Results 1 to 26 of 26
May 26, 2019, 01:01 PM #1
B&W800D3/ Luxman 900 combo/ MSB S2
https://youtu.be/5v6ytfAFHWQ
What a beautiful sound!
Sorry if this has been posted. A quick check didn’t turn up.
May 26, 2019, 01:16 PM #2
Who’s this character that posted this?
They sound wonderful. A couple of notes:
- they need an amp stable down to 1ohm to really perform their best. That includes Luxman, Hegel, Bryston, SimAudio, Gryphon, among others.
- they are designed to be 0.5 to 1m away from the back wall (behind the speakers) - as per the manual. If you pull them out further, the bass goes away. My thinking is that B&W’s are designed for use in studios and studios aren’t going to have them 8 feet into the room.
- little to no toe in (as per the manual). The wide dispersion tweeter sounds best straight on with a ever so slight toe in (like 5-10 degrees max).
The entire B&W line is under $30k and that gives me a nice floor stander option, with a great history.
May 26, 2019, 01:25 PM #3
May 26, 2019, 01:56 PM #4
Re: B&W800D3/ Luxman 900 combo/ MSB S2
That’s true! I’ve been away for 3 weeks in Europe and not caught up on the videos. I have 802D3’s in Prestige Finish (OMG) coming this week along with 803D3’s in white. I want some 702S2’s. $4500/pair and stupid good. ELAC killers. . I’m taking some 804D3’s on trade (for 802D3’s) and that only leaves 805D3’s, but I have enough stand mounts with every Harbeth model and Magico A1’s coming.
May 27, 2019, 08:34 AM #5
- May 2016
- Bucks County, PA
- 115
Why is this on a FOCAL Thread?
Amps: First Watt SIT-3, Pass XA25, Valvet E2 SE, LTA ZOTL40, First Watt SIT-1 Mono's, ARC Ref75SE, Decware Zen TorII MK4, Line Magnetic 845 Premium, Raven Reflection MK2, Audio Hungary Qualiton X200, Kingko 101Pro, Audio Hungary Qualiton I50
Pre-Amps: Luxman 900U, Coda 07X, ARC MP-1 Multi-Channel, Conrad Johnson Met-1 Multi-Channel
Disc Spinners: Luxman D-10X, Ayre DX5, Oppo 105/205
Speakers: Cube Audio Nenuphar Mini, Fleetwood Deville, Volti Razz, Spendor Classic 100, Rosso Fiorentino Certaldo 2, Klipsch Cornwall IV, Harbeth SHL5+, Harbeth C7XD, Omega Compact 8, Triangle Comete 40th Anniversary, Audio Solutions Figaro M, Graham LS3/5A
Check out my Facebook Page RIAA AWARD COLLECTORS to see over 3800 authentic Music Industry Awards (Gold and Platinum Records) from my personal collection. New awards added every month. https://www.facebook.com/riaaawards
May 27, 2019, 08:35 AM #6My Systems: http://www.audioshark.org/showthread...481#post158481
May 27, 2019, 08:37 AM #7
I switched to the monos yesterday:
https://youtu.be/j3uyBvGA898My Systems: http://www.audioshark.org/showthread...481#post158481
May 27, 2019, 10:02 AM #8
I assume all that equipment sitting out in front, blocking the speakers is not advised .... Just Kidding, I know you have to display it some where...
― Neil deGrasse Tyson
May 27, 2019, 10:11 AM #9
May 27, 2019, 01:56 PM #10
May 27, 2019, 03:56 PM #11
You’re back home now Mike? What are your early impressions of the 800D3s?
Rance
May 27, 2019, 04:28 PM #12
Yes. We got back in the wee hours of the morning on Thursday. I’m still a little jet lagged, but feeling much better today.
I went and played with the 800D3’s for the first time on Friday. They had set them up where we set every other speaker up in that room. After 30 seconds of listening, I knew it wasn’t right.
I read the manual and then called B&W to confirm what I read. Speakers approximately 0.5m from back wall, no less than 0.5m from side wall, approximately 3m apart and little to no toe in. Check. Moved things around and then it all snapped in place. The bass came alive, the tweeter was smoooooooth. The image was focused dead center. The wide dispersion tweeter is not one I would point at your ears or just outside your ears for example like we do with other speakers. The midrange is absolutely fantastic. Overall the speaker is incredibly engaging and musical when setup right and paired with the right amp.
I have a hunch a pair of B&W DB1D subs would just put things over the top. When I heard the B&W’s at Axpona, they had the subs and the impact and overall improvement wasn’t subtle. The new B&W subs are quite state of the art as well and allow complete control and setup from your iPhone.
If you get a chance, check out the HiFi News reviews on the 802D3 and 800D3. Both received the highest scores I’ve ever seen them give for a speaker. Maybe a little biased- British mag and British speakers, but still.
From my standpoint, I needed an entire lineup of floor standing speakers below $30k, not just a speaker or two. I needed a brand where I didn’t have to sit there and explain what the brand is and what they are about. Everyone has heard of B&W.
B&W for me is a little nostalgic. I owned B&W 801F’s with Carver amps about 30 years ago. Just loved that system.
For those looking for cost no object SOTA, cone and dome, well, that remains Magico IMO. The new M2’s are just incredible. But for those shopping below $30k, I now have many many more options. And damn good ones.
The 802D3’s and 803D3’s arrive this week. 702S2 at $4500/pair is also on the radar.
June 6, 2019, 09:29 PM #13
- Apr 2018
- 14
Call me crazy but I heard the 800D3 back-to-back with the Magico M2, same room, same gear and I preferred the 800D3. YMMV.
June 7, 2019, 06:55 AM #14
- May 2016
- 574
Thanks for sharing those videos Mike. I was going to ask you how the 800s compare to your KEF Blades but, then I saw your signature and don’t see KEF listed anymore.
I assume B&W is filling that void?
June 7, 2019, 07:06 AM #15
August 15, 2019, 01:54 PM #16
800D3 wins Golden Ear.
August 15, 2019, 04:58 PM #17
They do sound nice - much better than I expected. The Luxman and Gryphon amps mate extremely well with 800 D3.
_______________
Phono Pre: Pass XP-27
Speakers: MBL 101E MKII
Rack: Artesania Exoteryc
August 16, 2019, 02:50 AM #18
A friend of mine, who has an Esoteric front end, ARC Ref 10 and Momentum 400 monos, have switched from the 800D3 to Magico M3 and the improvment in his words was dramatic, across the board.
Probably much, as always, depends on the room, setup and the rest of the system.Adam
Speakers: Magico M3
August 16, 2019, 07:40 AM #19
March 10, 2020, 10:11 PM #20
- Nov 2019
- Canada
- 38
Hi guys, the 800 with the Luxman is such a nice combo. I have a question would like to seek for advice from you all. I’m currently using the 803D3 and matched with Accustic Arts Int amp (mark4) and now looking to upgrade the speaker cable (using only the Nordost super flatline) to get a better dynamic and musical. Any suggestions on what brand of speaker cable is a good match with B&W plus AA combo?
July 26, 2021, 11:34 AM #21
B&W803D3; McIntosh MA9000 integrated amp; Esoteric K-03 SACD/CD player; VPI Prime Signature/Ortofon Cadenza Bronze; Sennheiser HD800S and AudezeLCD-XC headphones
July 26, 2021, 11:38 AM #22
July 26, 2021, 12:01 PM #23
July 26, 2021, 12:12 PM #24
July 27, 2021, 06:27 PM #25
- Apr 2016
- 590
Wasn't it 95 Watts in Class A/B? If so, making that statement and comparing it to its 30 Watt Class A rated output is misleading.
July 27, 2021, 06:28 PM #26
Nucleus one
