Results 101 to 150 of 192
Thread: Shunyata Denali 6000/S v2
April 17, 2020, 07:18 PM #101
- Apr 2020
- Washington, DC
- 25
Re: Shunyata Denali 6000/S v2
~DP
Loudspeaker: Harbeth 40.2 Anniversary
Amp/Pre: Luxman C900u/M900u
Digital: Luxman d-10x + Aurender N10
AQ Thunder pwr + Shunyata delta v2 signal
April 17, 2020, 07:36 PM #102
April 18, 2020, 04:12 AM #103
Francisco
April 19, 2020, 08:11 PM #104
- Apr 2017
- Australia
- 1,763
Speakers: Magico M3, ACC, S-SUB | Electronics: Esoteric Grandioso stack | Amplification: Halcro |
Analog cables: Crystal Cable | Digital cables: Shunyata Sigma | Rack: YG Acoustics Rack 1.8
| Source: Kaleidescape Premiere (4 x 6TB) | Power: Shunyata Typhon-QR, Everest and Denali
April 19, 2020, 08:36 PM #105
- Mar 2017
- North Carolina
- 813
I'll try. Noise from the wall to the distributor has two places to be removed - the distributor and the distributor to component NR PC. [Noise emanating from a component to another component (attached to the same distributor) has three places to be removed: the NR PC that drives the component, the distributor, and NR PCs from the distributor to other attached components.] Having a PC from the wall to the distributor with NR capability would, in Shunyata's opinion, be overkill/overly redundant noise filtration and cost more than necessary.
Quote: "Again, this is why I don't understand why NR power cords and not XC are recommended to power components connected to Denali V2."
I think because there is likely other noise present in the room that may penetrate to PC (between the distributor and the component) before it reaches the component.... that needs to be removed by the NR filter at the component end.Last edited by GSOphile; April 19, 2020 at 08:44 PM. Reason: clarity, correction of terms
April 19, 2020, 09:00 PM #106
- Apr 2017
- Australia
- 1,763
So inter-component noise rejection via the CCI in Denali V2 of itself can be improved further by using NR PC, but using NR PC from the wall to the Denali V2 doesn't (in a worthwhile sense) because the NR feature within Denali V2 is sufficient (meaning CCI within Denali V2 is not).
April 20, 2020, 12:55 PM #107
Just ordered one. Looking forward to seeing if there's an improvement in sound over my PS Audio P10
Preamp/Digital: Meitner MA3
HT Processor: Bryston SP3
Amps: Bryston 14b3, Bryston 4b3
Speakers: Kef Reference 5, Kef Reference 4c
Sub: REL Carbon Special
Power: Shunyata Denali, Bryston BIT15
Wires: Wireworld Silver Eclipse XLR & SC, Ethernet - WW Platinum USB
Other: Stillpoint Ultra SS, ISO-Acoustics ISO Pucks
-Kyle
April 25, 2020, 09:01 PM #108
- Mar 2020
- Marysville Ohio
- 3
So I'm considering getting a Denali v2 for my system but I'm wondering if the QR/BB tech will make a difference considering my system is a DNA Stratus(pure class A tube headphone amp) and a Bryston bcd-1 CD player(will be upgrading CD player soon). I know it may sound like overkill to some but I spend a lot of time with this system and want the best(currently using a Hydra V-ray v2). So what do you think Denali v2 or should I just go with a Delta D6?
April 25, 2020, 09:14 PM #109
- Mar 2020
- Marysville Ohio
- 3
So I'm considering getting a Denali v2 but I'm wondering if the QR/BB tech will make a difference considering that my system consists of a DNA Stratus(pure class A tube headphone amp) and a Bryston bcd-1 CD player(will be upgrading CD player soon). I know this probably sounds like overkill to some but I spend a lot of time with this system and want the best(currently using Hydra V-ray v2) So do I get a Denali v2 or just go with a Delta D6?
April 30, 2020, 07:56 PM #110
What do you do when you’re locked inside? Have a shootout of course...
The Denali 6000 S/v2 removes that last bit of glare from digital. It’s really freaking good.
How much better can the 8000 be?My Systems: http://www.audioshark.org/showthread...481#post158481
April 30, 2020, 08:51 PM #111
Hm, let me drop a hint: The patented QR/BB in the Everest is 3 times the size of that in the Denali series.
April 30, 2020, 11:33 PM #112Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
April 30, 2020, 11:37 PM #113
The QR/BB technology is, IMHO, a breakthrough at a fundamental level, and it is one of the key functionalities that sets Denali apart from competitive products. It creates an enveloping, almost 3D-holographic soundstage, image and presentation that becomes....immersive.
In conclusion, with all the discussion of "engineering considerations", audiophile-speak, and high-end geekery aside, Denali creates beguiling and engaging musical experiences. When I listen to it with high-quality recordings, I'm not thinking about cables, QR/BB modules, or "gear" at all because...I find myself lost in the music.
April 30, 2020, 11:43 PM #114
April 30, 2020, 11:46 PM #115
- Oct 2013
- Seattle, WA
- 317
Mike,
Have you had a chance to try the Shunyata Denali 6000S/V2 with Audioquest storm series power cords? If yes, is the performance still very good?
Thanks,
Anshul
May 1, 2020, 12:05 AM #116
May 1, 2020, 12:05 AM #117
May 1, 2020, 05:51 AM #118
- Apr 2018
- 63
May 1, 2020, 05:51 AM #119
- Apr 2018
- 63
May 1, 2020, 08:45 PM #120
- Apr 2017
- Australia
- 1,763
Did Triton v3 have QR/BB or was it in the Typhon QR?
May 1, 2020, 08:49 PM #121
- Apr 2017
- Australia
- 1,763
May 1, 2020, 11:05 PM #122
-Kyle
May 2, 2020, 11:36 AM #123
May 3, 2020, 11:55 AM #124
- Feb 2020
- Germany
- 63
Yes, Mike, I had the same question on my mind. How good is the Denali v2 with Audioquest Hurricanes/ Dragons? You mentioned you use Hurricanes at home so would be really eager to know, since I also got a Denali v2 and ordered a set of Hurricanes for it. Any advantage for the Sigma power cords or do the Hurricanes still shine (as well)?
Thanks and regards!
May 3, 2020, 12:05 PM #125
Sorry, just seeing this. I’ve been busy with the home projects.
Yes, I tried a Dragon HC on the 6000S/v2. I felt it had too much upper end energy for me. Subtle, but too much sizzle for me. Not an ideal combo Ironically, on the Niagara 5000, the Dragon HC is silky smooth butter. Smooooooth as silk.
When I switched to a Shunyata NR on the 6000S/v2 and it was smoooooooth as silk and I felt, it also took away some of the glare on the digital recordings.
Both are excellent, but must be used with their respective designed cables IMO.
I can’t wait to try an Everest 8000 with Omega XC. OH MAN!
May 3, 2020, 12:23 PM #126
This is very helpful Mike, I had the same question, but in reverse and I assume the same would hold true.
I use Niagara 7000 and 5000 with Hurricanes from outlets to Niagara; Hurricanes Niagara to LCR amps, and bunch of Shunyata Alpha HC to preamp, streamer, DACs, and SSP.
In the context of Niagara distributors, best to feed them with AQ power cords or have you not tried the latest Shunyata PCs with the Niagara?? Ok to use new Shunyata NR after the Niagara to block noise coming from components?? Or again stick with same manufacturer, AQ??
Thx.
May 3, 2020, 12:57 PM #127
May 3, 2020, 08:59 PM #128
I may get laughed out of here (given the rest of my room), but I’m going Pangea Audio AC 9SE MKII made from Cardas Copper. Most of my system is powered form that now days.. great PC for a reasonable price.
Sent from my iPad using TapatalkPreamp/Digital: Meitner MA3
-Kyle
May 3, 2020, 09:08 PM #129
- Oct 2013
- Seattle, WA
- 317
May 3, 2020, 09:08 PM #130
- Oct 2013
- Seattle, WA
- 317
May 4, 2020, 10:50 AM #131
-Kyle
May 4, 2020, 11:14 AM #132
I started with Pangea when I was being exposed to power cords. Later I moved over to Shunyata, and haven't looked back.
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
May 7, 2020, 09:35 PM #133
Call me a “power skeptic” but I never in my wildest dreams thought I’d be sitting here talking about the virtues of clean power. 15 years ago I bought a Panamax power converter for a small set up I had from Best Buy and cursed the sales guy that sold it to me.
Fast forward, and I seem to overloaded my PS Audio P10 at high volumes with my mono blocks and I “needed” to find a solution. I was also experiencing noise at louder volumes that I dove me a little nuts.
I’ve had the Denali V2 in my room for about a week now. I’ve kept it playing almost constantly to break it in. It’s being fed by a Pangea PC. The 6 outlets are powering my mono blocks, EMM front end/digital, and the extra goes to my center channel amp.
I started with music that I normally listen to and heard some improvement. Was I shocked, not at all.. sounded better.. not anything to write home about. A couple days later it started to open up. Last night, I turned off the lights and played Dark Side of the Moon DSD. Laying back with my eyes closed, I swear to you that the music was coming from behind me on my pool table. I have NEVER heard as much of a 3D soundstage as I did last night. There were no walls, there was nothing but exact placement of music all around me. I played it louder and louDER, and LOUDER and never heard any of the noise I had with the P10.
This is an insane comment from a guy who said power converters were all the same. I was without question wrong. My PS Audio is only powering TV and other “non-essential” parts of my set up.
Damn it.. I might need to buy their power cables.
-Kyle
May 7, 2020, 10:00 PM #134
Congratulations.
Bud
Sony XA-5400ES SACD
May 7, 2020, 10:34 PM #135
Really pleased you've been hearing what we've been experiencing with Denali V2.
The 3D soundstage you've described is primarily due the QR/BB device in Denali V2; this is a key attribute that it brings to the presentation that is, in my experience, completely unique. It fundamentally changes the musical presentation in a way I've never experienced before.
And guess what: it gets EVEN better when you use Shunyata power cords. You may want to start with a Delta XC, or if you have the budget, Alpha XC, to power your Denali. The Sigma XC will maximize this effect.
One of the things I've been experiencing using Sigma XC and Denali, is that I find myself listening and going into a quasi-trance-like mental state while listening to music, much as you described when you were listening with your eyes closed.
What happens is that I completely stop listening to "gear" and find I am completely lost in the experience of the music. It's really something.
Have fun!
May 7, 2020, 10:34 PM #136
Duplicate post due to Audioshark web system bug.
May 7, 2020, 11:34 PM #137
May 8, 2020, 12:15 AM #138
Bud
Sony XA-5400ES SACD
May 8, 2020, 01:42 AM #139
Speakers: Wilson Alexias
May 8, 2020, 01:48 AM #140
May 8, 2020, 01:50 AM #141
May 18, 2020, 07:29 AM #142
- Nov 2017
- Tokyo
- 145
I am wondering whether the US version of the Denali 6000/S v2 would work fine in Japan on 100V?
Per the specs it looks it should be fine but I prefer to ask.
Thank you.
Cheers,
Bernard
May 18, 2020, 12:12 PM #143
May 18, 2020, 03:53 PM #144
- Nov 2017
- Tokyo
- 145
Thank you very much!
Regards,
Bernard
June 5, 2020, 01:32 PM #145
Wilson Yvette speakers, [B]Conrad-Johnson [ART88 [B]pre, TEA1bc phono, and ART 27A Amplifier, Marantz digital player, Wireworld Gold and Platinum ICs, USB and power cables, Rega Planar 10 turntable/ Apheta cartridge, Wireworld Platimum Eclipse 8 speaker cables, AQ Hurricane and Tornado power cables, Shunyata Denali 6000S/V2, Sigma NR PC and DELTA USB cords, Symposium and Stillpoint vibration control, JL Audio Fathom 113 subwoofer, dCS Bartok Streamer/DAC
June 5, 2020, 03:44 PM #146
- Mar 2020
- Sweden
- 111
Yes, there is something special happening when you mate a Shunyata PD with a Sigma XC. It's like it has optimal working conditions
Now, don't come talk about the OHMega.
June 5, 2020, 04:36 PM #147
June 5, 2020, 05:17 PM #148STEREO: Roon Nucleus, DCS Rossini DAC & Clock, Ayre KX-R TWENTY, Ayre MX-R TWENTY, Sonus Faber Stradivari speakers, WireWorld Platinum Eclipse 8 interconnects, and speaker cables, Shunyata Research Omega power cords, Shunyata Everest power distributor with Omega power cord, Dedicated 20amp AC lines with Oyaide Duplexes.
A/V SYSTEM: Sony A9G 77” OLED (main), Sony A9F 65” OLED, Sony A8G 65”OLED , Anthem MCA525, Anthem AVM 60, Lexicon DD-8 for Atmos, Sonus Faber Amati Futura L+R, ProAc Response CC, AT surrounds, Triad Atmos ceiling speakers x4 , JL112E, Oppo 203 & 103, TiVo Bolt, Apple 4KTV, Shunyata Research Denali 6000/S v2 & Shunyata Research Triton v3. Auralex room tx, black-out curtains, Audioquest speaker & HDMI cables, Shunyata Research Sigma & Venom V10NR power cords. Dedicated 20 amp AC lines.
June 5, 2020, 09:25 PM #149
June 6, 2020, 02:05 AM #150
- Mar 2020
- Sweden
- 111
Don’t sweat it, just be prepared to get a Sigma/Omega XC to your Everest
Climb like immediately.
Then later you can begin working the preamp/source with Alpha V2 NR. And then Sigma V2 NR for amps. It can be done in steps but your PD-Wall cable is the most important for the PD to work optimally.
VBR is not precise. Please ignore the bit rate display.
Lumin supports Plex
