Results 1 to 34 of 34
June 3, 2019, 07:35 PM #1
- Feb 2019
- Southeast Iowa
- 992
5 best power amps for $5000 to $12,500...including integrated.
Let's just go ahead and cover all bases.
June 3, 2019, 10:23 PM #2
Re: 5 best power amps for $5000 to $12,500...including integrated.
Luxman 509x
Luxman 590
Gryphon Diablo 120
Pass INT-60
VAC i170iQ
Hegel 590
....many more
June 3, 2019, 10:42 PM #3
- Nov 2013
- St. Louis, MO, USA
- 3,067
Keep in mind "best" is so subjective. Here's a few I would consider and there are things I haven't had much exposure to, so don't worry if you don't see Luxman on my list,
Power amps:
Bryston 4b cubed
Pass X250 or 350.8
I would include my Levinson 532h as I can't think of anything in that range I'd trade for, on the other hand it doesn't hold it's resale value like other Levinson amps, so I would add, if buying at a good deal.
I suspect something from Conrad Johnson or VTL would go on this list if I knew pricing. Also, in tube Octave Audio has a stunning power amp that was around $10k.
PS Audio - BHK
Integrated:
Hegel 590
VAC
At only $3500.00 I sure did like the Triode of Japan
That's it for nowAurender ACS10 w/Audioquest Diamond USB, Esoteric N05xd
SVS PC13 Ultra
Sony XBR-75X940D & BDP
June 4, 2019, 12:16 AM #4
Used Gyphon Diablo 300.
Jock
June 4, 2019, 10:13 AM #5
Rowen Absolute One! A pair of these will deliver nearly 4KW into 0.5 ohms.
NORMAN
June 4, 2019, 03:07 PM #6
What is meant by 'best'?
June 4, 2019, 05:16 PM #7
June 4, 2019, 05:25 PM #8
I voted with my wallet. Hegel H360 $6000 list.
KEF Blade, Mc-611's, C49 rega jupiter, roon nucleus, revox tuner. Meridian dsp8000 se upgrade, meridian 218 zone controller VA Beethoven's, Hegel h360.
June 5, 2019, 09:19 AM #9
- Feb 2019
- Southeast Iowa
- 992
June 5, 2019, 11:37 AM #10
In this range I would think that the Audio Mirror SET 45 have to be considered. It depends on your speakers and listening habits, but my 89db KEFs work very well with these amps. They are rated at 45 watts per amp, which some may think is low, but for SET this is very much on the high end. However, they have dynamic power at over 100 watts per amp.
As The Absolute Sound wrote, at $10,000 these would receive their top rating and be considered a must listen to amp, at their price they are a steal. Add some nice NOS tubes for rolling and you have a killer combo, very easily in your range.
Other brands I would consider in this range:
T+A
Audio Research
McIntosh
Pass LabsMcIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
June 5, 2019, 11:40 AM #11
Well, IME the best amps have the best imaging and detail without the coloration of brightness and harshness, and for that you need tubes. I've only heard two solid state amps that really brought home the bacon in that regard, one is the re-imagined Sony V-FET (SIT) amp designed by Nelson Pass, which was only available in kit form. SITs have linearity and soft clipping similar to triodes (and have become rare, long out of production); a pity that Sony has been so intent on shooting their foot over the decades... The other is a class D prototype.
Our M-60 amplifier makes the list- its been the benchmark that other amps have had to beat. So far the SIT kit and that prototype have been the only ones that could keep up.
Bandwidth is simply not a thing, since tubes and solid state can have very similar bandwidth. I do find though that its harder to get solid state to have good resolution in the bass- you get get punch but less body and detail of the instrument. The two amps I mentioned above do that bit quite well.
June 5, 2019, 11:59 AM #12
What is it about Minnesota... tube amp companies congregating there....
Audio Research
Atma-Sphere
Audio Mirror
any others?McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Wyred 4 Sound ISO Recovery, DC Recovery | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
June 5, 2019, 12:05 PM #13
- Nov 2013
- Minnesota
- 1,369
AVA DVA 850 Mono block tube-ss hybrids should be in this group. These mono's are a hidden gem.
June 5, 2019, 12:26 PM #14
June 5, 2019, 12:33 PM #15
June 5, 2019, 03:44 PM #16
I'll add the Accuphase E-480 to the mix.
Accuphase A-75, C-3850, DP-750, T-1200, C-37, P-530 / Magico S7, Mcoat Red w/Mpod / LessLoss C-MARC Entropic cables (Spk. IC's PC's) / Clearaudio Innovation Wood, 9" Universal arm ,VTA adj. Outer Limit platter ring, Statement clamp / SteinMusic PI Carbon Signature Mat /My Sonic Lab Ultra Eminent EX MC cart./ Clearaudio 24v Battery PSU / Magnum Dynalab Signal Sleuth / B]Onyx Plus[/B] Sirius XM Sat Radio / Synergistic Research Galileo PowerCell SX ,Active Ground Block SE ,Black Box ,Acoustic ART, Atmosphere Infinity ,UEF panels /Stillpoints Apeture II panels /Furutech GTX-D NCF duplex outlets, NFC Booster-Braces/ 20a dedicated lines / SteinMusic H2 Harmonizers / Adona Eris II 5C racks / Symposium Acoustics Svelt Shelves /HRS Damping plates / KLAudio Ultrasonic RCM / Clearaudio Smart Matrix Pro. RCM /Kemp Electroniks SR plugs,/ Akiko Audio Corelli PLC,Tuning Sticks/ LessLoss Firewall 640X, Blackbody v.2, BlackGround Power Base 10X, Blackground Speaker Base 8X, Firewall for speakers
June 6, 2019, 12:28 PM #17
- Jun 2019
- Greenwich, CT
- 1
Best absolute sound -
Art Audio Diavolo 300B Copper Reference is the most musical amp I have ever heard and the balance of Art Audio's line is pretty special
Musical Fidelity M8 700s are phenomenal if you need lots of power and the Nu-Vista line is pretty special.
June 6, 2019, 12:56 PM #18
June 6, 2019, 01:14 PM #19
June 6, 2019, 02:33 PM #20
Accuphase E-480
Accuphase E-650
Soulution 330
and probably many more.Flemming
Lumin X1
Rotel Michi S5
Focus Audio FS788
LS cable : Yter
Nordost QB8
Rack : Finite Elemente Pagode
June 6, 2019, 05:57 PM #21
Does my Conrad-Johnson LP70S count? Originally sold for $7500.
June 6, 2019, 06:48 PM #22
- May 2019
- Germany
- 6
June 7, 2019, 12:51 PM #23
June 7, 2019, 02:19 PM #24
Audio Research REF75SE should be included in the list.
Audio Dealer in Coral Gables Florida for Mcintosh/Audio Research/Wilson Audio/Focal/Naim/Joseph Audio/D'Agostino/Nagra/dCS/VPI industries/Soulution/The Gryphon/Nordost/Shunyata Research/Kubala Sosna/Bryston/VAC/HRS/NAD/Lyra/Koetsu/Aurender/.
June 8, 2019, 01:21 PM #25
I like my McCormack DNA500, it makes my Apogees sing beautifully (and can actually drive them unlike many others).
Vine, Vide, Velcro - I came, I saw, I stuck around.
June 9, 2019, 08:35 AM #26
McIntosh MC 462
McIntosh MC 275VITom
Audio:
Amati Futura Mains
Amati Homage VOX Center,
Proac Response 1sc Rears,
Three MC2301's for L,C,R
MC 602 for the rears
C 1100, MX 151, MCD 1100, MR 77
Nottingham Dais with Sumiko Palo Santos Presentation
SurfacePro 3, JRiver, WW Starlight Platinum USB, Schiit Yggdrasil, Benchmark DAC3 HGC
Video:
MX 151, OppO BDP-95, JVC RS-500 DILA projector, 106" diagonal Stewart Luxus Screenwall Deluxe with Studiotek 130 G3 material.
Lake House:
Ohm F, MC 275V, C2300, MR 80, Rega P3
OnDeck:
McIntosh MAC 4300v
June 18, 2019, 09:56 AM #27
- Nov 2015
- 22
Of all the ones I've heard, an older version of the Herron Audio monos. I suspect the latest revision M2 monos are even better.
June 18, 2019, 04:42 PM #28
Herron is awesome gear!Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
June 18, 2019, 05:14 PM #29
- Nov 2015
- 22
Thank you Joe. This group was recommended by Jim Smith and I'm really liking it so far. I miss my Avantgarde Duos.
June 18, 2019, 06:02 PM #30
So happy that you are enjoying everything.
My Duos are absolutely wonderful. I'm very lucky.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
June 18, 2019, 06:45 PM #31
- Jun 2019
- VT
- 1
I use a Pass XA25.
This replaced elderly but truly fine VAC 300B amps.
My speakers are Rockport Atria 2s, Tortuga passive pre, Esoteric SACD, Sutherland duo phono, Koetsu Black.
Sound is glorious, ticks every high end box, then you ignore that stuff and disappear into the music.
i would not recommend the Pass with bright speakers as it passes everything unedited.
June 18, 2019, 07:14 PM #32
Love the Pass XA25. It's a superb amp.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
July 28, 2019, 11:52 PM #33
- Nov 2015
- 22
Herron M2 mono blocks and Coda Continuum No. 8 stereo amplifier. Nothing else I've heard in that price range comes to mind.
August 11, 2019, 03:51 PM #34
- Mar 2016
- Minnetonka, MN
- 59
Upgrade on the way...
