Results 1 to 34 of 34
  1. #1
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    The New Pass Int-25
    Just released and seen in passive display, the single-ended only Pass Int-25 ($7250) combines an XA-25 with a simplified Int-60 front end. The Int-25 has three inputs, all single-ended.
  2. #2
    Senior Member
    Join Date
    May 2013
    Silicon Valley
    Posts
    2,838
    Re: The New Pass Int-25
    Might make a nice bedroom system. I was going to also say work system, but I always had to use headphones at work.
    Bud
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Three 20 amp circuits.
  3. #3
    Senior Member
    Join Date
    May 2013
    Posts
    3,242
    If you live in a cold weather state.
  4. #4
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    https://www.passlabs.com/amplifier/int-25
  5. #5
    Senior Member
    Join Date
    May 2013
    Bucks County PA
    Posts
    3,702
    What types of speakers would one pair with that? Does 25w Class A equal anything more in Class B or C?
    Brian
    Main System -
    Rotel RCD-1572 / Rega P3 > Luxman 505UX Mark II > Fyne Audio F502SPs > Synergistic Cables
  6. #6
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    The XA25 is capable of putting as much as 50Wpc class-A (or 100Wpc class-AB) into a 2 ohm load so any reasonable speaker will do. The XA25 is a superb amp and any speaker you'd pair with a 25/50wpc tube amp will be great on the XA25 or INT25.
  7. #7
    Senior Member
    Join Date
    Nov 2015
    Kansas
    Posts
    5,948
    Nice looking integrated!
    McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
    ― Neil deGrasse Tyson
  8. #8
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    So anyone tried this yet ?
    1]bel canto EIX/ F5 monoblocks . BC cd2, tannoy eaton legacy 2]bel canto pre 5 ,arcam a85 , black ice modded dac
  9. #9
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,027
    I have. Very nice sounding unit.
  10. #10
    Join Date
    May 2018
    Adelaide, South Australia.
    Posts
    39
    Think I'll stick with my M2 clone.
  11. #11
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    yes i saw a first watt m2 today in a store , very interested in how folks get on with this amp . although it only has a few inputs
  12. #12
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    Has the int 25 replaced the int 30 ?
  13. #13
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    782
    First evening listening ...
    Marcin
  14. #14
    Audioshark
    Join Date
    Apr 2013
    Sarasota, FL
    Posts
    30,027
    Nice! Needs a lot of break in.
  15. #15
    Senior Member
    Join Date
    May 2017
    birmingham uk
    Posts
    586
    ah fantastic , soundrebels . not had much response in UK to thoughts on this amp . its pretty light in weight compared to some of the pass integrated . Nice to see the size of it compared to the bottles . keep us posted as it breaks in . i recently sold my lovely msb s200 so sometime next year will be looking at a replacement integrated
  16. #16
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    782
    For now first impression - don't even try to listen this small Pass during first hour after wake up from stand-by. The sound is dull, grey and irritating
    Marcin
  17. #17
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Like most, if not all, Pass/First Watt amps, they need a good hour or more to wake up and open up. My SIT-3 takes a little longer but once there, OMG it's superb!
  18. #18
    Join Date
    Sep 2018
    Houston
    Posts
    51
    Joe - do you warm up your SIT-3 with music streaming, or can you just turn it on for an hour? Thanks - Scotty
  19. #19
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Hi Scotty,
    Do you mean if I am only listening for an hour?
    It's sort of ok for the first hour, more listenable after about 20 minutes and wonderful after an hour or more. Once my amps are on, they are usually on for 8-12 hours.
    Quote Originally Posted by Scotty View Post
  20. #20
    Join Date
    Sep 2018
    Houston
    Posts
    51
    Joe - Before listening and while warming up the amp, do you stream music at low volume, or do you just turn on the amp (without streaming music) for the warmup period.....(and wondering if that is good for the amp)
  21. #21
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Ahhh, if my amp is on, I'm at least streaming. I never really just leave the amp on without music playing. I'm always running music through an amp that's on. And yes, low volume on first turn on, gradually getting to my preferred listening level.
  22. #22
    Join Date
    Sep 2018
    Houston
    Posts
    51
    I just raised the question to Kent at Pass Labs (what a guy, he responded to email on a Friday evening). He says there is no harm in warming up the amp with no load, although they have detected a slight improvement in their audio shows with streaming vs no streaming. Warming up amps with no speaker load is mostly a tube amp thing - not a good idea for the toobs.
  23. #23
    Join Date
    Sep 2018
    Houston
    Posts
    51
    Of course, all the components in the system (in my case for my near field listening rig workstation / studio: MSB Dac, PS Audio BHK Pre, SIT-3, Harbeth P3ESR) will also benefit from the warm up. So, you are doing it the right way. I agree, the SIT-3 is amazing and mesmerizing..........enjoy
  24. #24
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    SIT-3 and P3esr is supposed to be an awesome combination.
    I figure if my system is on, might as well play some tunes.
  25. #25
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    Does the int 25 sound quite a bit different from the int 250? If you read reviews of both, it's almost like they're not even made by the same company. Evidently there is no Pass "signature sound". But I've read they are both top notch stuff.
    Tom
  26. #26
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    XA25 is superb. I’m sure the Int-25 is as well. If I remember correctly, the XA25 is based off the XS series amps. You might absolutely love the Int-25 on your Harbeth Super HL5 speakers. It’s a powerful little amp.
    My thoughts are the bigger or the more inefficient speaker, the bigger the amp. Meaning, no need to overdo the combo. Sometimes you can finesse better sound out of a smaller, sweeter amp.
  27. #27
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    782
    Quote Originally Posted by bluegrassphile View Post
    Tom
    I'm playing now on INT-25 and reviewed a few years ago Int-60 and INT-250. So for me ... Int250 is the best, Int25 second ,and Int60 on the end.
    Marcin
  28. #28
    Super Moderator
    Join Date
    Apr 2013
    NY
    Posts
    18,726
    Thank you Marcin.
  29. #29
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    Quote Originally Posted by SoundRebels View Post
    Marcin, one person told me they thought the top end on the int 60 was "sweeter sounding" vs the int 250. Would you agree with that or not? I've never heard an int 250 so I can't comment. However, almost all reviews I've read on the int 250 were overwhelmingly positive.
  30. #30
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    782
    Not in my system ;-) For me 60 was much more analytical and on the colder side of neutrality than 250 and 25
    Marcin
  31. #31
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    Marcin,
    I just reread your posts. I ordered the int 250. I'm really pumped to hear it. I've heard the int 60 but not the int 250. I thought the int 60 sounded really good so I'm hoping the int 250 sounds even better to my ears. Thank you for your posts. I'm optimistic the int 250 will sound superb. It will also be running through an MSB Discrete DAC with optional second power supply. I'm told that will add to the SQ. Can't hardly go wrong. We'll see.
    Tom
  32. #32
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    Quote Originally Posted by Shadowfax View Post
    Klipsch? Fyne?
  33. #33
    Senior Member
    Join Date
    Feb 2019
    Southeast Iowa
    Posts
    992
    To make sure I understand...It's OK to turn the int 250 on (or any other SS amp) with the volume all the way down and let the amp warm up for half an hour or more?
  34. #34
    Senior Member
    Join Date
    Sep 2013
    Warsaw, Poland
    Posts
    782
    For the best effect just play the music with Your normal volume level ;-)
    Marcin
The New Pass Int-25
Posting Permissions
  • You may not post replies
  • You may not edit your posts
