Results 51 to 79 of 79
May 4, 2019, 11:39 AM #51
- Apr 2013
- 259
Re: CH Precision Announces New 10 Series
May 4, 2019, 07:41 PM #52
- May 2015
- 100
May 5, 2019, 09:53 AM #53
- Apr 2013
- 259
I had an ARC REF10 prior to upgrading the MSB to the Select II. I was very sure that the "hyperbole" of MSB was just that and that surely the pre stage on the Select couldn't be better. Well I was wrong. The MSB direct was, IMHO, better. More neutral and alive. It was an easy choice and selling the REF10 helped make my rationalization of upgrading to the Select II much easier.
However, upon the recommendation of several who have tried (and purchased it), I was cajoled into trying the L1 Stereo + X1 power supply. Took a couple of days to get the gain just right but once matched I was pretty shocked how good it was. Depth and width definitely increased and noise floor (amazing with the MSB direct) got even better. I was flabbergasted as I wasn't expecting any improvement. I can't say the bass was any better. More dimensionality, which is hard to imagine and more neutral, another aspect I was surprised to find.
Now is it worth the price? At near or just under or over 50K list, there lies the issue. I can't say. I have been listening direct again for the last two weeks and I definitely "miss" the L1/X1 BUT the MSB direct is world class, IMHO, better than a world class preamp I sold the REF10 and since I am digital only, find it difficult to justify the cost for the incremental improvement. BUT there was a significant improvement which I was not expecting.
May 5, 2019, 01:10 PM #54
- Jan 2014
- 119
May 5, 2019, 02:46 PM #55
- Apr 2013
- 259
Yes I used all Gobel cables. I didn't, but would have like to have used, a Gobel plug to the X1. I have Gobel plugs everywhere else. Timbre were not drastically different but subtle, again slightly in favor of the L1/X1. Microdynamics was a significant surprise in improvement possibly because the noise floor was so improved.
My Gobel speakers are extremely good at producing that holographic stage I find endearing about many other speakers like some panels, MBLs, etc and the improvement in space with the L1/X1 was also stellar.
It was an eye opening event for me that I wasn't expecting.
May 5, 2019, 04:31 PM #56
- Jan 2014
- 119
May 5, 2019, 07:04 PM #57
- May 2015
- 100
May 5, 2019, 10:21 PM #58
I find your comments intriguing particularly because of how adamant the conventional wisdom is that the MSB sounds better without a preamp.
It speaks volumes about the quality of the two-box CH L1/X1 stereo combo. And you may be even more surprised about the positive effect of the 4-Box CH L1-X1 mono combo. Although at that point, the marginal performance/cost ratio may become harder to justify.
Sent from my iPhone using TapatalkRockport Lyra speakers; TotalDac Amp-1 mono blocks; four box CH Precision L1/X1 pre/power supply monos; CH precision P1/X1 phono/power supply; TotalDac d1-driver monos; Pacific Microsonics Model 2 DAC; TotalDac d1-12 MkII DAC with two reclockers; Kodo The Beat Turnatable with LT Schroder magnesium tonearm and Lyra Atlas cart; Taiko Extreme server; Kalista Dreamplayer CD Transport; Taiko Audio Daiza Platforms; Nordost Odin2 Power Cords and Analog ICs; 512 Engineering/Tim Marutani Balanced Transformers (30 amp for sources; 50 amp for amps); Rives designed dedicated room.
May 6, 2019, 06:48 AM #59
- Mar 2018
- 54
I apologize for jumping into a CH Precision thread, however I felt it worthwhile mentioning that I have also tested MSB Select direct vs through a preamp, and preferred the sound including the preamp. The amps were Naim Statement set. I would love to compare CH to Naim... Best regards to all.
May 6, 2019, 09:19 AM #60
- Apr 2013
- 259
I have an M1.1 which was set to a global feedback of 10% and gain of 2.5. MSB recommends using their DAC with volume setting at 94-98 depending upon the preamp with 98 being recommended for most preamps. The L1 was set at a gain of 0. So I listened to some of my go to albums while trying to to matching all the options. Ultimately I found leaving M1.1 at 2.5 was best. MSB set to 98 was the correct setting. Increasing the gain/sensitivity on the XLR input on the L1 to 3.5 I found was ultimately the right ticket and closest to what I was used to with the MSB direct
May 7, 2019, 03:13 PM #61
Francisco
May 7, 2019, 07:01 PM #62
I didn’t name anyone!
But if the shoe fits wear it.
Tal vez te queda también?Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Magico S3 Mk2 in Mcast Pewter
Denali 6000S
Ansuz and MIT cabling
Timbernation walnut racks
May 7, 2019, 07:13 PM #63
Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Denali 6000S
May 7, 2019, 08:12 PM #64
- Apr 2013
- 259
May 7, 2019, 08:32 PM #65
1. Now it comes that he did not name anyone ?, it was obvious to whom he insulted.
2. I very much doubt that Mike wants special privileges for being the owner. When he publishes is one more.Francisco
May 7, 2019, 08:34 PM #66
Let’s just get this topic back on track.
May 8, 2019, 02:54 PM #67
- Jan 2014
- Massachusetts
- 101
May 9, 2019, 08:16 AM #68
Just In, CH M10 in the Dark finish, considerably deeper than M1.1
May 9, 2019, 08:16 AM #69
May 9, 2019, 08:20 AM #70
- May 2015
- 100
Great pictures. The depth should be due to two big transformers inside the case. Similar to MBL 9011. Can you also take L10 photos please?
May 9, 2019, 08:43 AM #71
CH L10 in Gold. Looks like they also have another L10 next to it - showing it's back.
May 9, 2019, 01:14 PM #72
Nice looking gear! With performance to match I imagine.
Larry
Lumin U1
Chord Dave Dac
Vac Master Preamp
Vac 200IQ Amp
Denali 6000S
May 11, 2019, 12:43 AM #73
- Nov 2013
- 6
Hi All
I’m an owner of a CH Precision preamp and amp and also agree with some of the posts about customer service. I have had several dealings with Florian and their response to questions and supplying some additional parts was first class. Best I have come across to date.
Yes their equipment price is not cheap but at least they back up an outstanding product with customer service unlike some other brands I won’t mention on public forums.
May 16, 2019, 01:57 PM #74
- Apr 2016
- italy
- 62
L 10 inside
May 16, 2019, 09:24 PM #75
- Mar 2014
- Canada/HK
- 312
Impressive. Did anyone hear it?
May 17, 2019, 02:39 AM #76
May 17, 2019, 10:35 AM #77
- Apr 2016
- italy
- 62
Will be sold starting from december together with M 10
P 10 will be ready half 2010
May 18, 2019, 03:17 AM #78
Some more shots from the CH room(s) during the show. CH was clearly the dominant on the highest level among the manufacturers of solid state electronics. Wonderful products by great people.
/ Marcus, www.perfect-sense.se
PERFECT SENSE
Showroom in Stockholm, Sweden | info@perfect-sense.se | 08 518 368 00 | Follow us on Facebook
May 18, 2019, 03:56 AM #79
