Results 1 to 16 of 16
Thread: Please help
July 10, 2019, 03:00 PM #1
Please help
Hi all. I need your help to solve a problem. I have connected my audio equipment (amplifier and streamer) and a TV to a shoe Bada model LB 5500. When I connect the Bada power cable to the power (to the wall) a buzzing sound enters my speakers, I had to disconnect the cable from the land of Bada so that the buzzing disappears, I mean if Bada power cable is connected normally (3-prong plug) there is hum, if I connect without the ground wire disappears. What should I do so that the Bada is normally connected to the current and not have the buzz. If anyone knows how to solve it, I would appreciate it. Thank you very much. Greetings.
Bada LB5500
July 11, 2019, 09:03 AM #2
July 11, 2019, 09:46 AM #3
Re: Please help
Seems like you are having a grounding issue. These things can be very difficult to track down. Maybe we will get some ideas on how to fix it. Have you tried a normal power strip instead of this unit? Maybe it’ll be better to not use it at all.
July 11, 2019, 10:24 AM #4
Re: Please help
Thanks for answering. At this moment I have disconnected the ground wire of the Bada power cable and there is no buzz, my idea was to buy a better quality power cable for Bada, but first I have to solve this problem. Sorry if I do not explain well. My only problem is when the plug of the Bada power cord has a connection to the ground.
July 11, 2019, 11:34 AM #5
Re: Please help
It might be dangerous but leaving the ground unconnected might be the only way to keep it silent.
What might be an interesting experiment is to try disconnecting each plug until the speaker go silent. Sometimes it’s only one piece that causes the buzz.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
July 11, 2019, 12:43 PM #6
July 12, 2019, 06:37 AM #7
Re: Please help
My guess it is the TV. Is the TV connected to a coax cable? I don't know what the cable TV system is like in Argentina, but in Canada it causes all kinds of ground loop issues when the TV is connected into an audio system.
Dan Santoni
www.dtsaudioelectronics.com
www.blackdoghifi.com
July 12, 2019, 08:51 AM #8
July 13, 2019, 08:19 PM #9
- Oct 2014
- Oregon
- 234
Re: Please help
Does it buzz when no equipment is attached? If it doesn't, try isolating the one that makes it buzz one at a time. Lift the ground on the offender. If it does buzz without anything attached, keep it ungrounded, or consider the unit and home wiring a miss match.
Main System: Analog - Linn LP12, Origin Live DC motor and Controller, SME V arm, Benz Ruby H 2 cartridge, Wright Sound preamp. Digital - Intel NUC I-7, 16 gig ram, Jriver media center 24, Wyrd4 Sound 2V2 SE Dac, Fathom Hard Drives.
H-Cat Version 9 preamp, ARC Reference 75 amp, Custom line source speakers - 10 SB Acoustics midwoofers, 10 Fountek ribbon tweeters. JL Audio Fathom f112 Subs
Wire - T G Audio, Shunyata, Synergistic Research , Audioquest, Lewis silver foil, Duelund, Transparent.
July 14, 2019, 12:02 PM #10
Re: Please help
Looking at a photo of the Bada LB-3300 internals, particularly this image, it appears the outlets ground lines are wired in series instead of in parallel (star). Also, the unfiltered power lines coming from the IEC inlet are run along the side of the enclosure, alongside the ground lines, to the front toggle switch. It's also not clear to me if there is any chassis ground, but it might go through one of the PCB screws.
The LB-5500, which claims to support 3000W and 15A, might be constructed differently but I wasn't able to find any photos of the interior.
For comparison, here is what the APC H15 internals look like. The wiring you see matches up with the bank illustration on the rear. The APC H15 supports 1500W and 15A.Neko Audio
July 14, 2019, 03:43 PM #11
Re: Please help
You may have a point though. Checking the integrity of those grounds may help.
There's not much filtration in the Bada. Most of the jacks just have a capacitor across them., Two have a coil in series.
I think chassis ground may come from the two outlets closet to the IEC. Probably from the mounting screws. Not a legal way to do it, at least in this country.Dan Santoni
July 14, 2019, 04:08 PM #12
Re: Please help
Neko Audio
July 14, 2019, 04:33 PM #13
Re: Please help
Dear thank you very much for your comments, I would like to remind you that my electric wiring has been changed very recently. Everything is working correctly. Tomorrow I will do several tests with different powers cable, all the powers cables I use in my equipments are connectors american (3 legs) I'm thinking about trying the amplifier and the streamer, with American and European power cables (2 legs) and see if I can find the problem. Unfortunately I do not understand anything about electronics and I can not comment on what they are talking about. Greetings.
July 14, 2019, 08:15 PM #14
Re: Please help
Hi all. I tell you to disarm the Bada LB 5500 below I put the photos, connect the power cable of Bada power, and start connecting my equipment, first the amplifier, zero buzz, then the power cable of the TV there is no buzz , and the last one was connected the Lumin D2, I do not have any hum in the speakers, I put a picture of the power cable connector of Bada, there you can clearly see the ground wire disconnected (I had this way before) now all connected and without buzzing, it's weird but good, in these days I'm going to change Bada's power cable, something of good quality and I see this story as follows.
Bada LB 5500
July 15, 2019, 12:07 PM #15
Re: Please help
I think you're saying you now have the ground wire connected and there is no buzzing? That's great and please keep the ground wire connected because it is there for your safety. It could be that some other component in your home or even from outside your home was temporarily creating interference that somehow got through to your electronics.
Neko Audio
July 15, 2019, 02:50 PM #16
Re: Please help
Hello, thank you for commenting, yes, that's right, the ground wire was disconnected and yesterday I plugged it again, right now I'm listening to music and without any problem, if at some point the buzz comes back I'll try changing the power cables of the amplifier and the streamer (I will replace the european connectors, 2 legs)
Upgrade on the way...
