh?
  9. #109
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Your speakers? I'm thinking by dimebag or ounces?
  10. #110
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    They image so well they disappear hard to see ...
  11. #111
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    Your selling speakers and your tech behind them is ball washing bloviation thats sad man , Campion shamed ..
    Let me know the size of the room, what model are you using , my one criteria is you have to build all your drivers yourself nothing purchased apart from parts necessary to make , less see how good your online EE degree is ....
    ohhh look she runs ....!
  12. #112
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    According to whom?
  13. #113
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Campion shamed ..
    Did them proud Sunday. Where was your demo?
  14. #114
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Psst, Mr Wayne
    https://www.audioshark.org/showthrea...l=1#post278519
    https://www.stereophile.com/content/...speaker-system - Wow
    Don't be so jealous now
  15. #115
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Big enough for any Class A amp you won't bring, for the world to see making yourself look silly.
  16. #116
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    Haha, you pull measurements off the internet to show how good your speakers are
    What a guy .....
  17. #117
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    Quad ESL , knock yourself out
  18. #118
    Senior Member
    Join Date
    Apr 2015
    Front Row Center
    Posts
    3,468
    Speakers big and the class A amp weighs 200 lbs , better you put your class D amps in your back pocket and fall in ...
    Regards ...
  19. #119
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    You were saying?
  20. #120
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    My posted measurements are on my hard drive, yours are imaginary, like your speakers
  21. #121
    Senior Member
    Join Date
    May 2014
    Tampa
    Posts
    1,899
    Speakers big and the class A amp weighs 200 lb.
    Yet small enough to exist only in your head.
    Big imaginations again...
    My room at Flexpo will be waiting for your imaginary Class A. Cameras will be rolling. Scared eh?
    Hit the pipe prior, come relaxed
  22. #122
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Ok, you both need to take a break on this thread. The pointless bickering kind of ruined the point of my thread.
  23. #123
    Senior Member
    Join Date
    Mar 2017
    chicago burbs
    Posts
    623
    Back on point, after deciding I wasn't jumping into the bottomless pit of component matching I bought a clean used pair of Meridian DSP8000's and the 'se' upgrade kit. With the price a known up front I was less apprehensive and while expensive (for me) quite affordable in hifi terms. They're full range, adjustable, accurate and musical.
    KEF Blade, Mc-611's, C49 rega jupiter, roon nucleus, revox tuner. Meridian dsp8000 se upgrade, meridian 218 zone controller VA Beethoven's, Hegel h360.
  24. #124
    Who let the dogs out >>>?>>>?>>>?
  25. #125
    Senior Member
    Join Date
    Aug 2013
    Singapore
    Posts
    1,028
    Quote Originally Posted by sharkmouth View Post
    "Woof, woof, woof, woof, woof"
    Well that was fun.
    Unfortunately the bickering has merely migrated to another thread.
    Back on point, as evidenced at Munich 2019, active loudspeakers are on-trend and a rapidly growing market segment. Audiophiles remain cautious which is curious when most recognise that synergy between an amplifier and speaker is a fundamental for great sound. When their ability to choose an amplifier is removed many audiophile politely decline. Perhaps this simply demonstrates that we are box junkies?
  26. #126
    Stereo - issue #32 just did a mini survey of active speakers.
    https://stereo-magazine.com/index.ph...14a9&download=
  27. #127
    Senior Member
    Join Date
    Mar 2017
    chicago burbs
    Posts
    623
    Kiwis, that probably holds true for the well heeled as stereo like cars can often be used to display financial status. I drive a Chevy, always have and when I realized that the best speakers I could afford needed like priced amps I bailed. Like imported motorcycles affording the price and then the maintenance are two different things. I love the music and owning active just makes sense for me
  28. #128
    In my own opinion, actives are a win win. Simply because the crossovers are not part of the equation, they are the end result as in all parts involved.
    I owned some of the best actives coming out of Australia at the time & probably still current today, yet I had people listen to them that just wanted to tear them down & make them small. I went from Sonus Faber Stradivaris with MC2301 monos to the speakers I mention. I remember sitting in front of the actives & thinking, yep they're really good, i had the same thought in several different places around the house over the next few hours. Have never forgotten those speakers, then again, I've always remembered the uneasiness of the Strads when used with the type of music they weren't totally comfortable with ...
  29. #129
    Senior Member
    Join Date
    Aug 2013
    Singapore
    Posts
    1,028
    Quote Originally Posted by steve59 View Post
    I am broadly supportive of active loudspeakers. As I mentioned in an earlier post, actives are on-trend and a growing market segment. The integration of amplification and speaker - when done well - should ensure sonic synergy and de-risk investment.
  30. #130
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,098
    Quote Originally Posted by nicoludio View Post
    I wasn’t able to open. Are you able to share the results?
  31. #131
    This should work - they must have moved it to the archives. It’s issue #23.
    https://stereo-magazine.com/archive/issues
  32. #132
    Senior Member
    Join Date
    Mar 2017
    chicago burbs
    Posts
    623
    I went to the avr forum revel thread and begged KV and company for an active version of the salon 2. If I recall correctly the reply was there was too much time invested into perfecting the passive ones in use... They’re the experts.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
