Results 1 to 46 of 46
May 1, 2019, 04:47 AM #1
New Magico A series speakers announced
New A series standmount, Centre and Sub announced.
May 1, 2019, 04:48 AM #2
Re: New Magico A series speakers announced
MAGICO ACC 3 way High Performance Center Speakers
Aircraft Grade Aluminum Enclosure
The ACC enclosure is constructed using 3⁄8” thick 6061 T6 aircraft grade aluminum, similarly to the enclosure developed for the Q1 and is available in an elegant brushed, black-anodized aluminum finish. An innovative internal bracing technique along with the most advanced damping materials makes the sealed enclosure incredibly rigid and free of unwanted mechanical resonances. The finished enclosure design of the ACC is evaluated in simulation using the latest FEA software along with physical testing to meet the no-compromise requirements of Magico for optimized enclosure rigidity, stability and to ensure benchmark acoustical standards.
High Frequency Driver
The ACC tweeter follows the A3 with a pure Beryllium-diaphragm tweeter with an optimized 28-mm dome surface which is based on the fundamental design platform and geometry of our reference M-Series tweeter design. The customized neodymium motor system is encased in an improved back chamber with our latest generation damping materials that facilitate ultra-low distortion, higher power handling, massive dynamic capabilities and extended linear voice coil movement.
Midrange Driver
The 6-inch midrange driver, also deployed in the A3, features a Multi-Wall carbon fiber cone with a layer of XG Nanographene, providing an optimal stiffness to weight ratio and an ideal damping factor. The driver frame has been simulated and tested for the optimal combination of stiffness and damping. Minimum acoustical impact is achieved through reducing vibration modes while maximizing air flow. An overhung neodymium-based motor system incorporates extra-large magnets to ensure a stabilized magnetic field in the 75-mm pure titanium voice coil. The ACC midrange driver is optimized for minimal music related distortions in its band pass, in both the frequency and time domains using latest state of the art FEA simulation of acoustical, mechanical, electromagnetic and thermal behavior.
Bass Driver
Extended low bass frequencies which are incredibly deep and fast result from 7-inch bass drivers (x2) that are found in the A3 which are produced with advanced manufacturing techniques using Multi- Wall carbon fiber with a layer of XG Nanographene. Powerful neodymium magnets control a 75-mm pure Titanium voice coil that has long throw excursion and produces clean, undistorted sound pressure levels. Individual driver performance and the ACC loudspeaker in its final form are tested and optimized for acoustical, mechanical, electromagnetic, and thermal behaviors using the latest state-of-the-art Finite Element Analysis simulation testing equipment.
Crossover
The drivers in the ACC are acoustically integrated using Magico’s proprietary Elliptical Symmetry Crossover topology that utilizes state-of-the-art components from Mundorf of Germany. The dividing network features a 24db per octave Linkwitz-Riley filter that maximizes frequency bandwidth while preserving phase linearity and minimizing intermodulation distortion.
SPECIFICATIONS:
Dimensions: 15.6"H x 12"D x 8.5"W
Weight: 96 lbs
High: 1.1” Beryllium Tweeter
Mid: 6” Graphene Nano-Tec Midrange
Bass: 7” Graphene Nano-Tec Bass (x2)
Sensitivity:88 dB
Impedance: 4 Ohm
May 1, 2019, 04:49 AM #3
MAGICO A1 Reference Quality Speakers
Magico A1 Specifications:
Weight: 45 lbs.
High: 1.1" Beryllium Dome Tweeter
Mid-Bass: 6.5” Graphene Nano-Tec Midbass
Sensitivity: 85dB
Impedence: 4 ohms
The A1 enclosure is constructed using 3⁄8” thick 6061 T6 aircraft grade aluminum, similar to the enclosure developed for the Q1 and is available in an elegant brushed-aluminum, black anodized finish. An innovative internal bracing technique along with the most advanced damping materials makes the sealed enclosure incredibly rigid and free of unwanted mechanical resonances. The complete enclosure design of the A1 is evaluated in simulation using the latest FEA software along with physical testing to meet the uncompromising requirements of Magico for optimized enclosure rigidity, stability and to ensure benchmark acoustical standards.
Featuring the same tweeter as the full range A3, the A1 utilizes a pure Beryllium-diaphragm with an optimized 28-mm dome based on the fundamental design platform and geometry of our reference M- Series tweeter. The customized neodymium motor system is encased in an improved back chamber with our latest generation damping materials that facilitate ultra-low distortion, higher power handling, massive dynamic capabilities, and extended linear voice coil movement.
Mid-Bass Driver
The newly developed 6.5-inch mid-bass driver features a Multi-Wall carbon fiber cone with a layer of XG Nanographene, providing optimal stiffness to weight ratio and an ideal damping factor. The driver frame has been designed, simulated and tested for the optimal combination of stiffness and damping. Minimum acoustical impact is achieved through reducing vibration modes while maximizing air flow. The motor system incorporates extra-large magnets to ensure a stabilized magnetic field in the 39- mm pure titanium voice coil. The A1 mid-bass driver is optimized for minimal music related distortions in its bandpass, in both the frequency and time domains using state of the art finite element analysis simulation of acoustical, mechanical, electromagnetic and thermal behavior.
Crossover
The drivers in the A1 are acoustically integrated using Magico’s proprietary Elliptical Symmetry Crossover topology that utilizes state-of-the-art components from Mundorf of Germany. The 2-way network features a 24db per octave Linkwitz-Riley filter that maximizes frequency bandwidth while preserving phase linearity and minimizing intermodulation distortion.
May 1, 2019, 12:57 PM #4
Pricing was also announced, with all having a ship date of 2019Q3.
A1: $7400/pair
ACC: $6800
ASUB: $6500Neko Audio
May 1, 2019, 01:51 PM #5
May 2, 2019, 10:40 AM #6
Great photos. I'm curious about the stands for the A1. Looks like it would make a wonderful front, center and rear channel HT set up. The A3/ASub combo should also be a good combination. For about $20K, I wonder if people will choose the A3 plus one ASub or the A1 and two ASubs. This is pretty exciting news from Magico.
Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
Analog: Micro Seiki SX 8000 II, 2 NOS SME 3012R tonearms, 2 vdH Colibri Grand Cru, Colibri XPP
Electronics: Lamm LP2.1 Deluxe, Lamm LL1.1 Signature, Lamm ML2
Speakers: Vitavox CN-191 corner horns
Cables: Stock SME phono cables, DIY ICs and speaker cables, Ching Cheng power cords, custom rack and amp stands
May 2, 2019, 12:52 PM #7
2 subs for audio
1 + for home theaterJock
May 2, 2019, 01:43 PM #8
Thank you professor. I understand that. I was asking this question for 2-channel audio: "For about $20K, I wonder if people will choose the A3 plus one ASub or the A1 and two ASubs." In other words, for the same amount of money, I wonder what combination people would prefer.
May 2, 2019, 01:51 PM #9
May 3, 2019, 07:52 AM #10
- Apr 2017
- Australia
- 1,758
The dimensions given for ACC look wacky to me.
May 3, 2019, 09:25 AM #11
For me Magico was a company who's effort was on the best, most innovative speakers they could design.
Now it seems like they want to ultimately be in Best Buy and Music Direct with this new range of products with the Magico name on the front.
Alon better be careful because the spotlight in this business changes in a second and right now it doesn't feel very bright........
May 3, 2019, 12:15 PM #12
Jock
May 4, 2019, 08:20 AM #13
Great initial thoughts on A3 from M&S !
May 4, 2019, 08:21 AM #14
May 5, 2019, 12:13 PM #15
Thanks for posting this link, Mike. I was surprised to read the second sentence:
"A few hours ago the Magico A3 speakers finally arrived. I'm not sure if any of floor-standing speakers created such interest as these four-ways. "
Are the Magico A3s really four-way designs? I had always thought they were three-ways.Link to my system thread: https://www.whatsbestforum.com/threa...l-sound.32867/
May 5, 2019, 12:15 PM #16
May 13, 2019, 03:58 PM #17
OR, the strategy could be to get people into the brand sooner and then get them to move up the range.
I would not have considered Magico at all in the past due to the price points, but I'm soon to take delivery of A3's. Just shopping for them and listening to them has already greatly increased my brand awareness. I could see M2's for example in my future if all goes well!
May 14, 2019, 09:08 AM #18
May 14, 2019, 09:35 AM #19
What would you consider to be a "timely fashion" for delivery of a newly built Magico? I waited about 8 weeks for my S7's and I don't consider that a inordinate amount of time to wait for a hand built SOTA loudspeaker. Considering the huge amount of pleasure i'm now experiencing, it was well worth the wait. The anticipation and build -up to delivery was really fun to experience.
Accuphase A-75, C-3850, DP-750, T-1200, C-37, P-530 / Magico S7, Mcoat Red w/Mpod / LessLoss C-MARC Entropic cables (Spk. IC's PC's) / Clearaudio Innovation Wood, 9" Universal arm ,VTA adj. Outer Limit platter ring, Statement clamp / SteinMusic PI Carbon Signature Mat /My Sonic Lab Ultra Eminent EX MC cart./ Clearaudio 24v Battery PSU / Magnum Dynalab Signal Sleuth / B]Onyx Plus[/B] Sirius XM Sat Radio / Synergistic Research Galileo PowerCell SX ,Active Ground Block SE ,Black Box ,Acoustic ART, Atmosphere Infinity ,UEF panels /Stillpoints Apeture II panels /Furutech GTX-D NCF duplex outlets, NFC Booster-Braces/ 20a dedicated lines / SteinMusic H2 Harmonizers / Adona Eris II 5C racks / Symposium Acoustics Svelt Shelves /HRS Damping plates / KLAudio Ultrasonic RCM / Clearaudio Smart Matrix Pro. RCM /Kemp Electroniks SR plugs,/ Akiko Audio Corelli PLC,Tuning Sticks/ LessLoss Firewall 640X, Blackbody v.2, BlackGround Power Base 10X, Blackground Speaker Base 8X, Firewall for speakers
May 14, 2019, 09:52 AM #20
8 weeks for S models probably OK for that level of customer, plus u ordered a special finish so that plays into it....
A products should ship within 2 weeks at most
I waited about 5 months for my M6's
May 14, 2019, 01:33 PM #21
I ordered my A3's in late December . . . and it's now May 14th and they aren't here yet. Should get here this month. I ordered just after they got really "hot" in the market and there obviously was a huge backlog.
That IS a long time to wait, but I am trading my Devore Nines towards them and pretty OK with listening to the Devores in my home til the A3's arrive. If I didn't have speakers already, the wait would have not worked out - definitely.
May 14, 2019, 01:43 PM #22
Congratulations Bart. I admire your patience and had no idea that the wait for a pair of A3s was that long. I see that you are from Boston. Did you audition the A3s at Goodwin's High End before deciding to buy them? If so, may I ask which room you heard them in, and what the associated gear was? I have not heard them yet but would like to.
May 14, 2019, 02:03 PM #23
Hi Peter. Yes I'm from the Boston area as well, and are buying them from Goodwins. I listened to them there (the middle room on the right-hand side), and then was able to work it so that I brought them home for about 4 days. It was a time where they could spare them around Thanksgiving I think it was, and a 'Im not going to buy them unless I get them into my home for a few days' deal. It worked out ok for Alan (a friend and I used the friends truck and did the moving ourselves) but probably very hard to pry them away for a few days now-a-days.
I'm a Naim guy pretty much, and part of the problem was that their Naim pre-amp in the store had a fault and that made it impossible to audition with Naim there. The in-home audition was key, as their rooms are quite different sounding than my home.
I had already borrowed their Devore X's (great but too much for my room, despite being perfect in their middle room) and the A3's worked way better at home. After 20 minutes we were in love with them.
NOTE: In their middle room, the A3's were almost to the 'boring' line for me, but in my much more lively room at home they were very good and fast. It's hard to describe what I mean by 'boring' but they were very different in my lively room vs. Goodwins very dead listening room.
May 14, 2019, 02:28 PM #24
Thanks Bart. Goodwins can be quite accommodating at times. I have a friend who has tried a bunch of electronics from them at home and ended up buying. I've heard mixed reviews of the A3 in that middle room. Glad to read it worked out for you. There is nothing like a home audition.
May 15, 2019, 09:29 AM #25
- Apr 2017
- Australia
- 1,758
I waited about that many months also, for my S3.
May 15, 2019, 11:14 AM #26
Speakers: Magico S3 (23')
Streamer: HiFi Rose RS150b
CD/DVD: Oppo 205
May 18, 2019, 03:07 AM #27
August 8, 2019, 07:44 PM #28
A1 stand has been finalized.
August 8, 2019, 07:49 PM #29
- Apr 2017
- Australia
- 1,758
I'm reluctant to call any Magico product ugly, but that A1 stand is ugly.
Are they doing a stand for ACC?
August 8, 2019, 08:04 PM #30
- May 2013
- 3,242
That looks to be a Sound Anchor stand.
August 8, 2019, 08:08 PM #31
Yup. That’s what the official announcement says.
http://soundanchors.com/products/category/10
August 8, 2019, 08:09 PM #32
- Mar 2014
- Canada/HK
- 312
August 10, 2019, 05:02 AM #33
- Apr 2017
- Australia
- 1,758
Any consensus out there that this would have looked much better under A1?
August 10, 2019, 05:54 AM #34
Bud
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Three 20 amp circuits.
August 10, 2019, 10:25 AM #35
This was a nice Magico stand at a different price point:
August 13, 2019, 12:17 PM #36
August 13, 2019, 01:07 PM #37
- Oct 2013
- Sacramento
- 1,129
They're so cute when they're little. Nice compact stand to give some isolation and tilt.
August 13, 2019, 01:16 PM #38
August 13, 2019, 02:26 PM #39
Paul Klipsch came out with the Hersey speaker which was named because it was considered Heresy to build such a small speaker considering his Klipshcorn, La Scala and Cornwall speakers. He also used a riser tilted back with the Heresy speakers. Is this Alon Wolfs version?
CD/DVD: Oppo 205
August 13, 2019, 02:49 PM #40
- Oct 2013
- Sacramento
- 1,129
October 9, 2019, 10:23 AM #41
- Apr 2017
- Australia
- 1,758
....and this is what the box looks like. Arrived today.
To be powered by Halcro. Hopefully it's a nice match across the front with my Halcro powered M3's and S-sub.
October 9, 2019, 11:59 AM #42
October 9, 2019, 12:44 PM #43
- Apr 2017
- Australia
- 1,758
Not yet. The Q3's still gravitating towards lowly surround channel duty.
October 22, 2019, 10:17 AM #44
- Apr 2017
- Australia
- 1,758
Giving my M3 a rest whilst I loosen up the new ACC. The S-sub you also see there is obviously a case of over-kill. I like over-kill. Oh, did I mention I have something of everything in the Magico line-up? A-series, S-series, Q-series and M-series. The full set. Suffice to say I like their stuff.
October 24, 2019, 01:56 PM #45
October 24, 2019, 04:13 PM #46
- Apr 2017
- Australia
- 1,758
The Q3 are in the same room you see all those other speakers, but they aren't connected to anything. Q3's don't need subs, same as M3 don't need subs, until you actually use them with subs.
