Results 1 to 13 of 13
Thread: Pass XP22 Preamp Review
May 20, 2019, 08:19 AM #1
https://www.stereophile.com/content/...e-preamplifier
“In concert with the rest of my system, Pass Laboratories' XP-22 sounded great: full-bodied, rich-toned, robust, resolving, spacious, essentially neutral. But it was the whole experience of using the XP-22—its rugged, understated look; the subtle texture of its faceplate; the feel of the volume knob's action—that won me over. It just clicked for me, in a way that's entirely reasonable and yet transcends reason.”
May 20, 2019, 09:29 AM #2
Re: Pass XP22 Preamp Review
May 20, 2019, 04:17 PM #3
- Apr 2013
- Valrico, FL
- 407
Pass Labs gear is so good it even makes my crummy speakers sound good.
Howard
Pass Labs XS 300's, XS Pre | Berkeley Audio Design Alpha DAC Reference Series 3, Alpha USB | Aurender W20SE, ACS10 | Magico S7's with MPOD's, QSub 15 x 2 | Shunyata Denali 2000T x 2 with Sigma HC | Audience aR6-TS Incoming... Shunyata Everest 8000 w/ Omega XC | MIT Heritage and Oracle Interconnects and speaker cables | Critical Mass Maxxum rack | Resolution Acoustics custom room treatments
May 20, 2019, 04:27 PM #4
- Apr 2015
- 634
May 20, 2019, 04:39 PM #5
May 20, 2019, 05:25 PM #6
I found out two years ago that the XP-22 was excellent. They learned from the XP-20 that the interconnect cable between the power supply and the preamp is critical, and they used an aircraft grade cable/connectors on the XP-22.
Anyway, I have been very pleased with my XP-22. I even had to recently send it back for repair, and I swear it sounded even better when I got it back.Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
May 20, 2019, 09:01 PM #7
EQ: DEQX HDP-4
Speakers: Wilson Maxx3
May 20, 2019, 09:25 PM #8
- Apr 2013
- Valrico, FL
- 407
The XP-30 is their 3 chassis preamp.
Howard
May 22, 2019, 02:24 AM #9
The review in Stereophile was very good, but it was also a bit strange. He keep saying how he loved it, but then stated how another pre did something better. It does sound like a great preamp though!
One point he made that I 100% agree with is how much of a musical improvement a good preamp makes in a system!McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
― Neil deGrasse Tyson
May 22, 2019, 12:08 PM #10
May 22, 2019, 06:32 PM #11
- Apr 2015
- 634
Why would that be strange? Do you expect a given component to always be better than another one in ALL respects? What I do find strange is the reason:
"But when I listened to the Pass Labs and PS Audio preamps in direct, volume-matched comparisons, I was surprised how close they were in sound. The Pass seemed a tad more open, and perhaps more extended at the extremes. The soundstage was a touch more precise. Yet, through the PS Audio, music sounded more visceral, more embodied, to a small but meaningful degree. That quality is important to me—a big success for the much cheaper PS Audio preamp."
As an experienced audiophile he should know that when the treble output is higher (Pass: "more extended at the extremes"), the body and viscerality of sound may appear somewhat less (and he says, it is better on the PS Audio "to a small degree"). When I dampen the treble in my room by, for example, putting a more absorbing carpet between listening seat and speakers, then mid-bass on rock, which affects viscerality, may seem more pronounced. But of course, the carpet does not alter mid-bass output at all (it only works for absorbing treble), but the ear/brain interface interprets the sum of frequency output, and in this case assigns relatively more mid-bass prominence when treble is attenuated.
Similarly, when treble is less, lower midrange body may also appear relatively more pronounced.
One point he made that I 100% agree with is how much of a musical improvement a good preamp makes in a system!Simaudio Moon Neo 260 DT CD Transport / MIT SL-Matrix Plus AES/EBU digital cable / Schiit Yggdrasil Analog 2 DAC / Octave HP 700 preamp / Octave RE 320 stereo amp with Super Black Box / Reference 3A Reflector monitors on Sound Anchors Signature Stands / dual JL Audio Fathom 112 v2 subwoofers on ASC SubTraps / ZenWave Audio D4 and SMSG cables / Acoustic treatment: tube traps, Tri-panels, window plugs, ceiling diffusers (all ASC), large absorbing panels (Acoustics First), diverse carpets chosen for acoustic properties: wool, polypropylene basket-weave
May 22, 2019, 06:55 PM #12
I got the exact same experience when I recently got the Stage 2... wow did it solidify the system!
I just felt that the whole review was a bit off, or wishy washy... it seemed to me that he really liked the preamp but was very hesitant to say it was better then the others. I guess with the bold statement on the cover of the issue I expected more from the review. The cover basically states that the preamplifier is "the state of the preamplifier art", but the review did not even come close to making a similar statement.McIntosh C49, MC152, MR85, R778 | T+A DAC 8 DSD | KEF LS50 Meta w/S2, KC62 (x2) | Rega RP8, Ania Pro, NEO PSU | Technics SL-1500C | Audio Technica VM750ML | Hexmat Eclipse, Yellow Bird, Molekula, Molekula Mini | Pro-Ject VC-E | Falcon NW PC Server (Roon Core & HQPlayer) | Microsoft Surface Pro 6 (Roon Controller) | Abyss Diana Phi | Schiit Jotunheim 2 | Astell&Kern SE200 | Oppo BDP105
December 7, 2019, 10:21 AM #13
- Dec 2019
- USA
- 786
Excellent read and well written, but it seems he was trying to qualify his opinion too much. But I normally learn as much by the positives an author comments upon as well as what they don't comment upon - or tend to qualify (sometimes to a fault).
It did earn the Stereophile Amplification Component of the Year Award - https://www.stereophile.com/content/...component-2019
Looks like a great room and install!
