Results 1 to 15 of 15
Thread: Tube, Solid State, Other?
May 1, 2019, 12:52 AM #1
Is the best of both worlds when you blend tubes and solid state?
If so, what are you running?
If not, why?
Speakers: Wilson Alexias
May 1, 2019, 10:13 AM #2
Re: Tube, Solid State, Other?
My first decent setup included a Sound Valves 101i Tube Pre with an Odyssey Stratos Plus and was really enjoyable for the cost and drove my Dynaudio 82s nicely.
My main system now is all tube pre, with a Hybrid amp, again very enjoyable.
I have yet had the chance to have a full tube amp or full tube integrated-----------------
Brian
May 1, 2019, 11:44 AM #3
When I want maximum enjoyment, I opt for all tube amp and preamp. Typically though I enjoy playing music for hours on end. When I know that I am mostly going for the long haul, I’ll switch out the amp and use solid state. It’s still great but I worry less about wear and tear.
May 1, 2019, 12:22 PM #4Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
May 1, 2019, 12:23 PM #5Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
May 1, 2019, 12:46 PM #6Micro Seiki SX-8000 air bearing table, SME 312s arm, SME 3012R arn, Dynavector XV-1s cartridge, Lyra Etna SL cartridge, ARC Ref 3 phono stage, Otari MX-55 2 track R2R, Ampex 350 tape repros, Roon Nucleus Plus music server, HiFi Rose 150B DAC, ARC Ref 6, ARC Ref 75 with KT-150s, Parasound JC5 amp , JBL 4345 speakers, Viero Equilibro Level 3 speaker cables, and Definitive Technology Ref subs.
May 1, 2019, 12:50 PM #7
I've got a hybrid system. MC 2301 power amps have SS input circuits and tube outputs. My C 1100 has a hybrid MC preamp section - SS input, tube output. So even though my components are labeled 'Tube' they are hybrids. I like the way they sound.
With three MC 2301's in the mix, a tube change out is 24 KT-88's and 6 12 AT7's. That's not counting the 12 tubes in the preamp. Wear and tear is just a budget item, kind of like having a phono cartridge to deal with.Tom
Audio:
Amati Futura Mains
Amati Homage VOX Center,
Proac Response 1sc Rears,
Three MC2301's for L,C,R
MC 602 for the rears
C 1100, MX 151, MCD 1100, MR 77
Nottingham Dais with Sumiko Palo Santos Presentation
SurfacePro 3, JRiver, WW Starlight Platinum USB, Schiit Yggdrasil, Benchmark DAC3 HGC
Video:
MX 151, OppO BDP-95, JVC RS-500 DILA projector, 106" diagonal Stewart Luxus Screenwall Deluxe with Studiotek 130 G3 material.
Lake House:
Ohm F, MC 275V, C2300, MR 80, Rega P3
OnDeck:
McIntosh MAC 4300v
May 1, 2019, 12:59 PM #8
May 1, 2019, 01:01 PM #9
May 1, 2019, 02:21 PM #10
- May 2017
- Cleveland, Ohio, USA
- 531
For an accurate, Hi-Fidelity, low maintenance sound, it's solid-state all the way!
For a pleasant, euphonic sound, tubes are the first choice.
May 1, 2019, 09:36 PM #11
I’m fortunate to have the variety. Rotating gear does have its benefits. It certainly makes you appreciate what’s not in the system. The delta between great solid state and great tube gear is getting smaller all the time. Variety is the spice of life.
May 1, 2019, 09:51 PM #12
- May 2013
- 3,242
Same here have options on both sides so I change based on mood and/or temperature.
May 2, 2019, 07:23 AM #13
viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
May 2, 2019, 07:48 AM #14
Typically on weekends, my system is constantly playing (if I need to run an errand or two, no big deal) weekdays for about 10-16 hours per day depending on my schedule. I don't leave tube amps unattended, but don't worry much about my tube preamps and solid state amps although nothing is immune. It's all good.
I'm fine with the way I run my gear. You'd be surprised how many toasters, coffee pots, wall warts, etc cause problems. Where I work, I'm just a little more aware of what can happen. That's all.Fleetwood Deville by Oswald Mills Audio, Vienna Acoustics Haydn Jubilee, Wharfedale Linton w/ stands, Klipsch RB-75, Klipsch RP-160M.
May 2, 2019, 08:25 AM #15
wow -- makes total sense for that many hours. that would burn through expensive and hard to find output tubes pretty quickly!
i am only at ~2.5 hrs/day and like you don't leave it unattended. with an expected 2,000 hour life at the recommended bias setting i end up replacing my 6c33c output tubes about once every year or so -- at $69 each its not big deal.viking acoustics berlin r mk2 | almarro a318b + air tight atc-5 (phono) | clearaudio concept + virtuoso v2 MM | t+a dac8 dsd + diy transport + roon rock
It's like music you're only as good as your latest hit, LOL Last year it was the minuet, this year, well, it wasn't. I notice that each online magazine seem to have their picks or favorites they...
