Results 51 to 100 of 545
Thread: Why no turntable?
July 6, 2019, 10:11 PM #51
- Nov 2013
- 318
Re: Why no turntable?
I agree --with the exception of Mike Moffats "Gain System" his rendering of Muddy Waters Folk Singer--still one of the benchmark Digital CD's.
I knew Mike when this was being done and have couple of "beta" discs before the domestic run--the dynamic contrasts are superb.
Track one will give your system a workout for any susceptibility to these
Bruce
July 6, 2019, 11:06 PM #52
- Apr 2015
- 634
Yes it is!
Why don't more people get into vinyl?
1) So many components involved: turntable, motor, speed controller, arm, cartridge, cables, phono preamp, record cleaner
2) Very tweaky: optimal gain, optimal "cartridge loading", optimal cartridge VTF, speed stability, bearing noise, tracking errors & alignment, skating issues, choice of belt if belt-driven, more significant motor noise issues if direct-driven, hum and other noise issues, VTA/SRA differences per LP, acoustic feedback issues, platter material, platter-to-LP interface (e.g. "mat"), record clamps and periphery rings, vacuum holddowns, platter mass & inertia, acoustic signature of all materials involved including damping materials, cartridge bodies/cantilever materials/stylus shapes/stylus materials, azimuth, MC vs MM or other, cartridge output level, unipivot arms vs gimbaled vs linear trackers, deep vs shallow record cleaning, low-numbered LPs sounding arguably better than later pressings, record thickness and weight, stylus wear, surface noise, pops and ticks, a whole bunch of very bad pressings, cables cables and more cables all with varying degrees of signal loss and noise rejection (both of which are extremely critical for this application), arm rigidity and resonances, arm geometry (e.g. length) and how many can really set up an arm correctly, underlying support platforms ... there really is no end
3) Cost: very expensive to get the most out of vinyl, and totally disproportionate to tape which arguably can sound even better and is in many cases the true source of truth
The positives: truly hi-resolution sound, showcases superiority of hi-res digital recordings transcribed to LP over any redbook versions on CD. In this respect, I differ widely and wildly in opinion than my friend Al M.
I just found another substantial improvement in my own system too. It cost me zero dollars and was done in a few minutes. It's so trivial that I cannot believe why I hadn't revisited the issue earlier.
It's slight speaker toe out by just a few degrees. I had from previous quick experiments thought that with these speakers toe out/in largely did not change tonal balance, because unlike with my previous monitors the upper treble does not change much, unless toe out is extreme. But the rest of the frequency spectrum changes to give a substantially more natural timbre with more body. Duh. Could have figured that out earlier.
I only experimented once more since I wanted to move again to my closer seating position a few inches forward and there was bothered a bit by the treble.Simaudio Moon Neo 260 DT CD Transport / MIT SL-Matrix Plus AES/EBU digital cable / Schiit Yggdrasil Analog 2 DAC / Octave HP 700 preamp / Octave RE 320 stereo amp with Super Black Box / Reference 3A Reflector monitors on Sound Anchors Signature Stands / dual JL Audio Fathom 112 v2 subwoofers on ASC SubTraps / ZenWave Audio D4 and SMSG cables / Acoustic treatment: tube traps, Tri-panels, window plugs, ceiling diffusers (all ASC), large absorbing panels (Acoustics First), diverse carpets chosen for acoustic properties: wool, polypropylene basket-weave
July 6, 2019, 11:15 PM #53
What makes you think this is a true statement? Are you saying that LP playback from 20 years ago is as good as it is today (because that is the implication)? And I don't know about you, but the idea of dealing with LP playback when I am in my late '80's is not a happy one.
And if one asks this question about LP playback, why not ask the same question about reel-to-reel tape?Rob
__________________________
Tascam BR-20; Technics 1506 with tape path upgrades, FM head, DeHavilland 222 tape head pre; Modwright Oppo 205 full tube mod w/LPS; Euphony Summus server, EtherRegen, HDPLEX LPS; MSB Discrete DAC (dual PS, ISLPro, balanced out); Pass Labs XP-12, XA60.8 (pair); Daedalus Audio Apollo 11’s, VMPS Larger Sub; Daedalus/Wywires, Acoustic Zen, Sablon Audio, Wireworld, Shunyata Research cables; Core Power Equi=Power;
Adona rack, Stillpoints, IsoPods, ASC, GIK Acoustics accessories
July 6, 2019, 11:22 PM #54
Because Linn LP12’s from decades ago are still around and still excellent and fabulous sounding. We hear from people all the time with a table from the 90’s or 80’s and they’re needing a new cartridge. They love their Basis or whatever table and no desire to change.
As for R2R, I have two Studer 810’s and a Technics 1500 (recently sold). Still awesome sounding after all these years.
July 6, 2019, 11:27 PM #55
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
July 6, 2019, 11:31 PM #56
July 7, 2019, 08:14 AM #57
Rob
July 7, 2019, 08:34 AM #58My Systems: http://www.audioshark.org/showthread...481#post158481
July 7, 2019, 09:30 AM #59
Rob
July 7, 2019, 01:26 PM #60
Rob
July 7, 2019, 03:34 PM #61
Jim
July 7, 2019, 05:59 PM #62
Regards,
Steve
https://www.audionirvana.org/forum/t...geezr-s-system
I only do what the voices in my wife's head tell her to tell me to do.
July 7, 2019, 07:35 PM #63
Having both formats is great. and on the digital side, it lets me discovery new music and artists via Tidal.
in MY personal experience, with Audiophile and Non-Audiophile recordings on vinyl, the music can be magical!
keep in mind the examples are strictly based on MY opinion. and just sharing my experience with Vinyl and Digital, to many examples to list.
Example : Regular LP's
Count Basie "Me and You" playing the Vinyl the dynamics are incredible and not the same on Tidal
Sarah Vaughan and Her Trio "At Mister Kelly's" a live recording has incredible room presence and her voice is great and don't get the same emotion of the recording on Tidal
Audiophile Examples:
Mofi---Dire Straits "Brothers in Arms" amazing on Vinyl (Dynamics) and on Tidal is very good but the Mofi is supreme.
Music Matters SRX---J.Coltrane "Blue Train" winner is Vinyl all the way.
Analogue Production---- Muddy Waters "Folk Singer" dynamics and emotion of Muddy is amazing on Vinyl, and good on Tidal
Analogue Production----HM "Hope" (Stimela--Coal Train) Vinyl smokes Digital!
having both formats, is a plus in my book, and hearing is believing !
July 7, 2019, 07:59 PM #64
July 7, 2019, 08:01 PM #65
Rob
July 7, 2019, 08:14 PM #66
July 7, 2019, 08:15 PM #67
Why no turntable?
July 7, 2019, 08:25 PM #68
Rob
July 7, 2019, 08:27 PM #69
July 7, 2019, 08:28 PM #70
July 7, 2019, 08:29 PM #71
- Aug 2014
- east of Seattle
- 821
July 7, 2019, 08:31 PM #72
It’s very possible. The turntable has its own set of variables. As one example, one can lower the VTA ever so slightly to take the edge of bright recordings. There is also the remastering stage (for vinyl). There also isn’t the hocus-pocus of added noise from a network which often reveals itself in the upper register. Conversely, the digital can also sound better in many systems with the right DAC, network, remastering, etc.
At the end of the day, it’s not a great recording, but it is a great album however you choose to enjoy it.
July 7, 2019, 08:32 PM #73
July 7, 2019, 08:51 PM #74
July 7, 2019, 09:03 PM #75
July 7, 2019, 09:37 PM #76
July 7, 2019, 10:21 PM #77
I don't even know what this means? You're basically saying that all CD's will sound "better" (whatever that means) if one records them to tape and then listens to that. All very well and good, but "high fidelity" isn't part of that equation.
I wouldn't care about the audiophile love of LP's except for this phenomenon, that the record companies simply will not release a product that sounds as good as it can. No matter how good the 45 rpm LP sounds, a CD made from the original recording, properly mastered, would sound better; there's really no way that isn't true. BUT, apparently that isn't going to happenRob
July 7, 2019, 11:34 PM #78
- Aug 2014
- east of Seattle
- 821
sigh.
I love 16/44 and listen to it often with great satisfaction. and music recorded and mastered to 16/44 is typically outstanding. I'm a 'native' guy and format agnostic in as much as I want to hear it as god intended......in the native recorded format. which is why I'm heavily invested in digital, vinyl and tape. I love all of the formats.
I was wrong above (that it was mastered to analog tape, it was mastered to DAT tape.....I got the tape part right) when I was going from my memory. here is what it says on the Wiki link....
Brothers in Arms was one of the first albums directed at the CD market, and was a full digital recording (DDD) at a time when most popular music was recorded on analog equipment. It was also released on vinyl (abridged to fit on one LP) and cassette. Producer Neil Dorfsman says the digital multitrack was mixed on an analog board with the resulting two track mix re-digitized via a Prism A/D converter and recorded on a DAT machine.
I have the dsd rip from the 96/24 sourced SACD of Brothers in Arms (and a quality way to play it back) and it is very nice.
I do have a number of digitally sourced Lp's where I do prefer the digital to the Lp. but it's a mixed situation 'depending'. in this case the 45rpm Lp is better. maybe the 'analog board' inserted between the direct recording and the DAT?
July 8, 2019, 08:24 AM #79
I know DAT did not exist in 1985, when BIA was released. I also doubt that the Prism ADC existed then, so I’m not sure what that anecdote is about?
Rob
July 8, 2019, 09:22 AM #80
- Oct 2017
- 175
I had a reasonably nice turn table and cart - something from rega and a grado cart on it. Neither were top of the line nor entry level. I paired it with a simple Schiit phono amp and bought some records. It sounded great and wasn't as fussy as I thought it would be - though the driver excursion did scare the hell out of me at times.
The sound was good but certainly not as detailed as the digital I like. There was a wonderful body to vocals that I really enjoyed but I did find it a bit too rich and dark for my liking. I'll chalk that up to the rega - I've never been a fan of the traditional british hifi sound. My favorite audio products from the UK are chord and dcs if that gives an idea of my preference (hell, liking soulution and magico probably gives an even better idea).
I ended up selling it all after about a year for pretty much no cost to own. Most of the music I listen to just isn't released on vinyl. Despite this knowledge, I may continue to be a silly audiophile by...picking up a more expensive turntable and giving it another shot lol but it's at the bottom of my list. The generally higher dynamic range of most recordings on vinyl vs digital is certainly enticing so I keep a look out to see if more artists are releasing on vinly. To that end, they are, but still not at that critical mass where I feel compelled to set up another TT rig.
July 8, 2019, 09:46 AM #81
July 8, 2019, 09:55 AM #82
A problem when discussing BIA is how many different ways it has been released. Neil Dorfsman was obviously confused in the quote Mike L. referenced above; referring to the links below suggest he was confusing the original mix/mastering with the much later 5.1 production. Adding "fuel to the fire", Chuck Ainsley describes
" In addition, we also mixed it to half-inch analogue tape at 30 IPS, as well as to 15 IPS, one-inch tape in two-track. And everyone in the room had the same opinion that the 96kHz 24-bit PCM was the closest representation of the console bus, and coming second was the 15 IPS one-inch analogue tape. Thereafter, it was a toss-up of which came in third and fourth — i.e. was it the Sonoma DSD, or the half inch 30 IPS tape? So going forward now, we have basically determined that we prefer 96kHz 24-bit PCM for recording over the Sonoma DSD. I was really surprised at that."
https://www.soundonsound.com/people/...-money-nothing
https://web.archive.org/web/20080610...in_arms_01.asp
https://web.archive.org/web/20080820...in_arms_02.aspRob
July 8, 2019, 10:37 AM #83
My mistake was selling or giving away all my albums when I bought my 1st CDP and disks. I get the appeal and the sound differences but never pursued it again.
I barely have the room to store my CDs and really have no place to start storing LPs if I was to start buying them. And, what would I buy? Another copy of all the same music I already have? I am not one to need multiple copies of the same music in different formats.
I do still enjoy listening to a good vinyl setup when I get the chances.-----------------
Brian
July 8, 2019, 12:30 PM #84
- Nov 2014
- Decatur, IL
- 13
I guess for me, it was the time period in which I got interested in audio. It was about 1987 and the CD was where I made my initial investment in equipment. I think it also has to do with perhaps I am just more used to the sound of digital along with the convenience.
Main Listening System
Harbeth SHL5, REL T-5, Odyssey Audio Khartago Monoblock SE, Wyred 4 Sound STP-SE, Sony XA20-ES, Oppo BDP 105, Skylan stands, Nordost Heimdall II, Shunyata Research Hydra, Audioquest CV-8 speaker cables
Office System
NHT Super Ones, Exposure 2010S2, Cambridge Audio 840C, Audioquest Type 4
July 8, 2019, 01:51 PM #85
- Nov 2014
- 2,104
I still own a turntable and have no intention of giving it up but I would not bother owning one if I have to start anew.
In my experience, a “basic vinyl rig” cannot compete with a similarly priced digital set up. One would have to spend a lot more in an analog rig to achieve what is now possible with digital.
The convenience of digital and the improvements made in the last 5 years make it difficult for me investing in vinyl.
That said, I did hear a system playing R2R and it was amazing. Beautiful analog sound with no ticks or pops. That would be interesting. But... oh the inconvenience...
July 9, 2019, 08:49 AM #86
That’s where I keep going back and forth.
I’m over the top with what I’ve accomplished in my digital assembly, and will add vinyl only at a modest expense.
Then comes limited play, since I will be starting with a handful of albums, over thousands of choices between streaming, downloaded and disc.
Speakers: Wilson Alexias
July 9, 2019, 09:09 AM #87
I have 2 vintage ones right now. An old (stock) Lenco L78 that has only been internally converted to 115v, as that sounds better than the 230v here in Europe. I use a step down transformer on it. The other is a vintage HK linear tracker.
With circa 100 albums now, I am good there...don't really need more than that.NORMAN
July 9, 2019, 09:12 AM #88
July 9, 2019, 09:14 AM #89
NORMAN
July 9, 2019, 10:31 AM #90
I remember (not fondly!) the days when I had a turntable (LP12 Valhalla) on a dedicated stand, 2 reel decks, 2 DAT decks, a cassette deck, CD player, Beta HiFi and VHS HiFi with a Sony PCM-601ES, all on a wide lowboy rack, with all the assorted "software" (LP's, CD's, all kinds of tapes).
Rob
July 9, 2019, 11:16 AM #91
July 9, 2019, 11:35 AM #92
Mine was ripped by a very AR person...though could not test directly in the same system. That TT is $$$$$, so outta my league. Even the P-Stage is something else.
However, its a great recording even in car stereo.NORMAN
July 9, 2019, 11:36 AM #93
July 10, 2019, 04:19 PM #94
This is a touchy subject.
The way I see it: if, at the time of recording, the mix was recorded to an analog medium, then I want to hear it in analog. The same goes for digital (for the most part)...
So, if the recording engineer mixes everything down to DSD... I want to hear that album in it's original format.
If it was recorded to tape, I want to hear it on tape, or the next best thing, a vinyl record that was cut by a competent mastering engineer to a lacquer, using an all-analog signal chain and pressed at a good pressing plant like QRP, RTI, etc...
There are companies out there right now that are putting out the best sounding reissues on the market. Analogue Productions, Music Matters, even Blue Note directly with their new Tone Poet series are releasing these recordings on vinyl and they can beat out ANY digital reissue of the same release.
I know the big labels are trying to preserve all of those old master tapes that degrade every time they hit a tape head. But some, NOT ALL, of these labels are using cheap A/D converters to record down to 24/96, 24/192, 32/384 etc, instead of cutting new lacquers from the tape. As we all know, lacquers degrade over time... it's a conundrum.
90% of these new vinyl reissues that are being mass-produced by crappy pressing plants, hitting the shelves of Barnes & Noble, Best Buy, Walmart, Guitar Center and your local record stores, with lacquers cut from a digital recording of an analog source... just don't cut it for me. A simple, blind, A/B test on a good system will reveal that. Obviously, the mastering, pressing plant, all play a big part in that final product.
With all of that said, you can find some incredible DSD recordings of analog masters that, depending on the hardware the studio uses and the hardware in your system, can get you as close to that master tape as possible.
I like, and use, both digital and analog sources in my system. But if I had to choose one.........
July 10, 2019, 07:04 PM #95
I own a simple entry level Marantz TT. It’s been in its box for two years. Lack of LPs or having to buy new LPs is one reason I don’t further invest in a better rig. The cost and fussiness of purchasing an analog system to equal the overall sonic rewards of my digital system is another and much bigger reason.
Main Equipment: Kharma Elegance dB11-S, JL Audio F113v2, Block Audio Line & Mono SE Amplification, Bricasti M21 DAC, Antipodes Kala K-50 Server, ClearAudio Performance SE, Satisfy Arm & Maestro Wood MM Cartridge
Power: 3 x 20 Amp Lines, Shunyata Everest 8000, Sigma XC v2, Shunyata Sigma v2 NR, Block Audio Power Cords, Defender, ADDPowr Wizard
Grounding: Shunyata Altaira CGS - Alpha CGS cables
Network : Supra Cat 8+, Twin (Nenon Modified) Buffalo GS2016 Switches powered with Keces P3 LPSU,
Cables: Wireworld Platinum Starlight 8 USB, Wireworld Platinum Eclipse 8 SCs, 1M & 6M Tubulus Concentus ICs,
Other: PSI Audio AVAA C20, Isoacoustics GAIA I footers Kharmas, GIK/Vicoustics/Stillpoint Apertures, Stillpoint Ultra SS, Furutech GTX - Gold outlets, Adona Rack
July 11, 2019, 08:41 AM #96
For my multi-channel recordings, I prefer digital...
Vivid Audio - Burmester - Hegel - Marantz - Oppo - Pioneer 60" - Wireworld
July 11, 2019, 10:37 AM #97
- Jan 2017
- Leyden
- 596
I sometimes regret going into analogue. I love my turntable, but the costs are just too much. Carts, tonearm, TT, cables etc etc.
Pre amp: Ocatve Phono Module Power amps: Octave MRE130 Turntable: SAC Girati Grande. Tonearm: Dynavector 507mkII Cartridge: Dynavector Ikeda 9TT Streamer: Aurender A10 Power Distributor: Anzus Mains D8 Speakers: Raidho X-3 Speaker Cables: AudioQuest Rocket 88 XLR Interlink: Ansuz A2, [B]XLR Interlink: [B]Phono interlink: Cammino Serie 1.0 - PH 1.0s Power cables: Anzus Mains Ceramic, two Pom, Aluminium, X series Audio Rack: Rack of Silence 4 and 2.
July 11, 2019, 10:44 AM #98
July 11, 2019, 11:25 AM #99
Jim
July 11, 2019, 11:58 AM #100
- Apr 2015
- 634
Clarisys Arrives at Puur...
